sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:08:50 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:09:01 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:09:11 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:09:21 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:09:27 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:09:37 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 25 23:09:47 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:32:11 kernel: raid6: int32x1 29 MB/s
Aug 26 21:32:11 kernel: raid6: int32x2 45 MB/s
Aug 26 21:32:11 kernel: raid6: int32x4 52 MB/s
Aug 26 21:32:11 kernel: raid6: int32x8 48 MB/s
Aug 26 21:32:11 kernel: raid6: using algorithm int32x4 (52 MB/s)
Aug 26 21:32:11 kernel: arm4regs : 429.200 MB/sec
Aug 26 21:32:11 kernel: 8regs : 369.200 MB/sec
Aug 26 21:32:11 kernel: 32regs : 513.600 MB/sec
Aug 26 21:32:11 kernel: raid5: using function: 32regs (513.600 MB/sec)
Aug 26 21:32:11 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Aug 26 21:32:11 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Aug 26 21:32:11 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Aug 26 21:32:11 kernel: VFS: Mounted root (ext2 filesystem).
Aug 26 21:32:11 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
Aug 26 21:32:11 kernel: Brand: Synology
Aug 26 21:32:11 kernel: Model: DS-107+
Aug 26 21:32:11 kernel: synobios: unload
Aug 26 21:32:11 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Aug 26 21:32:11 kernel: VFS: Mounted root (ext3 filesystem).
Aug 26 21:32:12 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Aug 26 21:33:03 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Aug 26 21:33:09 scemd: scemd.c:97 fan_type=5, led_type=2, raid_type=2, dual_power_type=1, auto_poweron_type=1
Aug 26 21:33:09 scemd: modules/disk_hibernation.c:86 Force hibernation enable, idle minutes 0
Aug 26 21:33:09 synoprint: printer_device_open.c:16 bad parameter.
Aug 26 21:33:09 synousbdisk: RCClean succeeded
Aug 26 21:33:13 synocheckshare: service_user_home.c:276 SYNOShareRSectionRemove failed. synoerr=[0x2000]
Aug 26 21:33:13 ddnsd: main(ddnsd.c:1729): not enable DDNS, shutdown daemon
Aug 26 21:33:18 kernel: Got empty serial number. Generate serial number from product.
Aug 26 21:33:20 syno_hdd_util: Model:[WDC WD10EACS-00Z], Firmware:[01.01B01], S/N:[WD-WCASJ1949563] in [/dev/sda] is not ssd
Aug 26 21:33:32 synorcd: hw_raytac.c (126) failed to open /dev/usb/hiddev5 (No such device).
Aug 26 21:34:10 afpd[2347]: DiskStation:AFPServer@* started on 65280.63:128 (2.0.1)
Aug 26 21:34:41 logman.cgi: Synology log file /var/log/synobackup.log not exist
Aug 26 21:34:41 logman.cgi: logman.cpp:74: Failed to get log
Aug 26 21:38:36 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:38:42 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:38:48 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:38:53 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:38:59 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:04 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:09 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:15 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:20 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:26 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:31 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:36 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:42 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:52 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:39:57 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:02 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:08 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:13 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:18 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:29 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:34 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:39 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:45 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:50 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:40:55 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:01 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:06 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:11 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:19 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:24 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:30 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:35 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:40 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:46 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:41:56 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:42:01 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:42:12 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:42:18 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:42:23 status.cgi: external_hw_sys_temp_degree.c:28(SYNOHWSysTempDegree) Failed to ioctl(), [2(No such file or directory)]
Aug 26 21:50:24 sshd[2555]: error: subsystem: cannot stat /usr/libexec/sftp-server: No such file or directory
Aug 26 21:52:50 sshd[2615]: error: subsystem: cannot stat /usr/libexec/sftp-server: No such file or directory
Aug 26 22:25:17 sshd[2738]: error: subsystem: cannot stat /usr/libexec/sftp-server: No such file or directory
Aug 26 22:40:07 kernel: DEVICE_CS2 ....base fa800000, size 1MB
Aug 26 22:40:07 kernel: DEV_BOOCS ....base ffc00000, size 4MB
