Feb 8 06:56:00 syslogd started: BusyBox v1.16.1
Feb 8 06:56:01 kernel: [ 51.091851] md: md2: set sda3 to auto_remap [0]
Feb 8 06:56:01 kernel: [ 51.096393] md: md2: set sdd3 to auto_remap [0]
Feb 8 06:56:01 kernel: [ 51.100922] md: md2: set sdc3 to auto_remap [0]
Feb 8 06:56:01 kernel: [ 51.105450] md: md2: set sdb3 to auto_remap [0]
Feb 8 06:56:01 kernel: [ 51.155938] 0: w=1 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Feb 8 06:56:01 kernel: [ 51.160921] 3: w=2 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Feb 8 06:56:01 kernel: [ 51.165923] 2: w=3 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Feb 8 06:56:01 kernel: [ 51.170891] 1: w=4 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Feb 8 06:56:01 kernel: [ 51.175856] raid5: raid level 5 set md2 active with 4 out of 4 devices, algorithm 2
Feb 8 06:56:01 kernel: [ 51.183510] RAID5 conf printout:
Feb 8 06:56:01 kernel: [ 51.186735] --- rd:4 wd:4
Feb 8 06:56:01 kernel: [ 51.189437] disk 0, o:1, dev:sda3
Feb 8 06:56:01 kernel: [ 51.192837] disk 1, o:1, dev:sdb3
Feb 8 06:56:01 kernel: [ 51.196236] disk 2, o:1, dev:sdc3
Feb 8 06:56:01 kernel: [ 51.199635] disk 3, o:1, dev:sdd3
Feb 8 06:56:10 scemd: scemd.c:122 fan_type=7, raid_type=1, led_type=1, thermal_type=1, fanctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=2, fan_number=2, ebox_type=0, pis_type=2, rtc_type=1
Feb 8 06:56:11 scemd: modules/fan_speed_adjust_common.c:158 Fan Table HW Version: DS409p
Feb 8 06:56:11 scemd: modules/fan_speed_adjust_common.c:161 Type: INTERNAL Fan Mode: HIGH (suitable for 3.5'' HD)
Feb 8 06:56:11 scemd: modules/raid_sys_volume_check.c:163 MD0 active disks 4, designed disks 4
Feb 8 06:56:11 scemd: modules/raid_sys_volume_check.c:163 MD1 active disks 4, designed disks 4
Feb 8 06:56:11 scemd: modules/disk_hibernation.c:142 Force hibernation enable, idle minutes 30
Feb 8 06:56:12 synoprint: printer_device_open.c:16 bad parameter.
Feb 8 06:56:17 synousbdisk: RCClean succeeded
Feb 8 06:56:17 synosata: synosata.c:187 no external sata devices used
Feb 8 06:56:18 ddnsd: main(ddnsd.c:2693): not enable DDNS, shutdown daemon
Feb 8 06:56:19 kernel: [ 69.562033] ehci_hcd 0000:00:0e.1: Enabling legacy PCI PM
Feb 8 06:56:20 syno_hdd_util: Model:[WD15EADS-00P8B0], Firmware:[01.00A01], S/N:[WD-WMAVU0065963] in [/dev/sdd] is not ssd
Feb 8 06:56:20 syno_hdd_util: Model:[WD15EADS-00P8B0], Firmware:[01.00A01], S/N:[WD-WMAVU0082411] in [/dev/sdc] is not ssd
Feb 8 06:56:21 syno_hdd_util: Model:[WD15EADS-00P8B0], Firmware:[01.00A01], S/N:[WD-WMAVU0047685] in [/dev/sdb] is not ssd
Feb 8 06:56:21 syno_hdd_util: Model:[WD15EADS-00P8B0], Firmware:[01.00A01], S/N:[WD-WMAVU0036371] in [/dev/sda] is not ssd
Feb 8 06:56:23 s2s_monitor: Fail to create default monitored folder:[/var/run/S2S-db]. Error:[File exists]
Feb 8 06:56:32 kernel: [ 82.366522] usbip_common_mod: module is from the staging directory, the quality is unknown, you have been warned.
Feb 8 06:56:32 kernel: [ 82.442181] usbip: module is from the staging directory, the quality is unknown, you have been warned.
Feb 8 06:56:34 synorcd: hw_raytac.c (222) failed to open /dev/usb/hiddev5 (No such device).
Feb 8 06:58:19 scemd: scemd.c:329 stop manutild.
Feb 8 11:59:53 scemd: modules/rtc.c:146 RTC and system time diff are too large. rtc_year:[111] rtc_mon:[1] rtc_mday:[8] rtc_hour:[11] sys_year:[111] sys_mon:[1] sys_mday:[8] sys_hour:[10] timezone:[-3600]
Feb 8 11:59:58 scemd: modules/rtc.c:146 RTC and system time diff are too large. rtc_year:[111] rtc_mon:[1] rtc_mday:[8] rtc_hour:[11] sys_year:[111] sys_mon:[1] sys_mday:[8] sys_hour:[10] timezone:[-3600]
Feb 8 11:59:58 scemd: modules/rtc.c:164 RTC looks like fine, maybe system error let it update
