# synOCR_YAMLRULEFILE # please keep this line
# IT IS VERY IMPORTANT TO READ THIS MANUAL #
# - it is very necessary to include the correct indentations #
# • don't use tapstops! #
# • only use the exact count of spaces as shown in the example #
# - Tip: copy & paste the sample block and then modify this #
# - don't use Windows line breaks! #
# - below a description of the keywords: #
# ? "sampletagrulename" #
# • "sampletagrulename" is a placeholder for an individual name #
# • just to distinguish the rule #
# • the name must be unique #
# • a colon must be added at the end #
# • each block like "sampletagrulename" defines ONE tag #
# and ONE action (move), if defined #
# ? "tagname:" #
# • syntax: ???tagname: VALUE???? (one space between colon & VALUE) #
# • VALUE is used as tag, if the rule is satisfied #
# • one keyword >tagname:< per rule #
# ? "targetfolder:" #
# • optional / if not defined, the target folder is used #
# • syntax: >targetfolder: VALUE< (one space between colon & VALUE) #
# • VALUE is path, if the rule is satisfied #
# • it can be an absolute path (/volume1/…) #
# • if it is not an absolute path, it will be created #
# relative to the destination folder #
# • one keyword >targetfolder:< per rule #
# ? "condition:" #
# • syntax: >condition: VALUE< (one space between colon & VALUE) #
# • VALUE is "all" or "any" or "none" #
# ? "condition: all" ? all rules must be satisfied #
# ? "condition: any" ? any rule must be satisfied #
# ? "condition: none" ? no rule is satisfied #
# • one keyword >condition:< per rule #
# ? "tagname_RegEx:" (optional) #
# • syntax: >tagname_RegEx: RegEx< (one space between colon & RegEx) #
# ? "subrules:" #
# • after this, the searchrules are described (don't modify "subrules:") #
# • a subrule block always consists of the following four keys #
# • an unlimited number of subrule blocks can be combined #
# ? "searchstring:" #
# • syntax: >- searchstring: VALUE< #
# begins with a hyphen and a space #
# one space between colon & VALUE #
# • VALUE is a string, keyword or RegEx #
# ? "searchtyp:" #
# • syntax: >searchtyp: VALUE< (one space between colon & VALUE) #
# • VALUE can be: "contains", "does not contain", # irgendwo enthalten
# "is", "is not" # Wortfolge
# "starts with", "does not starts with", #
# "ends with", "does not ends with", #
# ? "isRegEx:" #
# • defines "searchstring" as text or RegEx #
# • syntax: >isRegEx: VALUE< (one space between colon & VALUE) #
# • VALUE can be: "true" or "false" #
# ? "source:" #
# • syntax: >source: VALUE< (one space between colon & VALUE) #
# • VALUE can be: "content" or "filename" #
# ? "casesensitive:" #
# • syntax: >casesensitive: VALUE< (one space between colon & VALUE) #
# • if the parameter is missing, "false" is used. #
# - finaly, you can check and validate your config file on: #
# https://codebeautify.org/yaml-validator #
regextest_01:
tagname: "ForumTest"
targetfolder: ""
# wieviel Subrules müssen erfüllt sein, damit die Regel greift:
condition: any
tagname_RegEx: "HUK[[:digit:]]{2}"
subrules:
- searchstring: Suchwort
searchtyp: contains
isRegEx: false
#is | is not | contains | does not contain | starts with | does not starts with | ends with | does not ends with | matches | does not match
source: content
casesensitive: true
