DS_Store Dateien vom Mac auf DS verhindern, so gehts!
Pino72
08. Okt. 2009
nur falls es hier noch nicht gepostet wurde, die nervigen DS_store Dateien die der MAC überall ablegt kann man permanent für alle NICHT-lokalen Platten also alle Netzwerklaufwerke und Verbindungen deaktivieren. Hat bei rmi prima geklappt:
To configure a Mac OS X user account so that .DS_Store files are not created when interacting
with a remote file server using the Finder, follow the steps below.
Note: This will affect the user's interactions with SMB/CIFS, AFP, NFS, and WebDAV servers.
1. Open the Terminal.
2. Type:
defaults write com.apple.desktopservices DSDontWriteNetworkStores true
3. Press Return.
4. Restart the computer.
If you want to prevent .DS_Store file creation for other users on the same computer, log in to
each user account and perform the steps above?or distribute a copy of your newly modified
com.apple.desktopservices.plist file to the ~/Library/Preferences folder of EACH other
target users.
These steps do not prevent the Finder from creating .DS_Store files on the local volume. These
steps do not prevent previously existing .DS_Store files from being copied to the remote file
server. Please note that disabling the creation of .DS_Store files on remote file servers can
cause unexpected behavior in the Finder (click here for an example:
http://docs.info.apple.com/article.html?artnum=107822 ).
