- Mitglied seit
- 05. Mrz 2013
- Punkte für Reaktionen
- 767
Ich hab grad gesehen, es gibt eine Beta für Active Backup for Business: 3.0.0-24557
Die könnte vor allen Dingen für die Apple Nutzer interessant sein: Added support for macOS Sequoia 15.
Siehe Release Notes:
https://www.synology.com/de-de/beta...Business_3_0_0_Beta/release_note#ActiveBackup
Compatibility and Installation
Active Backup for Business 3.0.0 and above requires DSM 7.2 or above.
Active Backup for Business 3.0.0 and above requires installing Container Manager.
The following models are not supported in Active Backup for Business 3.0.0 or above:
DS214play
DS216play
DS415play
DS416play
DS418play
Important Note
Daily backups previously scheduled to run every hour will change to hourly backups.
To back up a custom volume on Mac, you only need to specify the volume name instead of the entire path. However, if your device has multiple volumes with the same name, all of them will be backed up. Backups configured before the update will continue using the full path unless modified.
What's new
Added support for centralized management via ActiveProtect appliances. Learn about package features, requirements, and limitations here.
Updated OpenSSL to version 3.0.0 to enhance connection security. This update applies to personal computers, physical servers, file servers, and virtual machines.
Added support for throttling failure notifications when the server reaches its storage limit or encounters hypervisor connection issues, preventing excessive notifications.
Fixed Issues (General Issues)
Fixed an issue where reaching the storage limit might cause backups to freeze and prevent the status from updating.
Fixed a security vulnerability regarding SQL injection.
Fixed security vulnerabilities regarding heap-based and stack-based buffer overflows.
Fixed a security vulnerability regarding arbitrary access, creation, modification, and deletion of files.
Fixed Issues (Physical Server)
Fixed an issue where restoring to virtual machines might fail.
