Business ABfB neue Version 2.4.2-12341
Adama
05. März 2013
Grad mal wieder per Zufall entdeckt:
Version: 2.4.2-12341
(2022-09-14)
What's new
    Enhanced the usability of the SSL certificate that secures the connection between the agent and server.
Fixed Issues (General Issues)
    Fixed an issue where the version list could only display up to 50 versions when there were more versions.
    Fixed an issue where the Recovery Portal would time out when users browsed a large number of files.
    Fixed an issue where the Overview page couldn't display properly.
    Fixed an issue where the restoration of Windows 2008 R2 or Windows 7 physical servers to VMware might fail if the devices' disk sizes weren't 4K aligned and the backup tasks' encryption and compression features were enabled.
    Fixed an issue where backup files might be corrupted if the swap space or the pagefile.sys file was excluded from the backup.
    Fixed an issue where the system blocked the moving of non-Active Backup for Business backup destination shared folders to an ext4 volume.
    Fixed an issue where the backup of Linux devices with RAID volumes might fail.
Fixed Issues (Virtual Machines)
    Fixed an issue where users couldn't create backup tasks if they added the Hyper-V failover clusters via DDNS and the failover cluster had multiple IP addresses.
    Fixed an issue where the backup and restoration of an SCVMM failover cluster might fail if users added the failover cluster via the HTTPS protocol.
Anmerkungen:
    This version is released in a staged rollout.
Reaktionen: vater
Wird auf meiner 418play noch nicht angezeigt. Daher warte ich mal, bis mich das rollout erreicht. Wirklichen Handlungsbedarf habe ich ja nicht.
Reaktionen: vater
Wurde bei mir gestern über das Paket-Zentrum angeboten. Habe es installiert und keine Probleme bemerkt. Was mir aber aufgefallen ist: Die Agents werden nicht automatisch aktualisiert. Erst wenn man im AB4B Server den Client auswählt, sieht man, dass ein veralteter Agent installiert ist. Ein Klick auf "aktualisieren" klappt dann aber gut und schwupps sind die Clients aktuell.
