Syno> 7z --help
7-Zip 4.58 beta Copyright (c) 1999-2008 Igor Pavlov 2008-05-05
p7zip Version 4.58 (locale=C,Utf16=off,HugeFiles=on,1 CPU)
Usage: 7z <command> [<switches>...] <archive_name> [<file_names>...]
[<@listfiles...>]
<Commands>
a: Add files to archive
b: Benchmark
d: Delete files from archive
e: Extract files from archive (without using directory names)
l: List contents of archive
t: Test integrity of archive
u: Update files to archive
x: eXtract files with full paths
<Switches>
-ai[r[-|0]]{@listfile|!wildcard}: Include archives
-ax[r[-|0]]{@listfile|!wildcard}: eXclude archives
-bd: Disable percentage indicator
-i[r[-|0]]{@listfile|!wildcard}: Include filenames
-m{Parameters}: set compression Method (see the manual)
-l: don't store symlinks; store the files/directories they point to
CAUTION : the scanning stage can never end because of symlinks like '..'
(ex: ln -s .. ldir)
-o{Directory}: set Output directory
-p{Password}: set Password
-r[-|0]: Recurse subdirectories
(CAUTION: this flag does not do what you think, avoid using it)
-sfx[{name}]: Create SFX archive
-si[{name}]: read data from stdin
-slt: show technical information for l (List) command
-so: write data to stdout (eg: 7z a dummy -tgzip -so Doc.txt > archive.gz)
-ssc[-]: set sensitive case mode
-t{Type}: Set type of archive
-v{Size}[b|k|m|g]: Create volumes
-u[-][p#][q#][r#][x#][y#][z#][!newArchiveName]: Update options
-w[path]: assign Work directory. Empty path means a temporary directory
-x[r[-|0]]]{@listfile|!wildcard}: eXclude filenames
-y: assume Yes on all queries
@Itari: Ich wollte (wie im ersten Post angegeben) 7z statt zip im Dateibrowser zum Packen zu verwenden. Also nicht auf der Kommandozeile, sondern Grafisch im Dateibrowser mit rechtsklick Packen ist derzeit nur ZIP möglich.
