DSM 6.x und darunter Dsm 6.0.1-7393
odol26
28. Apr 2014
Version: 6.0.1-7393
(2016/06/06)
What's New
This update includes all bug fixes as well as security fixes in the previously released updates since DSM 6.0-7321.
EDS can now be upgraded to DSM 6.0.1.
Improved overall performance for multiple client connections.
SSD TRIM is now supported on DS715, DS1515, and DS2015xs.
File Station
The sorting algorithm has been changed from sorting by name to natural sort order.
Changed the filter function to the search function to locate files efficiently.
Supports search history.
High Availability Manager
Added the quorum server settings to reduce split-brain error occurrences.
Proxy servers are supported.
Supports customized DSM ports and HTTPS connection.
Reduced by 60% the average time for detecting disconnected networks before automatic failover.
Improved HA cluster stability during upgrade.
Supports installing DSM on RC18015xs+ in network environments without a DHCP server.
Fixed Issues
Fixed an issue where an ext2 external storage device could not be mounted.
Fixed an issue where shared folders on NTFS external storage devices could not be remotely mounted to some models via NFS.
Reduced memory usage for writing data to an NTFS external storage device.
Fixed an issue where Microsoft Excel files in an encrypted shared folder on some models could not be correctly accessed via Windows File Service.
Fixed a security vulnerability regarding the p7zip module (CVE-2016-2335).
Fixed an issue where files might not appear in search results if their file types were not specified for file indexing.
Fixed an issue where backup tasks could not complete when the remote destination was encrypted.
Fixed an issue where IPv6 link-local authentication might fail for rsync.
Fixed an issue where backup tasks in Time Backup might not run after system upgrade.
Fixed an issue where system monitoring processes might demand system memory on RS10613xs+, RS18016xs+, and RC18015xs+.
Applied the workaround to mitigate a security vulnerability of ImageMagick module (CVE-2016-5118).
Minor bug fixes.
Bei Meiner DS1815+ nach dem reboot alles in Ordnung
loutriju
23. Jan 2011
Anyone has installed it on DS116? I blew my DS111 when updating it a few years ago, now
I am cautious.
DKeppi
01. Apr 2011
Läuft Virtualbox 5.0.20 damit noch?!
reiki
16. Mai 2012
DS214+ und DS115 mit Neustart erfolgreich upgedated; dauerte jeweils etwa gefühlte 15-20 Minuten. Einige Pakete ebenfalls aktualisiert.
duri3
21. Dez 2015
Soeben auf meine DS216play installiert. Update lief problemslos durch. Zudem sind noch neue Pakete (PHP 5.6 / Speicheranalysator / Hyperbackup) erschienen die ich zusätzlich noch installiert habe.
amarthius
Super-Moderator
Teammitglied
03. Jun 2009
Gar kein Kommentar dazu, dass ein neues BIOS für die DS216+ enthalten ist welches angeblich den Freeze beim Shutdown behebt. Hat schon jmd. Erfahrungen mit einer DS216+ und kann die BIOS Version nach dem Update veröffentlichen?
Tommes
26. Okt 2009
Gar kein Kommentar dazu, dass ein neues BIOS für die DS216+ enthalten ist...
Finde ich auch sehr seltsam. Kann das aber erst heut Abend testen, wenngleich ich nicht weiß ob sich da bei mir etwas ändert. Ich hab vom Support ja bereits den BIOS-Patch erhalten und eingespielt.
Edit: Ich find auf dem Downloadserver gar kein File für die DS216+, nur für die DS216+II.
Tommes
optimist123
16. Jun 2010
Wenn man sich den Inhalt der "DSM_DS216_7393.pat" anschaut, dann erscheint eine "uboot_DS216.bin" in der Dateiliste.....
loutriju
23. Jan 2011
Gerade auch auf DS116 aktualisiert. (Noch) keine Probleme.
Schakal
20. Apr 2011
jDownloader funktioniert nach dem Update nicht mehr.
Der Rest läuft wie gewohnt...
JackOh
27. Mai 2015
Bei mir läuft JDownloader nicht mehr. Es lässt sich im Paketzentrum nicht mehr starten. Die gesamte DS ist total zäh geworden. Filestation braucht ewig, bis die Dateiliste angezeigt wird. Zugriffe über Windows Explorer dauern unzumutbar lange. Ein erneuter Nestart der DS dauerte über 5 Minuten. Was kann das sein?
Wicki
29. Dez 2013
Selbes Problem hier. syno-cloud-clientd lastest die CPU seit jetzt ~ 45 Minuten komplett aus. Neustart hat da keine Besserung gebracht.
/edit
Einmal schriftlich meckern hat das Problem gelöst. CPU Auslastung ist wieder ok und dann ist auch jDownloader wieder gestartet. Alles wieder ok. :)
bananie
14. Dez 2015
Bisher muss ich auf meiner DS214 nichts beanstanden. Läuft alles so, wie es sein sollte.
rednag
08. Nov 2013
weiss-nicht
14. Mai 2012
Habe eine DS415+ und DSM 6.0.1.
Was hat denn Synology jetzt wieder für Scheisse gebaut.
Das neuste Update durchgeführt und Plex kann nicht mehr gestartet werden.
Bei jedem Update kommen wieder neue Bugs.
Langsam ist es nicht mehr Lustig
ASch
29. Aug 2013
hmmmm, am Samstag bin ich auf DSM 6 update 6 gegangen und heute gibt es DSM 6.0.1.
Keine Probleme bei 6.0 auf 6.0.1 - auch Plex, das ja bei Update auf 6.0 nicht geht, fkt. nach Update auf die 6.0.1 noch.
Also DS213+: alles i.O,
