Admin kein Zugriff auf FTP geben
Starofall
15. Dez 2008
Hallo ich hätte gerne das nur ein User "FTP" über FTP reinkommen kann, sodass selbst bei einem Hack nur der FTP-Root offen liegt.
Kann ich also Admin den Zugang verweigern?
jahlives
19. Aug 2008
Starofall
15. Dez 2008
danke ich hab nur grad das problem das ich mal mit x11 rumgetestet hab und jetzt wenn ich nano starten will folgendes problem hab
# nano
Error opening terminal: xterm.
hab ich da etwas vergessen wieder zu deinstallieren??
# ipkg list_installed
coreutils - 6.12-2 - Bunch of heavyweight *nix core utilities
expat - 2.0.1-1 - XML Parser library
faad2 - 2.6-2 - Freeware Advanced Audio Coder
fontconfig - 2.5.0-0 - Font configuration library
freetype - 2.3.6-1 - Free truetype library
gconv-modules - 2.3.3-1 - Provides gconv modules missing from the firmware. These are used by glibc iconv() implementation.
glib - 2.16.6-1 - The GLib library of C routines.
hdparm - 8.9-1 -
libmad - 0.15.1b-3 - MPEG Audio Decoder library
libogg - 1.1.3-3 - Ogg is a multimedia container format.
libstdc++ - 5.0.6-6 - Standard C++ library, needed for dynamically linked C++ programs
libvorbis - 1.1.2-5 - Ogg Vorbis compressed audio format.
libxml2 - 2.7.2-1 - Libxml2 is the XML C parser and toolkit developed for the Gnome project.
mysql - 4.1.22-2 - Popular free SQL database system
nano - 2.1.7-1 - A pico like editor
ncurses - 5.7-1 - NCurses libraries
nload - 0.7.2-1 - Nload is a console application which monitors network traffic and bandwidth usage in real time
openssl - 0.9.7m-5 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
streamripper - 1.63.5-1 -
tre - 0.7.5-1 - a lightweight, robust, efficient, portable, and POSIX compliant regexp matching library.
wget-ssl - 1.11.4-1 - A network utility to retrieve files from the Web
zlib - 1.2.3-3 - zlib is a library implementing the 'deflate' compression system.
Successfully terminated.
