DSM 5.2 with eSata Raid Station
sgreg
10. Dez 2010
Hi
ich benutze eine 1512+ mit einem angeschlossenem externen eSata Gehäuse, Sharkoon 5 Bay Raid Station Festplattengehäuse für 5x SATA. Der Chipsatz im externen Gehäuse ist ein JMicron 539 Chipset. Nach dem Upgrade auf DSM 5.2 (DSM 5.2-5565 Update 1) läuft die Kiste leider nicht mehr.
Folgende Fehlermeldung kommt unter /var/log/messages:
Jun 4 07:59:28 syno kernel: [ 3508.438979] ata7: device plugged sstatus 0x123
Jun 4 07:59:28 syno kernel: [ 3508.443491] ata7: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0xe frozen
Jun 4 07:59:28 syno kernel: [ 3508.450404] ata7: irq_stat 0x00b40090, PHY RDY changed
Jun 4 07:59:28 syno kernel: [ 3508.455588] ata7: limiting SATA link speed to 1.5 Gbps
Jun 4 07:59:38 syno kernel: [ 3518.456722] ata7: softreset failed (timeout)
Jun 4 07:59:38 syno kernel: [ 3518.461012] ata7: softreset failed, set srst fail flag
Jun 4 07:59:40 syno kernel: [ 3520.870863] ata7: link reset sucessfully clear error flags
Jun 4 07:59:42 syno kernel: [ 3522.197531] ata7.00: limiting SATA link speed to 1.5 Gbps
Jun 4 07:59:42 syno kernel: [ 3522.614228] ata7.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Jun 4 07:59:45 syno kernel: [ 3525.216837] ata7.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Jun 4 07:59:47 syno kernel: [ 3527.481762] ata7.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Jun 4 07:59:49 syno kernel: [ 3529.464898] WARNING: disk 7 can't find master
Jun 4 07:59:49 syno kernel: [ 3529.469279] ------------[ cut here ]------------
Jun 4 07:59:49 syno kernel: [ 3529.473912] WARNING: at drivers/ata/libata-eh.c:1349 ata_scsi_port_error_handler+0x16c9/0x1710()
Jun 4 07:59:49 syno kernel: [ 3529.550791] CPU: 2 PID: 3469 Comm: scsi_eh_6 Tainted: P C O 3.10.35 #5565
Jun 4 07:59:49 syno kernel: [ 3529.558307] Hardware name: Intel Corporation GRANITE WELL, BIOS Tiano-GraniteWell 05/27/2011
Jun 4 07:59:49 syno kernel: [ 3529.566765] ffffffff8148163b 0000000000000000 ffffffff8103374d ffff8800b4f94000
Jun 4 07:59:49 syno kernel: [ 3529.574248] 0000000000000000 0000000000000246 0000000000000000 0000000000000000
Jun 4 07:59:49 syno kernel: [ 3529.581723] ffffffff8132e5c9 ffff8800b6493e68 ffff8800b4f970b0 0000000000011680
Jun 4 07:59:49 syno kernel: [ 3529.589192] Call Trace:
Jun 4 07:59:49 syno kernel: [ 3529.591649] [<ffffffff8148163b>] ? dump_stack+0xd/0x17
Jun 4 07:59:49 syno kernel: [ 3529.596889] [<ffffffff8103374d>] ? warn_slowpath_common+0x6d/0xa0
Jun 4 07:59:49 syno kernel: [ 3529.603075] [<ffffffff8132e5c9>] ? ata_scsi_port_error_handler+0x16c9/0x1710
Jun 4 07:59:49 syno kernel: [ 3529.610231] [<ffffffff8132e6a7>] ? ata_scsi_error+0x97/0xd0
Jun 4 07:59:49 syno kernel: [ 3529.615905] [<ffffffff812fdc34>] ? scsi_error_handler+0xc4/0x460
Jun 4 07:59:49 syno kernel: [ 3529.622021] [<ffffffff81484e5b>] ? __schedule+0x27b/0x6a0
Jun 4 07:59:49 syno kernel: [ 3529.627529] [<ffffffff812fdb70>] ? scsi_eh_get_sense+0xf0/0xf0
Jun 4 07:59:49 syno kernel: [ 3529.633456] [<ffffffff81053f75>] ? kthread+0xb5/0xc0
Jun 4 07:59:49 syno kernel: [ 3529.638513] [<ffffffff81053ec0>] ? kthread_create_on_node+0x120/0x120
Jun 4 07:59:49 syno kernel: [ 3529.645062] [<ffffffff814869ec>] ? ret_from_fork+0x7c/0xb0
Jun 4 07:59:49 syno kernel: [ 3529.650649] [<ffffffff81053ec0>] ? kthread_create_on_node+0x120/0x120
Jun 4 07:59:49 syno kernel: [ 3529.657180] ---[ end trace 1bf0eb22fa7ef0d4 ]---
Jun 4 07:59:50 syno hotplugd: hotplugd.c:1265 ##### ACTION:change
Jun 4 07:59:50 syno hotplugd: DEVNAME:host6
Jun 4 07:59:50 syno hotplugd: SYNO_PMP_EVENT:CABLE_CONNECT
Jun 4 07:59:50 syno hotplugd: hotplugd.c:1449 PMP Event CABLE_CONNECT
Jun 4 07:59:50 syno hotplugd: hotplugd.c:577 wait for /proc/partitions ready
Ich vermute DSM 5.2 verseht sich nicht mehr mit dem externen eSata Chipset.
Gibt es Heinweise das wieder zum Laufen zu bekommen?
Ein ähnlicher Fall ist hier beschrieben: http://forum.synology.com/enu/viewtopic.php?f=116&t=101365
Grüße und DANKE für den Support
RalfPeter
02. Apr 2014
@sgreg: ich spiele mit dem Gedanken ein externes HDD-Gehäuse an meine DS1513+ per eSATA anzuschließen. Läuft denn dein Sharkoon 5-Bay wieder? Oder hast du eine andere Lösung gefunden?
sgreg
10. Dez 2010
Hi
im Moment kann ich die Benutzung von eSATA nicht empfehlen. Auf meine Serviceanfrage hin, kam die Frage zurück ob denn das Gerät in der Supportliste stehen würde. Nachdem in der Supportliste keine eSATA Geräte aufgeführt sind, liegt die Schlussfolgerung nahe das offiziell keine eSATA Geräte mehr unterstützt werden, mit Ausnahme Synology eigenen Erweiterungen.
https://www.synology.com/de-de/compatibility
BTW meine alte DS 508 kann sehr gut mit dem Sharkoon 5 Bay Raid Station.
Meine Erklärung ist, das in der neue DSM Version 5.2 der Support bzw. der Treiber für eSATA eingeschränkt wurde.
Leider habe ich keine Lösung gefunden.
