Using cached pandas-1.2.4.tar.gz (5.5 MB)
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python3 /tmp/pip-standalone-pip-xojvbkjl/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-9eabj7c2/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i
https://pypi.org/simple -- setuptools wheel 'Cython>=0.29.21,<3' 'numpy==1.16.5; python_version=='"'"'3.7'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.16.5; python_version=='"'"'3.7'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy; python_version>='"'"'3.9'"'"''
cwd: None
Complete output (85 lines):
Ignoring numpy: markers 'python_version == "3.7" and platform_system != "AIX"' don't match your environment
Ignoring numpy: markers 'python_version == "3.7" and platform_system == "AIX"' don't match your environment
Ignoring numpy: markers 'python_version == "3.8" and platform_system == "AIX"' don't match your environment
Ignoring numpy: markers 'python_version >= "3.9"' don't match your environment
Collecting setuptools
Downloading setuptools-56.2.0-py3-none-any.whl (785 kB)
Collecting wheel
Using cached wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting Cython<3,>=0.29.21
Using cached Cython-0.29.23-py2.py3-none-any.whl (978 kB)
Collecting numpy==1.17.3
Using cached numpy-1.17.3.zip (6.4 MB)
Building wheels for collected packages: numpy
Building wheel for numpy (setup.py): started
Building wheel for numpy (setup.py): finished with status 'error'
command: /usr/local/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-_hvzogo_
cwd: /tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/
Complete output (14 lines):
Running from numpy source directory.
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py", line 443, in <module>
setup_package()
File "/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py", line 422, in setup_package
from numpy.distutils.core import setup
File "/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/numpy/distutils/core.py", line 26, in <module>
from numpy.distutils.command import config, config_compiler, \
File "/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/numpy/distutils/command/config.py", line 20, in <module>
from numpy.distutils.mingw32ccompiler import generate_manifest
File "/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/numpy/distutils/mingw32ccompiler.py", line 31, in <module>
import distutils.cygwinccompiler
ModuleNotFoundError: No module named 'distutils.cygwinccompiler'
ERROR: Failed building wheel for numpy
Running setup.py clean for numpy
command: /usr/local/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
Complete output (10 lines):
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
ERROR: Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: wheel, setuptools, numpy, Cython
Running setup.py install for numpy: started
Running setup.py install for numpy: finished with status 'error'
command: /usr/local/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-mv5yy7b4/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-9eabj7c2/overlay --compile --install-headers /tmp/pip-build-env-9eabj7c2/overlay/include/python3.8/numpy
Complete output (23 lines):
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install numpy` (last NumPy release on PyPi)
setup_package()
ERROR: Command errored out with exit status 1: /usr/local/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-1erwqsim/numpy_5267aae95a32443d904749fb0f3fa35c/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-mv5yy7b4/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-9eabj7c2/overlay --compile --install-headers /tmp/pip-build-env-9eabj7c2/overlay/include/python3.8/numpy Check the logs for full command output.
WARNING: Discarding
https://files.pythonhosted.org/pack...f967ff936496b0cfba0af00a55dfaacd82bdda5cb2279 (from
https://pypi.org/simple/pandas/) (requires-python:>=3.7.1). Command errored out with exit status 1: /usr/local/bin/python3 /tmp/pip-standalone-pip-xojvbkjl/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-9eabj7c2/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i
https://pypi.org/simple -- setuptools wheel 'Cython>=0.29.21,<3' 'numpy==1.16.5; python_version=='"'"'3.7'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.16.5; python_version=='"'"'3.7'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.17.3; python_version=='"'"'3.8'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy; python_version>='"'"'3.9'"'"'' Check the logs for full command output.
