[42432.780000] As the driver is backported to an older kernel, it doesn't offer
[42432.780000] enough quality for its usage in production.
[42432.780000] Use it with care.
[42432.780000] Latest git patches (needed if you report a bug to linux-media@vge r.kernel.org):
[42432.780000] d92462401dde1effa04a51d0a15000e6246d2a43 [media] v4l2-ioctl: fix W=1 warnings
[42432.780000] 1b8b10cc7e6bd9bf017c58e32b1e7f632e23850d [media] v4l2-ioctl: add blocks check for VIDIOC_SUBDEV_G/S_EDID
[42432.780000] 8a18382c3196978164f0f6290aac98f2f6f43c00 [media] omap3isp: Fix c ompilation error in ispreg.h
[42433.060000] WARNING: You are using an experimental version of the media stack .
[42433.060000] As the driver is backported to an older kernel, it doesn't offer
[42433.060000] enough quality for its usage in production.
[42433.060000] Use it with care.
[42433.060000] Latest git patches (needed if you report a bug to linux-media@vge r.kernel.org):
[42433.060000] d92462401dde1effa04a51d0a15000e6246d2a43 [media] v4l2-ioctl: fix W=1 warnings
[42433.060000] 1b8b10cc7e6bd9bf017c58e32b1e7f632e23850d [media] v4l2-ioctl: add blocks check for VIDIOC_SUBDEV_G/S_EDID
[42433.060000] 8a18382c3196978164f0f6290aac98f2f6f43c00 [media] omap3isp: Fix c ompilation error in ispreg.h
[42433.150000] WARNING: You are using an experimental version of the media stack .
[42433.150000] As the driver is backported to an older kernel, it doesn't offer
[42433.150000] enough quality for its usage in production.
[42433.150000] Use it with care.
[42433.150000] Latest git patches (needed if you report a bug to linux-media@vge r.kernel.org):
[42433.150000] d92462401dde1effa04a51d0a15000e6246d2a43 [media] v4l2-ioctl: fix W=1 warnings
[42433.150000] 1b8b10cc7e6bd9bf017c58e32b1e7f632e23850d [media] v4l2-ioctl: add blocks check for VIDIOC_SUBDEV_G/S_EDID
[42433.150000] 8a18382c3196978164f0f6290aac98f2f6f43c00 [media] omap3isp: Fix c ompilation error in ispreg.h
[42433.910000] usbcore: registered new interface driver em28xx
[42434.010000] Em28xx: Initialized (Em28xx dvb Extension) extension
[42434.380000] usbcore: registered new interface driver dvb_usb_ttusb2
[42434.960000] usbcore: registered new interface driver dvb_usb_dib0700
[42435.360000] au0828 driver loaded
[42435.380000] usbcore: registered new interface driver au0828
[42435.520000] usbcore: registered new interface driver dw2102
[42435.920000] usbcore: registered new interface driver pctv452e
[42436.070000] usbcore: registered new interface driver tbsqbox2ci
[42436.270000] usbcore: registered new interface driver tbsdvbc
[42436.350000] usbcore: registered new interface driver tbs5680
[42436.500000] usbcore: registered new interface driver tbsqbox22
[44142.500000] usb 2-4: new high speed USB device using xhci_hcd and address 3
[44142.530000] usb 2-4: configuration #1 chosen from 1 choice
[45717.650000] usb 2-4: USB disconnect, address 3
[54984.770000] usb 2-4: new high speed USB device using xhci_hcd and address 4
[54984.790000] usb 2-4: configuration #1 chosen from 1 choice
[55767.410000] usb 2-4: USB disconnect, address 4
[55897.970000] hub 2-0:1.0: over-current change on port 4
[55898.090000] hub 2-0:1.0: over-current change on port 2
[55898.200000] hub 2-0:1.0: over-current change on port 4
[55898.310000] hub 2-0:1.0: over-current change on port 2
[55898.420000] hub 2-0:1.0: over-current change on port 4
[55898.530000] hub 2-0:1.0: over-current change on port 2
[55898.640000] hub 2-0:1.0: over-current change on port 4
[55898.750000] hub 2-0:1.0: over-current change on port 2
[55898.860000] hub 2-0:1.0: over-current change on port 4
[55898.970000] hub 2-0:1.0: over-current change on port 2
[55899.080000] hub 2-0:1.0: over-current change on port 4
[55899.190000] hub 2-0:1.0: over-current change on port 2
[55899.300000] hub 2-0:1.0: over-current change on port 4
[55899.410000] hub 2-0:1.0: over-current change on port 2
[55899.520000] hub 2-0:1.0: over-current change on port 4
[55899.630000] hub 2-0:1.0: over-current change on port 2
[55899.740000] hub 2-0:1.0: over-current change on port 4
[55899.850000] hub 2-0:1.0: over-current change on port 2
[55899.960000] hub 2-0:1.0: over-current change on port 4
[55909.630000] usb 2-4: new high speed USB device using xhci_hcd and address 5
[55909.650000] usb 2-4: configuration #1 chosen from 1 choice
