- Mitglied seit
- 05. Mrz 2013
- Punkte für Reaktionen
- 730
Es gibt eine neue Version von Active Backup for Business:
https://www.synology.com/de-de/releaseNote/ActiveBackup?model=DS918+#7_x_series
Ich vermute mal, dass die darunter auftauchende Version 2.6.1-13052 für DSM 7.1.1 ist. Soweit ich das überflogen hab, ist das dieselbe Historie.
Version: 2.6.1-23052
(2023-07-18)
Fixed Issues (General Issues)
Fixed an issue where incremental backups on Windows devices would slow down when the bandwidth consumption limit feature was enabled.
Fixed an issue where the backup agent would simultaneously back up additional disk volumes containing system data while backing up the system volume.
Fixed an issue where the backup tasks would not run on schedule due to daylight savings.
Fixed Issues (Mac)
Improved the error handling behavior of the backup agent to help prevent backup failures.
Fixed an issue where the backup agent would simultaneously back up additional disk volumes while backing up the local system volume.
Fixed Issues (Virtual Machines)
Fixed an issue where backups and restorations could not be performed when the hypervisor contained more than 1,000 virtual devices.
Fixed an issue where backup tasks with auto-discovery enabled could not be edited after deselecting virtual machines that were unavailable.
Fixed an issue where users were unable to browse more than two versions on the same device in the recovery portal when the virtual machine contained a Btrfs file system.
Fixed an issue where hypervisors could not be edited after certificate updates due to the inability to re-trust certificates.
Fixed an issue where users were limited to browsing only up to two virtual machines with LDM volumes in the recovery portal.
Fixed an issue where the backup server would repeatedly select the same virtual machine, resulting in the inability to create tasks.
Fixed Issues (File Servers)
Fixed an issue where file server backup tasks could not be canceled.
Fixed an issue where file server backup tasks might fail when the backup service timed out.
