Dyndns hat meinen Host geblockt ???
orion
09. Mrz 2009
ich bekam die Tage folgende E-Mail:
Dear Valued Customer:
Your hostname, ***.dyndns.org, in account ***, has been blocked
for abusive updates. This usually occurs when an update client is
misconfigured or is not fully compatible with our services. This block has
been automatically placed to prevent flooding.
You can learn more about abusive updates here:
http://www.dyndns.com/support/abuse.html
Once you have corrected the issue with your update client, you may unblock
the host here:
https://www.dyndns.com/+dyndns/***.dyndns.org
If you have any questions or need help diagnosing the problem, please
contact support@dyndns.com or visit
http://www.dyndns.com/support/contact/email.html to use our online support
form.
Thank you for choosing DynDNS.com!
Sincerely,
The DynDNS.com Team
Dynamic Network Services Inc.
da ich keine wirkliche ahnung von der Materie habe und froh bin, dass ich das alles eingerichtet bekommen habe, habe ich den Support wie folgt angemailt:
my account is blocked because of abuse. I´m not an expert and I have no
idea what happend.
I use this account since a long time without any problems and I did not
chance the system since month. I´m using a synology disk station 207+ to
get access on my data from abroad.
how can I unblock the account? I´ve no idea of the use of an update client,
do I have such one?
thanks for help to unblock my account
marK :)
ich bekam auch promt noch am selben Tag eine Antwort und mit dieser Antwort leider kein Stück schlauer:
Hello Mark,
Thank you for contacting our customer support team. I looked at your
account and everything looks good. We are resolving your hostname fine,
so everything is working on our end. You can use the dns lookup tool to
see that it is properly resolving at:
http://dnscog.com/
I checked your logs and see that you have several update clients
operating, please disable the additional update clients other than the
Windows client and configure it so it only updates your IP when a change
is detected. Please see the update client article here:
http://www.dyndns.com/support/clients/
Be sure to follow the DynDNS Updater Installation Guide to troubleshoot
updating problems.
Regards,
Charles Phillips
Customer Service Technician
Dynamic Network Services, Inc.
ich habe nicht die Spur einer Ahnung, was ein update client ist und ich habe sicher keinen installiert. Ich habe über den dyndns. account noch weitere hosts laufen, die alle wunderbar funktionieren.
Die diskstation hat über mehrere Monate auch bestens funktioniert und ich habe nichts am System verändert.
Was kann ich tun?
Hat jemand eine Ahnung was das alles bedeutet?
danke im voraus
marK :)
jahlives
19. Aug 2008
Hast du mehrere DynDNS Client aktiv? z.B. auf dem Router und auf der DS und womöglich noch auf einem Windows-Client?
orion
09. Mrz 2009
mehrere clients aktiv ?
abgesehen davon, dass ich die def. client nicht so recht kenne, kann ich mir unter ümständen vorstellen, dass ich die daten meines accounts sowohl in der DS also auch aufdem Router eingetragen habe. Ist das falsch? Wenn ja wo müssen sie stehen?
karl2014
19. Apr 2009
nur auf einem von beiden, normalerweise auf dem Router.
orion
09. Mrz 2009
ok soweit, verstanden
werde die dyndns daten aus der synology löschen, wie aktiviere ich jetzt aber meinen geblockten host neu?
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
z3opa
15. Feb 2008
Hallo
Ich hatte das auch schon mal. Hab meinen Account bei DynDns gelöscht und sofort neu Angemeldet und es ging wieder.
elektrolurch
13. Feb 2007
Was kann ich tun?
Vielleicht hilft Dir auch das:
http://de.wikipedia.org/wiki/DynDNS
