Oct 30 00:00:00 ntpdate: Sync with time server 85.31.187.67 offset -2.120778 sec.
Oct 30 11:40:48 scemd: SCEMD: disk 1 wake up from hibernation
Oct 30 11:40:56 scemd: SCEMD: disk 3 wake up from hibernation
Oct 30 11:41:06 scemd: SCEMD: disk 2 wake up from hibernation
Oct 30 15:32:48 syslogd started: BusyBox v1.16.1
Oct 30 15:32:50 kernel: [ 57.490000] md: md2: set sda3 to auto_remap [0]
Oct 30 15:32:50 kernel: [ 57.500000] md: md2: set sdc3 to auto_remap [0]
Oct 30 15:32:50 kernel: [ 57.500000] md: md2: set sdb3 to auto_remap [0]
Oct 30 15:32:50 kernel: [ 57.570000] 0: w=1 pa=0 pr=3 m=1 a=2 r=3 op1=0 op2=0
Oct 30 15:32:50 kernel: [ 57.570000] 2: w=2 pa=0 pr=3 m=1 a=2 r=3 op1=0 op2=0
Oct 30 15:32:50 kernel: [ 57.580000] 1: w=3 pa=0 pr=3 m=1 a=2 r=3 op1=0 op2=0
Oct 30 15:32:50 kernel: [ 57.580000] raid5: raid level 5 set md2 active with 3 out of 3 devices, algorithm 2
Oct 30 15:32:50 kernel: [ 57.590000] RAID5 conf printout:
Oct 30 15:32:50 kernel: [ 57.590000] --- rd:3 wd:3
Oct 30 15:32:50 kernel: [ 57.600000] disk 0, o:1, dev:sda3
Oct 30 15:32:50 kernel: [ 57.600000] disk 1, o:1, dev:sdb3
Oct 30 15:32:50 kernel: [ 57.600000] disk 2, o:1, dev:sdc3
Oct 30 15:32:50 spacetool: spacetool.c:2208 [Info] Activate all VG
Oct 30 15:33:02 scemd: scemd.c:127 fan_type=7, raid_type=1, led_type=1, thermal_type=1, fanctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=2, fan_number=1, ebox_type
Oct 30 15:33:02 scemd: modules/fan_speed_adjust_common.c:163 Type: INTERNAL Fan Mode: LOW
Oct 30 15:33:02 scemd: modules/raid_sys_volume_check.c:163 MD0 active disks 3, designed disks 4
Oct 30 15:33:02 scemd: modules/raid_sys_volume_check.c:163 MD1 active disks 3, designed disks 4
Oct 30 15:33:03 scemd: modules/disk_hibernation.c:430 Force hibernation enable, idle minutes 120
Oct 30 15:33:03 synoprint: printer_enable_ext.c:488 delete printer failed: no bus id
Oct 30 15:33:11 kernel: [ 79.310000] Got empty serial number. Generate serial number from product.
Oct 30 15:33:12 syno_hdd_util: Model:[WD20EARS-00S8B1], Firmware:[80.00A80], S/N:[WD--] in [/dev/sdc] is not ssd
Oct 30 15:33:13 syno_hdd_util: Model:[WD20EARS-00S8B1], Firmware:[80.00A80], S/N:[WD--] in [/dev/sdb] is not ssd
Oct 30 15:33:13 syno_hdd_util: Model:[WD20EARS-00S8B1], Firmware:[80.00A80], S/N:[WD--] in [/dev/sda] is not ssd
Oct 30 15:33:13 synousbdisk: RCClean succeeded
Oct 30 15:33:14 synosata: synosata.c:174 failed to enum all external sata devices
Oct 30 15:33:16 hotplugd: hotplugd.c:956 failed get usb status from usb config, DEVICE=/proc/bus/usb/001/001, usbid=1d6b:0002:orion-ehci.0
Oct 30 15:33:16 hotplugd: ##### ACTION:add
Oct 30 15:33:16 hotplugd: DEVICE:/proc/bus/usb/001/001
Oct 30 15:33:16 hotplugd: DEVPATH:usb1
Oct 30 15:33:16 hotplugd: SUBSYSTEM:usb
Oct 30 15:33:17 hotplugd: hotplugd.c:732 Fail to recognize usb DEVNAME=, DEVPATH=usb1
Oct 30 15:33:17 hotplugd: hotplugd.c:1257 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb1, /proc/bus/usb/001/001, add, , )
Oct 30 15:33:17 hotplugd: hotplugd.c:956 failed get usb status from usb config, DEVICE=/proc/bus/usb/001/001, usbid=1d6b:0002:orion-ehci.0
Oct 30 15:33:17 hotplugd: ##### ACTION:add
Oct 30 15:33:17 hotplugd: DEVICE:/proc/bus/usb/001/001
Oct 30 15:33:17 hotplugd: DEVPATH:1-0:1.0
Oct 30 15:33:17 hotplugd: SUBSYSTEM:usb
Oct 30 15:33:17 hotplugd: INTERFACE:9/0/0
Oct 30 15:33:17 hotplugd: DEVICE:/proc/bus/usb/001/002
Oct 30 15:33:17 hotplugd: DEVPATH:1-1:1.0
Oct 30 15:33:18 hotplugd: hotplugd.c:758 ##### complete device hotplug!!
Oct 30 15:33:18 ddnsd: main(ddnsd.c:2783): not enable DDNS, shutdown daemon
Oct 30 15:33:20 ntpdate: Sync with time server 72.26.217.213 offset -1.548896 sec.
Oct 30 15:33:33 syno_bkp_data_update: Fail to get share information (NetBackup)
Oct 30 15:33:33 syno_bkp_data_update: syno_bkp_data_update.c: main(230) - Fail to update netbakup data format.
Oct 30 15:35:09 scemd: scemd.c:391 stop manutild.
