Das ist der Output:
Mem: 234792K used, 14496K free, 0K shrd, 21088K buff, 114132K cached
CPU: 0.1% usr 0.5% sys 0.0% nic 97.4% idle 0.0% io 0.0% irq 1.7% sirq
Load average: 0.17 0.10 0.22 1/206 12404
PID PPID USER STAT VSZ %MEM %CPU COMMAND
29271 1 root S < 89056 35.6 0.4 /var/packages/SurveillanceStation/target/sbin/ssd -c 11
3498 1 root S 29656 11.8 0.2 scemd
12384 12378 root R 4348 1.7 0.2 top
5701 5253 http S 311m127.5 0.0 /usr/bin/httpd -DSSL -DSPDY -DHAVE_PHP
9334 1 root S N 166m 68.2 0.0 /var/packages/VideoStation/target/sbin/synovideoindexd
16798 5928 root S < 109m 44.9 0.0 /usr/bin/httpd -f /etc/httpd/conf/httpd.conf-sys
8680 1 root S 109m 44.6 0.0 /var/packages/MediaServer/target/sbin/dms
9101 1 root S < 83568 33.4 0.0 /var/packages/AudioStation/target/sbin/synoaudiod
9115 1 root S < 81712 32.6 0.0 /var/packages/AudioStation/target/bin/pulseaudio
9355 1 root S 66660 26.6 0.0 /var/packages/VideoStation/target/sbin/synovpcd
9531 1 root S 64164 25.6 0.0 /var/packages/SurveillanceStation/target/sbin/vsctrld
9503 1 root S 61136 24.4 0.0 /var/packages/SurveillanceStation/target/sbin/sscored
9346 1 root S N 40448 16.1 0.0 /var/packages/VideoStation/target/sbin/synovideometadatad
562 5112 postgres S 37400 14.9 0.0 postgres: postgres video_metadata [local] idle
561 5112 postgres S 37280 14.9 0.0 postgres: postgres mediaserver [local] idle
31514 5112 postgres S 36428 14.5 0.0 postgres: postgres mediaserver [local] idle
5336 5112 postgres S 36388 14.5 0.0 postgres: postgres synolog [local] idle
5126 5112 postgres S 35628 14.2 0.0 postgres: checkpointer process
5112 1 postgres S 35512 14.2 0.0 /usr/bin/postgres -D /var/services/pgsql
5127 5112 postgres S 35512 14.2 0.0 postgres: writer process
5128 5112 postgres S 35512 14.2 0.0 postgres: wal writer process
14558 5468 root S 30860 12.3 0.0 /usr/syno/sbin/smbd -F
9515 1 root S 30740 12.2 0.0 /var/packages/SurveillanceStation/target/sbin/ssrotated
9520 1 root S < 30716 12.2 0.0 /var/packages/SurveillanceStation/target/sbin/ssfindhostd
5124 5096 http S 29692 11.8 0.0 php-fpm: pool www
12221 5096 http S 29692 11.8 0.0 php-fpm: pool www
5123 5096 http S 29692 11.8 0.0 php-fpm: pool www
5096 1 root S 29420 11.7 0.0 php-fpm: master process (/etc/php/php-fpm.conf)
5468 1 root S 29200 11.6 0.0 /usr/syno/sbin/smbd -F
5499 5468 root S 29200 11.6 0.0 /usr/syno/sbin/smbd -F
30969 9314 root S N 27924 11.1 0.0 /usr/syno/sbin/synomediaparserd
5073 1 root S 24120 9.6 0.0 /usr/syno/bin/synobackupd
2782 1 root S 22932 9.1 0.0 /usr/syno/sbin/nmbd -D
31463 9314 root S N 22172 8.8 0.0 /usr/syno/sbin/synoindexplugind
5253 1 root S 21328 8.5 0.0 /usr/bin/httpd -DSSL -DSPDY -DHAVE_PHP
12363 23445 root S 21296 8.5 0.0 sshd: root@pts/0
8703 1 root S 21160 8.4 0.0 /var/packages/MediaServer/target/sbin/lighttpd -f /var/packages/MediaServer/target/etc/lighttpd.conf -m /var/packages/MediaServer/target/lib/lighttpd
5266 5253 http S 18628 7.4 0.0 /usr/bin/fcgi- -DSSL -DSPDY -DHAVE_PHP
5265 5253 http S 18628 7.4 0.0 /usr/bin/httpd -DSSL -DSPDY -DHAVE_PHP
4404 5928 root S < 17272 6.9 0.0 /usr/bin/httpd -f /etc/httpd/conf/httpd.conf-sys
5928 1 root S < 17272 6.9 0.0 /usr/bin/httpd -f /etc/httpd/conf/httpd.conf-sys
5222 1 root S 15952 6.3 0.0 /usr/syno/sbin/snmpd -Ln -c /usr/syno/etc/snmpd.conf -p /var/run/snmpd.pid udp:161,udp6:161,tcp:161,tcp6:161
5790 1 root S 14604 5.8 0.0 /usr/syno/sbin/synosnmpcd
5635 1 root S N 14040 5.6 0.0 /usr/syno/sbin/fileindexd
23445 1 root S 13712 5.4 0.0 /usr/syno/sbin/sshd
1916 1 root S 13364 5.3 0.0 /usr/syno/sbin/synologarchd -f
5114 1 root S 13268 5.3 0.0 /usr/syno/sbin/ftpd -DP
5459 1 root S 12872 5.1 0.0 /usr/syno/sbin/cupsd -C /usr/local/cups/cupsd.conf
478 1 root S 11672 4.6 0.0 /usr/sbin/syslog-ng -F
9330 1 root S N 11232 4.4 0.0 /usr/syno/sbin/synomkthumbd
9333 1 root S N 11232 4.4 0.0 /usr/syno/sbin/synomkflvd
10009 9314 root S N 11120 4.4 0.0 /usr/syno/sbin/synoindexscand
30958 9314 root S N 11116 4.4 0.0 /usr/syno/sbin/synoindexworkerd
9314 1 root S N 11108 4.4 0.0 /usr/syno/sbin/synoindexd
3222 1 root S < 10444 4.1 0.0 /usr/syno/bin/findhostd
5335 1 root S 10308 4.1 0.0 /usr/syno/sbin/synologd
5109 1 root S 10200 4.0 0.0 /usr/syno/sbin/hotplugd
2132 1 root S N 10060 4.0 0.0 /usr/syno/bin/synologrotated
9137 1 root S < 9980 3.9 0.0 /var/packages/AudioStation/target/sbin/synorcd
2765 1 root S 9912 3.9 0.0 /usr/sbin/ntpd -p /var/run/ntpd.pid -g
