Hyper Backup "Backing up ... Generating summary of backup version ..." für eine sehr lange Zeit.
ChrisN
25. Mai 2022
Hallo Zusammen,
ich habe zwei DS918+ mit der Version DSM 6.2.4-25556 Update 6.
Diese sollen sich gegenseitig via HyperBackup über das Internet sichern.
Allerdings bekomme ich von der einen folgende Fehlermeldung:
"Backing up ...
  • Als Aktion kann ich nur Abbrechen.
  • Alles andere ist ausgegraut
  • Ich sehe nicht, dass über das Netzwerk ein Datenaustausch stattfindet.
Hätte jemand eine Idee woran das liegen könnte? Das Log verrät mir auch nicht so viel mehr.
Gibt es noch weitere Infoquellen / Logs?
Ich würde mich über Tips und Ratschläge freuen.
Vielen Dank für eure Zeit.
Viele Grüße
Chris
Level,Time,User,Event
Warning,2022/07/28 03:00:03,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/27 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/26 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/25 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Information,2022/07/24 11:26:32,SYSTEM,[Network][myBackupTask] Backup integrity check is finished. No error was found.
Information,2022/07/24 05:30:23,SYSTEM,"[Network][myBackupTask] Data integrity check finished. 300.4 GB data checked this time, accounting for 15.3% of the total data (1959.0 GB data in total, 15.3% checked already)."
Information,2022/07/24 05:00:17,SYSTEM,[Network][myBackupTask] Backup integrity check has started.
Warning,2022/07/24 03:00:03,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/23 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/22 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/21 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/20 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/19 03:00:03,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/18 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Information,2022/07/17 11:04:52,SYSTEM,[Network][myBackupTask] Backup integrity check is finished. No error was found.
Information,2022/07/17 05:28:46,SYSTEM,"[Network][myBackupTask] Data integrity check finished. 240.6 GB data checked this time, accounting for 12.3% of the total data (1959.0 GB data in total, 100.0% checked already)."
Information,2022/07/17 05:00:17,SYSTEM,[Network][myBackupTask] Backup integrity check has started.
Warning,2022/07/17 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/16 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/15 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/14 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/13 03:00:03,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/12 03:00:03,SYSTEM, Scheduled backup had been skipped because that task was running backup
Warning,2022/07/11 03:00:02,SYSTEM, Scheduled backup had been skipped because that task was running backup
Information,2022/07/10 11:06:59,SYSTEM,[Network][myBackupTask] Backup integrity check is finished. No error was found.
Information,2022/07/10 05:31:06,SYSTEM,"[Network][myBackupTask] Data integrity check finished. 270.7 GB data checked this time, accounting for 13.8% of the total data (1959.0 GB data in total, 87.7% checked already)."
Information,2022/07/10 05:00:17,SYSTEM,[Network][myBackupTask] Backup integrity check has started.
Adama
05. Mrz 2013
Du findest in folgenden Logs Infos übers Backup:
HyperBackup in /var/log/synolog/synobackup.log
HyperBackup Vault in /var/log/synolog/synobackup_server.log
und zum Teil auch in /var/log/messages
ottosykora
17. Apr 2013
ich sehe nur es wird dauernd versucht ein Backup Task zu starten noch bevor der vorherige fertig ist.
Du musst zuerst mal den ersten Backup auch fertig laufen lassen und erst dann die täglichen starten. Der erste kann schon länger dauern und ist wie es aussieht nach 24h weit entfernt von beendet
