todo
Hallo Matthieu,
ich brauche jetzt doch wieder deine Hilfe!
1) 15:14 DS runtergefahren
2) 15:28 DS eingeschaltet
Power: blau blinken
3) 15:32 Strom weg.
4) Strom wieder dran - DS wieder eingeschalten -> fährt hoch !
6)Telnet -> DS --> /var/log/messages
DS-01> more /var/log/messages
Oct 25 15:14:07 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Oct 25 15:33:26 kernel: Synology Hardware Version: DS209pII-j
Oct 25 15:33:26 kernel: Internal HD num: 2
Oct 25 15:33:26 kernel: Internal netif num: 1
Oct 25 15:33:26 kernel: Found initrd at 0xbfeb8000:0xbff8cec0
Oct 25 15:33:26 kernel: MPC85xx DS board from Freescale Semiconductor
Oct 25 15:33:26 kernel: Zone PFN ranges:
Oct 25 15:33:26 kernel: DMA 0 -> 131072
Oct 25 15:33:26 kernel: Normal 131072 -> 131072
Oct 25 15:33:26 kernel: Movable zone start PFN for each node
Oct 25 15:33:26 kernel: early_node_map[1] active PFN ranges
Oct 25 15:33:26 kernel: 0: 0 -> 131072
Oct 25 15:33:26 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Oct 25 15:33:26 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Oct 25 15:33:26 kernel: Mount-cache hash table entries: 512
Oct 25 15:33:26 kernel: PCI: 0001:01:00.0: class b20 doesn't match header type 01. Ignoring class.
Oct 25 15:33:26 kernel: PCI: 0002:03:00.0: class b20 doesn't match header type 01. Ignoring class.
Oct 25 15:33:26 kernel: Freeing initrd memory: 851k freed
Oct 25 15:33:26 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Oct 25 15:33:26 kernel: RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Oct 25 15:33:26 kernel: patch with: gianfar: Fix skb allocation strategy
Oct 25 15:33:26 kernel: Driver 'sd' needs updating - please use bus_type methods
Oct 25 15:33:26 kernel: Delay 10 seconds to wait for disk 1 ready.
Oct 25 15:33:26 kernel: Delay 10 seconds to wait for disk 2 ready.
Oct 25 15:33:26 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Oct 25 15:33:26 kernel: SYNOMTD-0: Swapping erase regions for broken CFI table.
Oct 25 15:33:26 kernel: vender Mac1 checksum error ucSum:0x8e Buf:0x00 Sum:142.
Oct 25 15:33:26 kernel: Random MAC address 00:aa:b0:14:46:d8
Oct 25 15:33:26 kernel: Serial Number: 98G3Nxxxxxx
Oct 25 15:33:26 kernel: raid6: int32x1 164 MB/s
Oct 25 15:33:26 kernel: raid6: int32x2 285 MB/s
Oct 25 15:33:26 kernel: raid6: int32x4 375 MB/s
Oct 25 15:33:26 kernel: raid6: int32x8 300 MB/s
Oct 25 15:33:26 kernel: raid6: using algorithm int32x4 (375 MB/s)
Oct 25 15:33:26 kernel: md: sda2 has different UUID to sda1
Oct 25 15:33:26 kernel: md: sda3 has different UUID to sda1
Oct 25 15:33:26 kernel: md: md0: set sda1 to auto_remap [0]
Oct 25 15:33:26 kernel: md: sda3 has different UUID to sda2
Oct 25 15:33:26 kernel: to_remap [0]
Oct 25 15:33:26 kernel: md: md2: set sda3 to auto_remap [0]
Oct 25 15:33:26 kernel: EXT4-fs warning (device ram0): ext4_fill_super: extents feature not enabled on this filesystem, use tune2fs.
Oct 25 15:33:26 kernel: VFS: Mounted root (ext2 filesystem).
Oct 25 15:33:26 kernel: ds508_synobios: module license 'Synology Inc.' taints kernel.
Oct 25 15:33:26 kernel: Brand: Synology
Oct 25 15:33:26 kernel: Model: Unknown
Oct 25 15:33:26 kernel: synobios: unload
Oct 25 15:33:26 kernel: VFS: Mounted root (ext3 filesystem).
Oct 25 15:33:26 kernel: Freeing unused kernel memory: 156k init
Oct 25 15:33:26 kernel: fuse init (API version 7.9)
Oct 25 15:33:26 kernel: PCI: Enabling device 0000:00:0f.0 (0006 -> 0007)
Oct 25 15:33:26 kernel: sk98lin: Network Device Driver v10.22.3.1 (alpha)
Oct 25 15:33:26 kernel: (C)Copyright 1999-2007 Marvell(R).
Oct 25 15:33:26 kernel: eth0: Yukon Gigabit Ethernet 10/100/1000Base-T Adapter
Oct 25 15:33:26 kernel: PrefPort:A RlmtMode:Check Link State
Oct 25 15:33:26 kernel: eth0: network connection up using port A
Oct 25 15:33:26 kernel: speed: 100
Oct 25 15:33:26 kernel: autonegotiation: yes
Oct 25 15:33:26 kernel: duplex mode: full
Oct 25 15:33:26 kernel: flowctrl: symmetric
Oct 25 15:33:26 kernel: irq moderation: disabled
Oct 25 15:33:26 kernel: scatter-gather: enabled
Oct 25 15:33:26 kernel: tx-checksum: enabled
Oct 25 15:33:26 kernel: rx-checksum: enabled
Oct 25 15:33:33 scemd: scemd.c:113 fan_type=6, raid_type=1, led_type=1, thermal_type=1, fanctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, ebox_type=0, pis_type=1
Oct 25 15:33:33 scemd: modules/fan_speed_adjust_common.c:110 Fan Mode: HIGH (suitable for 3.5'' HD)
Oct 25 15:33:33 scemd: modules/raid_sys_volume_check.c:160 MD0 active disks 1, designed disks 2
Oct 25 15:33:33 scemd: modules/raid_sys_volume_check.c:160 MD1 active disks 1, designed disks 2
Oct 25 15:33:33 scemd: modules/disk_hibernation.c:86 Force hibernation enable, idle minutes 20
Oct 25 15:33:34 synoprint: printer_device_open.c:16 bad parameter.
Oct 25 15:33:34 synousbdisk: RCClean succeeded
Oct 25 15:33:35 synocheckshare: service_user_home.c:281 SYNOShareRSectionRemove failed. synoerr=[0x2000]
Oct 25 15:33:35 synocheckiscsitrg: iscsitrg_conf_restore.c:56 Failed to opendir /volume1/@iSCSITrg, errno=No such file or directory
Oct 25 15:33:35 ddnsd: main(ddnsd.c:1772): not enable DDNS, shutdown daemon
Oct 25 15:33:42 syno_hdd_util: Model:[SAMSUNG HD103UJ], Firmware:[1AA01118], S/N:[S13PJ1LS621xxx] in [/dev/sda] is not ssd
Oct 25 15:33:50 scemd: ScemRefreshDiskLed(439)Disk 2 not exist
