Oct 7 08:14:15 kernel: [33105.850000] FAT: Directory bread(block 389972423) failed
Oct 7 08:14:15 kernel: [33105.850000] FAT: Directory bread(block 389972424) failed
Oct 7 08:14:15 kernel: [33105.880000] FAT: Directory bread(block 389972425) failed
Oct 7 08:14:15 kernel: [33105.880000] FAT: Directory bread(block 389972426) failed
Oct 7 08:14:15 kernel: [33105.910000] FAT: Directory bread(block 389972427) failed
Oct 7 08:14:15 kernel: [33105.910000] FAT: Directory bread(block 389972428) failed
Oct 7 08:14:15 kernel: [33105.940000] FAT: Directory bread(block 389972429) failed
Oct 7 08:14:15 kernel: [33105.940000] FAT: FAT read failed (blocknr 47734)
Oct 7 08:14:16 hotplugd: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdr] (errno = 6)
Oct 7 08:14:16 hotplugd: volume_parts_info_get_by_dev.c:304 failed to get disk '/dev/sdr' size
Oct 7 08:14:16 scemd: modules/usbcopy.c:57 USBCopy - Unknown Signal: 12
Oct 7 08:14:16 kernel: [33107.270000] drivers/scsi/sd.c (2308) Got USB disk
Oct 7 08:14:17 kernel: [33107.530000] sd 6:0:0:0: [sdq] Assuming drive cache: write through
Oct 7 08:14:17 kernel: [33107.590000] sd 6:0:0:0: [sdq] Assuming drive cache: write through
Oct 7 08:14:17 kernel: [33107.690000] sd 6:0:0:0: [sdq] Assuming drive cache: write through
Oct 7 08:14:18 hotplugd: usbbkp_hot_pull_out_ex.c:95 Failed to set alternative backup disk.
Oct 7 08:14:18 hotplugd: ##### ACTION:remove
Oct 7 08:14:18 hotplugd: DEVICE:/proc/bus/usb/001/006
Oct 7 08:14:18 hotplugd: DEVPATH:1-1.3:1.0
Oct 7 08:14:18 hotplugd: SUBSYSTEM:usb
Oct 7 08:14:18 hotplugd: INTERFACE:8/6/80
Oct 7 08:14:20 hotplugd: ##### ACTION:add
Oct 7 08:14:20 hotplugd: DEVICE:/proc/bus/usb/001/007
Oct 7 08:14:20 hotplugd: DEVPATH:1-1.3
Oct 7 08:14:20 hotplugd: SUBSYSTEM:usb
Oct 7 08:14:20 hotplugd: DEVPATH:1-1.3:1.0
Oct 7 08:14:20 hotplugd: INTERFACE:8/6/80
Oct 7 08:14:20 hotplugd: DEVNAME:sdq
Oct 7 08:14:20 hotplugd: DEVGUID
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
CA5782677FF0
Oct 7 08:14:20 hotplugd: DEVPATH:sdq
Oct 7 08:14:20 hotplugd: SUBSYSTEM:block
Oct 7 08:14:20 hotplugd: PHYSDEVPATH:/devices/platform/orion-ehci.0/usb1/1-1/1-1.3/1-1.3:1.0/host6/target6:0:0/6:0:0:0
Oct 7 08:14:20 hotplugd: hotplugd.c:757 ##### complete device hotplug!!
Oct 7 08:14:20 hotplugd: hotplugd.c (1357) ==== USB disk [sdq] plugged in ====
Oct 7 08:14:20 hotplugd: hotplugd.c:1358 goto USB disk, szDeviceName=sdq
Oct 7 08:14:20 hotplugd: hotplugd.c:1360 ret=-1, fsType=0
Oct 7 08:14:20 scemd: modules/usbcopy.c:57 USBCopy - Unknown Signal: 12
Oct 7 08:14:21 kernel: [33111.420000] FAT: nls_disk load default table
Oct 7 08:14:21 kernel: [33111.420000] FAT: nls_io load default table
Oct 7 08:14:21 kernel: [33112.270000] FAT: nls_disk load default table
Oct 7 08:14:21 kernel: [33112.290000] FAT: nls_io load default table>
