DS211j Volumen erstellen Fehler: failed to create space
gumi
24. Apr 2011
bin zeit heute Besitzer des DS211j, Installation von DSM 3.1 incl. Update war kein Problem. Jetzt wollte ich ein Volumen erstellen, klappt aber nicht.
Die Platte ist eine WD6400AAVS-00G9B.
Habe versucht das Volumen über die Schnell und Benutzerdef. zu erstellen,
beides hat nicht geklappt.
Log Datei ist angefügt.
Bin für jeden Tip dankbar.
Gruß Mirco
Apr 29 16:12:11 afpd[3576]: [afp_config.c:318] DiskStation:AFPServer@* started on 65280.119:128 (2.0.1)
Apr 29 16:12:48 volumehandler.cgi: space_disk_data_partition_clean.c:44 [Info] Clean data partition on /de
Apr 29 16:12:49 volumehandler.cgi: space_disk_data_partition_create.c:78 [Info] Create multiple logical pa
Apr 29 16:12:49 volumehandler.cgi: partition_logical_create.c:58 partition layout: 7
Apr 29 16:12:49 volumehandler.cgi: partition_table_type_get.c:52 pTable 2
Apr 29 16:12:49 volumehandler.cgi: partition_logical_create.c:94 Failed to [/sbin/sfdisk -N3 -E -uS -q -f
Apr 29 16:12:49 volumehandler.cgi: space_disk_data_partition_create.c:81 Failed to create multiple logical
Apr 29 16:12:49 volumehandler.cgi: space_create.c:674 [Info] Create RAID: /dev/md2, RAID level: 2, device
Apr 29 16:12:49 volumehandler.cgi: raid_create.c:124 Failed to do '/sbin/mdadm -C /dev/md2 -e 1.2 -amd --a
Apr 29 16:12:49 volumehandler.cgi: space_create.c:683 Failed to Create RAID: /dev/md2, RAID level: 2, devi
Apr 29 16:12:49 volumehandler.cgi: space_create.c:242 failed to create RAID path list
Apr 29 16:12:49 volumehandler.cgi: space_lib.cpp:428 failed to create space: /volume1
Apr 29 16:13:29 scemd: scemd.c:379 stop manutild.
Apr 29 16:14:03 volumehandler.cgi: space_disk_data_partition_create.c:33 [Info] Create primary data partit
Apr 29 16:14:03 volumehandler.cgi: partition_create.c:93 Failed to [/sbin/sfdisk -N3 -uS -q -f -j262144 -z
Apr 29 16:14:03 volumehandler.cgi: space_disk_data_partition_create.c:36 Failed to create single primary p
Apr 29 16:14:03 volumehandler.cgi: space_create.c:674 [Info] Create RAID: /dev/md2, RAID level: 2, device
Apr 29 16:14:03 volumehandler.cgi: raid_create.c:124 Failed to do '/sbin/mdadm -C /dev/md2 -e 1.2 -amd --a
Apr 29 16:14:03 volumehandler.cgi: space_create.c:683 Failed to Create RAID: /dev/md2, RAID level: 2, devi
Apr 29 16:14:03 volumehandler.cgi: space_create.c:242 failed to create RAID path list
Apr 29 16:14:03 volumehandler.cgi: space_lib.cpp:428 failed to create space: /volume1
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
würdest Du uns bitte auch verraten wie das Problem gelöst wurde? Kann ja anderen Usern helfen.
gumi
24. Apr 2011
Die Platte war eigentlich nur zum testen gedacht. Habe einfach zwei neu 2TB HD's gekauft. Hat alles sofort geklappt. Hatte keine Lust unnötig Zeit zu investieren. Die 650GB Platte wird jetzt extern per USB als Backupmedium genutzt.
Gruß Mirco
PS: Die DS211j ist echt eine schöne Sache. :)
