Ich habe ein Problem mit meinen Apache2 Webserver, dieser startet nicht mehr .
Hier Poste hier einmal alle Sache die ich für wichtig halte, wenn ihr weitere Informationen braucht melde dich bitte.
systemctl status httpd.service
certbot --apache
journalctl -xe
apache2.conf
http://paste.debian.net/912886/
cat ports.conf | pastebinit
http://paste.debian.net/912887/
000-default-le-ssl.conf
http://paste.debian.net/912889/
apache2 -t
Wie gesagt, würde mich freuen, wenn euch was einfallen würde.
Ich sehe den Wald vor lauter Bäumen nicht mehr .
Lockslay
/etc/init.d/apache2 restart
[....] Restarting apache2 (via systemctl): apache2.serviceJob for apache2.service failed. See 'systemctl status apache2.service' and 'journalctl -xn' for details.
failed!
? httpd.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
certbot --apache
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError("Error while running apache2ctl configtest.\nAction 'configtest' failed.\nThe Apache error log may have more information.\n\napache2: Syntax error on line 312 of /etc/apache2/apache2.conf: Could not open configuration file /etc/apache2/sites-enabled/000-default-le-ssl.conf: No such file or directory\n",)
journalctl -xe
Feb 05 13:40:01 debianserver dhclient[700]: send_packet: Operation not permitted
Feb 05 13:40:01 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300
Feb 05 13:40:01 debianserver CRON[18302]: pam_unix(cron:session): session opened
Feb 05 13:40:01 debianserver CRON[18301]: pam_unix(cron:session): session opened
Feb 05 13:40:01 debianserver CRON[18303]: (www-data) CMD (php --define suhosin.m
Feb 05 13:40:01 debianserver CRON[18304]: (root) CMD (/usr/local/bin/denyiptable
Feb 05 13:40:01 debianserver CRON[18302]: pam_unix(cron:session): session closed
Feb 05 13:40:01 debianserver CRON[18301]: pam_unix(cron:session): session closed
Feb 05 13:40:07 debianserver dhclient[2115]: DHCPREQUEST on eth0 to 192.168.0.1
Feb 05 13:40:07 debianserver dhclient[2115]: send_packet: Operation not permitte
Feb 05 13:40:07 debianserver dhclient[2115]: dhclient.c:2243: Failed to send 300
Feb 05 13:40:17 debianserver dhclient[700]: DHCPREQUEST on eth0 to 192.168.0.1 p
Feb 05 13:40:17 debianserver dhclient[700]: send_packet: Operation not permitted
Feb 05 13:40:17 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300
Feb 05 13:40:26 debianserver dhclient[700]: DHCPREQUEST on eth0 to 192.168.0.1 p
Feb 05 13:40:26 debianserver dhclient[700]: send_packet: Operation not permitted
Feb 05 13:40:26 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300
Feb 05 13:40:27 debianserver dhclient[2115]: DHCPREQUEST on eth0 to 192.168.0.1
Feb 05 13:40:27 debianserver dhclient[2115]: send_packet: Operation not permitte
Feb 05 13:40:27 debianserver dhclient[2115]: dhclient.c:2243: Failed to send 300
Feb 05 13:40:37 debianserver dhclient[700]: DHCPREQUEST on eth0 to 192.168.0.1 p
Feb 05 13:40:37 debianserver dhclient[700]: send_packet: Operation not permitted
Feb 05 13:40:37 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300
lines 1011-1033/1033 (END)
Feb 05 13:40:01 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300 byte long packet over fallback interface.
Feb 05 13:40:01 debianserver CRON[18302]: pam_unix(cron:session): session opened for user root by (uid=0)
Feb 05 13:40:01 debianserver CRON[18301]: pam_unix(cron:session): session opened for user www-data by (uid=0)
Feb 05 13:40:01 debianserver CRON[18303]: (www-data) CMD (php --define suhosin.memory_limit=512M /usr/share/cacti/site/poller.php 2>&1 >/dev/null | if [ -f /usr/bin/ts ] ; then ts ; else tee ; fi >> /var/log/cac
Feb 05 13:40:01 debianserver CRON[18304]: (root) CMD (/usr/local/bin/denyiptables.sh)
Feb 05 13:40:01 debianserver CRON[18302]: pam_unix(cron:session): session closed for user root
Feb 05 13:40:01 debianserver CRON[18301]: pam_unix(cron:session): session closed for user www-data
Feb 05 13:40:07 debianserver dhclient[2115]: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Feb 05 13:40:07 debianserver dhclient[2115]: send_packet: Operation not permitted
Feb 05 13:40:07 debianserver dhclient[2115]: dhclient.c:2243: Failed to send 300 byte long packet over fallback interface.
Feb 05 13:40:17 debianserver dhclient[700]: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Feb 05 13:40:17 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300 byte long packet over fallback interface.
Feb 05 13:40:26 debianserver dhclient[700]: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Feb 05 13:40:26 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300 byte long packet over fallback interface.
Feb 05 13:40:27 debianserver dhclient[2115]: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Feb 05 13:40:27 debianserver dhclient[2115]: send_packet: Operation not permitted
Feb 05 13:40:27 debianserver dhclient[2115]: dhclient.c:2243: Failed to send 300 byte long packet over fallback interface.
Feb 05 13:40:37 debianserver dhclient[700]: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Feb 05 13:40:37 debianserver dhclient[700]: dhclient.c:2243: Failed to send 300 byte long packet over fallback interface.
apache2.conf
apache2 -t
[Sun Feb 05 13:54:26.854314 2017] [core:warn] [pid 31843] AH00111: Config variable ${APACHE_PID_FILE} is not defined
[Sun Feb 05 13:54:26.854716 2017] [core:warn] [pid 31843] AH00111: Config variable ${APACHE_RUN_USER} is not defined
[Sun Feb 05 13:54:26.854799 2017] [core:warn] [pid 31843] AH00111: Config variable ${APACHE_RUN_GROUP} is not defined
[Sun Feb 05 13:54:26.854986 2017] [core:warn] [pid 31843] AH00111: Config variable ${APACHE_LOG_DIR} is not defined
[Sun Feb 05 13:54:26.995108 2017] [core:warn] [pid 31843] AH00111: Config variable ${APACHE_LOCK_DIR} is not defined
[Sun Feb 05 13:54:26.998317 2017] [core:warn] [pid 31843] AH00111: Config variable ${APACHE_RUN_DIR} is not defined
/etc/apache2/sites-enabled# ls -la
insgesamt 12
drwxr-xr-x 3 root root 4096 Feb 4 21:40 .
drwxr-xr-x 10 root root 4096 Feb 4 21:21 ..
lrwxrwxrwx 1 root root 35 Apr 3 2015 000-default.conf -> ../sites-available/000-default.conf
lrwxrwxrwx 1 root root 52 Feb 4 19:31 000-default-le-ssl.conf -> /etc/apache2/sites-available/000-default-le-ssl.conf
drwxr-xr-x 14 root root 4096 Feb 4 21:42 letsencrypt
lrwxrwxrwx 1 root root 27 Apr 30 2014 owncloud -> ../sites-available/owncloud
lrwxrwxrwx 1 root root 22 Apr 30 2014 ssl -> ../sites-available/ssl
Lockslay
