DSM 6.x und darunter DSM 5.2-5967 verfügbar
TheTwist76
21. Apr 2013
Version: 5.2-5967
(2016/04/28)
What's New
This update includes all bug fixes as well as security fixes in the previously released updates since DSM 5.2-5644.
Fixed Issue
Improved performance of backup tasks and data restoring in Backup & Restore.
Improved backup stability in Backup & Restore when files are being edited.
You may now choose to reset the system without resetting the password at Control Panel > Update & Restore.
Added full-speed fan mode to provide the best cooling effects for Synology NAS.
Fixed multiple vulnerabilities regarding Samba module (CVE-2016-2118, CVE-2015-5370, CVE-2016-2110, CVE-2016-2111, CVE-2016-2112, CVE-2016-2113,
CVE-2016-2114, CVE-2016-2115).
Fixed an issue where iSCSI service could not start upon system boot with snapshot retention policy enabled in DSM 5.2-5644.
Fixed an issue where iSCSI service could not respond under certain conditions when LUN was being created or removed.
Fixed an issue where the system could not enter hibernation with Snapshot Manager for VMware installed.
To enhance the security level, Synology's default administrator account "admin" with the blank password will no longer be allowed and will be disabled after this
update. It is also highly recommended that you increase the password strength of all accounts belonging to the administrators group.
Fixed an issue where permission settings for a shared folder could not be edited in Windows if the folder was mounted via SMB.
Happy testing!!!
Puppetmaster
03. Feb 2012
Ja, besonders bemerkenswert fand ich das hier:
Kann dazu schon jemand etwas sagen?
TheTwist76
21. Apr 2013
Ist wie bei der DSM 6.0. Es gibt drei Einstellungen
Full speed
Kühlmodus
Stillermodus
Puppetmaster
03. Feb 2012
Ah, und das nennt sich dann "full speed mode". Ok.
Meine Erwartung war da irgendwie eine andere. ;)
Aber so macht es ja auch Sinn...
Danke für die Information!
Ich finde die "Backup & Restore" Optimierungen interessant. Werde mir insbesondere die Performance ansehen, da ich mit der Stabilität keine Probleme hatte. Mit der Performance zwar auch nicht, aber schneller ist natürlich immer schön. ;)
X5_492_Neo
Gesperrt
24. Sep 2008
Update installiert, kanns mir erst heute Nachmittag angucken! Ich warte eigentlich eher auf das DSM 6 update!
Update auf der 214+ eingespielt - bisher keine Probleme.
KGBist2000
10. Jan 2016
Update 716+ alles ok. Lüftermodus mit max. Drehzahl getestet. Außer dass es lauter wird, bringt es wahrscheinlich nix.
Kurt-oe1kyw
10. Mai 2015
Doch bringt ein wenig etwas an niedriger CPU Temperatur, bei uns 5° C weniger.
Im Detail:
DS 415+ aktualisiert vom alten DS 5.2- 5644 Update 8 auf die neue DSM 5.2-5967 > Dauer inklusive automatischem Neustart der DS 5 Minuten.
Bisher problemlos.
Lüfter Einstellung bei Lüftermodus - Stiller Modus (DS bei uns wirklich unhörbar von den Lüftern) zeigt eine CPU Temp von 44°C.
Umstellung Lüftermodus auf "Modus Volle Geschwindigkeit", zeigt eine CPU Temp von 39°C - allerdings muss man hier Geduld haben es dauert mehrere Minuten bis die Temperatur unten war!
Die Lüfter sind jetzt aber deutlich hörbar bei uns!
Temperatur HDDs ( 3 x WD red 6 TB) nur 1°C weniger bei voller Geschwindigkeit.
Mein persönliches Fazit:
Ich hab wieder zurückgestellt auf "Stiller Modus".
Unsere APPS auf dem Handy DS Photo, DS File und DS Audio funktionieren weiterhin problemlos.
Auch die Photostation 6 läuft problemlos weiter mit der neuen DSM Version.
Backup muss ich erst testen.
Andy+
25. Jan 2016
...............warte eigentlich eher auf das DSM 6 update...............
Wer weiss (?), wenn DSM 6 so rund wäre, würde jeder drauf los wollen, weil DSM 5.2 "nicht mehr so toll" wäre. Mir scheint, das aber anders und die Strategie, noch bei DSM 5.2 zu bleiben, zumindest vorerst, bestätigt.
BirdofPrey
17. Jan 2015
Die 415+ und 213j aktualisiert und Ruhemodus läuft noch.
Die 6 kommt erst druff, wenn der Klagen deutlich weniger werden.
noiasca
08. Feb 2014
warum ist eigentlich das wieder in der Releasenote?
To enhance the security level, Synology's default administrator account "admin" with the blank password will no longer be allowed and will be disabled after this update.
das war ja schon im November 5.2-5644-1.
heido
07. Mrz 2008
112+ und 114 laufen nach Update ohne Probleme
Frogman
01. Sep 2012
warum ist eigentlich das wieder in der Releasenote?To enhance the security level, Synology's default administrator account "admin" with the blank password will no longer be allowed and will be disabled after this update. das war ja schon im November 5.2-5644-1.
Weil es Menschen gibt, die direkt von einer Vorversion updaten und nicht über das Update 1 der -5644 gehen... und die sollten ebenso gewarnt sein (wenngleich erfahrungsgemäß ein Großteil aller Nutzer die Release Notes keines Blickes würdigt ;)).
Hontem
20. Dez 2013
Was mich wundert ist folgendes:
Am 22.04.2016 wurde auf meiner DS214+ die Version Version: 6.0-7321-3 geupdatet.
Nun mit Datum vom 28.04.2016 erscheint die Version 5.2-5967 in den Release Notes
Die Version 6.0-7321-3 läuft aber einwandfrei.
Alle vorherigen Updates wurde ordnungsgemäß bis zur Version 6.0-7321-3 als update in der DS214+ angeboten und durchgeführt..
Muss ich jetzt manuell downgraten.??
Nein, Synology sieht ein Downgrade offiziell gar nicht vor. Die Release-Notes wurden in diesem Fall chronologisch geführt - 5.2-5967 kam schlichtweg nach 6.0-7321-3 heraus. Du hast die aktuelle Version von DSM 6.0 im Betrieb.
Perry2000
05. Nov 2012
Auch hier läuft alles unter 5.2 wie gewohnt :)
@Hontem: Nein, auch für ältere DSM-Versionen gibt es noch Updates. Und wie gesagt: Das genannte DSM 5.2 Update ist später herausgebracht worden als das letzte für DSM 6.0.
