Hi zusammen, hat einer von Euch das Thema mal probiert? Habe das IPKG installiert und den Client gestartet. Die Ausgabe sieht wie folt aus:
DSMain> tor
Nov 07 22:59:02.202 [notice] Tor v0.2.2.32 (git-877e17749725ab88). This is experimental software. Do not rely on it for strong anonymity. (Running on Linux armv5tel)
Nov 07 22:59:02.215 [notice] Configuration file "/opt/etc/tor/torrc" not present, using reasonable defaults.
Nov 07 22:59:02.220 [notice] Initialized libevent version 2.0.11-stable using method epoll. Good.
Nov 07 22:59:02.220 [notice] Opening Socks listener on 127.0.0.1:9050
Nov 07 22:59:02.238 [notice] Parsing GEOIP file /opt/share/tor/geoip.
Nov 07 22:59:05.236 [warn] You are running Tor as root. You don't need to, and you probably shouldn't.
Nov 07 22:59:07.280 [notice] OpenSSL OpenSSL 0.9.8p 16 Nov 2010 looks like version 0.9.8m or later; I will try SSL_OP to enable renegotiation
Nov 07 22:59:10.439 [warn] Please upgrade! This version of Tor (0.2.2.32) is not recommended, according to the directory authorities. Recommended versions are: 0.2.1.31,0.2.2.34,0.2.3.6-alpha,0.2.3.7-alpha
Nov 07 22:59:14.110 [notice] We now have enough directory information to build circuits.
Nov 07 22:59:14.110 [notice] Bootstrapped 80%: Connecting to the Tor network.
Nov 07 22:59:15.270 [notice] Bootstrapped 85%: Finishing handshake with first hop.
Nov 07 22:59:16.188 [notice] Bootstrapped 90%: Establishing a Tor circuit.
Nov 07 22:59:18.905 [notice] Tor has successfully opened a circuit. Looks like client functionality is working.
Nov 07 22:59:18.905 [notice] Bootstrapped 100%: Done.
Anscheinend läuft der Client, allerdings kommt er aus dem Status nicht mehr raus ( ich kann effektiv keine weiteren Befehle über ssh ausführen solange ich den Prozess mit Strg + C abbreche).
Jetzt aber meine eigentliche Hauptfrage: gibt es eine Möglichkeit zu überprüfen welche IP meine DS jetzt nach außen hin verwendet (z.B. für die Downloadstation)?
Gruß Zerro
