nach Ewigkeiten melde ich mich mal wieder im Forum zurück. Meine DS207+ macht mir zur Zeit ein paar Sorgen. Das Booten dauert sehr lange (teilweise 10min).
Hier die /var/log/messages:
Vielleicht könnt ihr mir helfen =/
Lg
Apr 29 21:10:42 kernel: CPU0: D VIVT write-back cache
Apr 29 21:10:42 kernel: CPU0: I cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets
Apr 29 21:10:42 kernel: CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Apr 29 21:10:42 kernel: Built 1 zonelists
Apr 29 21:10:42 kernel: PID hash table entries: 1024 (order: 10, 16384 bytes)
Apr 29 21:10:42 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Apr 29 21:10:42 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Apr 29 21:10:42 kernel: Mount-cache hash table entries: 512
Apr 29 21:10:42 kernel: CPU Interface
Apr 29 21:10:42 kernel: -------------
Apr 29 21:10:42 kernel: SDRAM_CS0 ....base 00000000, size 128MB
Apr 29 21:10:42 kernel: SDRAM_CS1 ....disable
Apr 29 21:10:42 kernel: SDRAM_CS2 ....disable
Apr 29 21:10:42 kernel: SDRAM_CS3 ....disable
Apr 29 21:10:42 kernel: PEX0_MEM ....base e0000000, size 128MB
Apr 29 21:10:42 kernel: PEX0_IO ....base f2000000, size 1MB
Apr 29 21:10:42 kernel: PCI0_MEM ....base e8000000, size 128MB
Apr 29 21:10:42 kernel: PCI0_IO ....base f2100000, size 1MB
Apr 29 21:10:42 kernel: INTER_REGS ....base f1000000, size 1MB
Apr 29 21:10:42 kernel: DEVICE_CS0 ....base fa000000, size 2MB
Apr 29 21:10:42 kernel: DEVICE_CS1 ....base f8000000, size 32MB
Apr 29 21:10:42 kernel: DEVICE_CS2 ....base fa800000, size 1MB
Apr 29 21:10:42 kernel: DEV_BOOCS ....base ffc00000, size 4MB
Apr 29 21:10:42 kernel: Marvell USB EHCI Host controller #0: c0bf5c00
Apr 29 21:10:42 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Apr 29 21:10:42 kernel: RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Apr 29 21:10:42 kernel: Marvell Gigabit Ethernet Driver 'egiga':
Apr 29 21:10:42 kernel: o Ethernet descriptors in DRAM
Apr 29 21:10:42 kernel: o DRAM SW cache-coherency
Apr 29 21:10:42 kernel: o Checksum offload enabled
Apr 29 21:10:42 kernel: o Loading network interface 'egiga0' as eth0
Apr 29 21:10:42 kernel: o Radom MAC address ********
Apr 29 21:10:42 kernel: PCI: enabling device 0000:00:01.0 (0140 -> 0143)
Apr 29 21:10:42 kernel: Delay 10 seconds to wait for disk 0 ready.
Apr 29 21:10:42 kernel: Delay 10 seconds to wait for disk 1 ready.
Apr 29 21:10:42 kernel: drivers/scsi/sd.c (1718) Internal disk with bus id: 0
Apr 29 21:10:42 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Apr 29 21:10:42 kernel: for broken CFI table.
Apr 29 21:10:42 kernel: Mac1: ********
Apr 29 21:10:42 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
Apr 29 21:10:42 kernel: Vender partition MacNum:1 retlen:128
Apr 29 21:10:42 kernel: Serial Number: 88E1N00627
Apr 29 21:10:42 kernel: raid6: int32x1 29 MB/s
Apr 29 21:10:42 kernel: raid6: int32x2 45 MB/s
Apr 29 21:10:42 kernel: raid6: int32x4 52 MB/s
Apr 29 21:10:42 kernel: raid6: int32x8 48 MB/s
Apr 29 21:10:42 kernel: raid6: using algorithm int32x4 (52 MB/s)
Apr 29 21:10:42 kernel: arm4regs : 429.200 MB/sec
Apr 29 21:10:42 kernel: 8regs : 368.800 MB/sec
Apr 29 21:10:42 kernel: 32regs : 513.200 MB/sec
Apr 29 21:10:42 kernel: raid5: using function: 32regs (513.200 MB/sec)
Apr 29 21:10:42 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Apr 29 21:10:42 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Apr 29 21:10:42 kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Apr 29 21:10:42 kernel: md: sda2 has different UUID to sda1
Apr 29 21:10:42 kernel: VFS: Mounted root (ext2 filesystem).
Apr 29 21:10:42 kernel: ds107+_synobios: module license 'Synology Inc.' taints kernel.
Apr 29 21:10:42 kernel: Brand: Synology
Apr 29 21:10:42 kernel: Model: DS-207+
Apr 29 21:10:42 kernel: synobios: unload
Apr 29 21:10:42 kernel: VFS: Mounted root (ext3 filesystem).
Apr 29 21:10:42 kernel: fuse init (API version 7.8)
Apr 29 21:10:42 kernel: fuse distribution version: 2.7.4
Apr 29 21:10:53 scemd: scemd.c:114 fan_type=2, raid_type=1, led_type=1, thermal_type=1, fanctrl_type=1, auto_poweron_type=2, dual_power_type=1, usbcopy_type=1, fan_number=1, ebox_type=1, pis_type=1, rtc_type=1
Apr 29 21:10:53 scemd: modules/raid_sys_volume_check.c:160 MD0 active disks 1, designed disks 2
Apr 29 21:10:53 scemd: modules/raid_sys_volume_check.c:160 MD1 active disks 1, designed disks 2
Apr 29 21:10:53 scemd: modules/disk_hibernation.c:90 Force hibernation enable, idle minutes 20
Apr 29 21:10:54 synoprint: printer_device_open.c:16 bad parameter.
Apr 29 21:10:54 synousbdisk: RCClean succeeded
Apr 29 21:11:00 ddnsd: ddnsd.c:1107 First update query: ********
Apr 29 21:11:02 kernel: Got empty serial number. Generate serial number from product.
Apr 29 21:11:14 syno_hdd_util: Model:[ST3500630NS], Firmware:[3.AEK], S/N:[********] in [/dev/sda] is not ssd
Apr 29 21:11:30 synorcd: hw_raytac.c (126) failed to open /dev/usb/hiddev5 (No such device).
Apr 29 21:12:08 afpd[6515]: ********:AFPServer@* started on 65280.148:128 (2.0.1)
Apr 29 21:13:01 scemd: scemd.c:235 stop manutild.
Lg
