Eigene Domain mit Zarafa dsmynas.de Fehler
placebofan86
15. Feb 2011
Hallo ich möchte über dsmynas.de einen eigenen Mailserver laufen lassen.
Geht das überhaupt?
ich habe noch eine weiterleitung zu einer .de adresse. also www.meine.de
nun habe ich folgendes log im postfix:
6183D: lost connection with mx1.hotmail.com[65.54.188.94] while sending RCPT TO
6183D: removed
tics: max connection rate 1/60s for (smtp:65.55.116.41) at Mar 16 18:35:45
tics: max connection count 1 for (smtp:65.55.116.41) at Mar 16 18:35:45
tics: max cache size 1 at Mar 16 18:35:45
]: stopping the Postfix mail system
inating on signal 15
: master pid is: 7254
: listening on socket: /var/run/saslauthd/mux
]: starting the Postfix mail system
n started -- version 2.5.5, configuration /usr/syno/mailstation/etc
t : master exited: 7254
nating on signal 15
: master pid is: 7355
t from blu0-omc1-s27.blu0.hotmail.com[65.55.116.38]
2625CE: client=blu0-omc1-s27.blu0.hotmail.com[65.55.116.38]
E12625CE: message-id=<BLU0-SMTP3337E8C131BFBB0C0AE50C89B5F0@phx.gbl>
625CE: from=<meinename.nachname@hotmail.de>, size=3160, nrcpt=1 (queue active)
nect from blu0-omc1-s27.blu0.hotmail.com[65.55.116.38]
625CE: to=<meinename@meinebox.dsmynas.com>, relay=zarafa, delay=3.1, delays=0.56/0.1/0/2.5, dsn=5.3.0, status=bounced (internal software error. Command output: [ 8063] Access denied or Connection failed,
A12625D0: message-id=<20120316180041.5FF3A12625D0@meinebox.dsmynas.de>
625D0: from=<>, size=5328, nrcpt=1 (queue active)
12625CE: sender non-delivery notification: 5FF3A12625D0
625CE: removed
625D0: to=<meinename.nachname@hotmail.de>, relay=mx4.hotmail.com[65.55.37.88]:25, delay=1.4, delays=0.12/0.16/0.87/0.2, dsn=5.0.0, status=bounced (host mx4.hotmail.com[65.55.37.88] said: 550 DY-001 (COL0-MC
625D0: lost connection with mx4.hotmail.com[65.55.37.88] while sending RCPT TO
625D0: removed
t from localhost[127.0.0.1]
2625CE: client=localhost[127.0.0.1]
412625CE: message-id=<zarafa.4f638026.20b4.47a3b2db36307236@meinebox>
nect from localhost[127.0.0.1]
625CE: from=<meinename.nachname@hotmail.de>, size=1899, nrcpt=1 (queue active)
to mx.freenet.de[2001:748:100:40::8:111]:25: Network is unreachable
to mx.freenet.de[2001:748:100:40::8:110]:25: Network is unreachable
to mx.freenet.de[2001:748:100:40::8:112]:25: Network is unreachable
625CE: to=<meinename.nachname@freenet.de>, relay=mx.freenet.de[195.4.92.211]:25, delay=1.6, delays=0.91/0.03/0.26/0.42, dsn=5.0.0, status=bounced (host mx.freenet.de[195.4.92.211] said: 550 Submission from
512625D0: message-id=<20120316180216.5B9E512625D0@meinebox.dsmynas.de>
625D0: from=<>, size=3950, nrcpt=1 (queue active)
12625CE: sender non-delivery notification: 5B9E512625D0
625CE: removed
625D0: to=<meinename.nachname@hotmail.de>, relay=mx3.hotmail.com[65.54.188.126]:25, delay=0.93, delays=0.07/0/0.67/0.19, dsn=5.0.0, status=bounced (host mx3.hotmail.com[65.54.188.126] said: 550 DY-001 (BAY0
625D0: lost connection with mx3.hotmail.com[65.54.188.126] while sending RCPT TO
625D0: removed
t from mout2.freenet.de[195.4.92.92]
2625CE: client=mout2.freenet.de[195.4.92.92]
B12625CE: message-id=<004b01cd039f$01617520$04245f60$@nachname@freenet.de>
625CE: from=<meinename.nachname@freenet.de>, size=3715, nrcpt=1 (queue active)
nect from mout2.freenet.de[195.4.92.92]
625CE: to=<meinename@meinebox.dsmynas.com>, relay=zarafa, delay=4.1, delays=0.26/0.13/0/3.7, dsn=5.3.0, status=bounced (internal software error. Command output: [ 9059] Access denied or Connection failed,
E12625D0: message-id=<20120316180525.377EE12625D0@meinebox.dsmynas.de>
625D0: from=<>, size=5883, nrcpt=1 (queue active)
12625CE: sender non-delivery notification: 377EE12625D0
625CE: removed
625D0: to=<meinename.nachname@freenet.de>, relay=mx.freenet.de[195.4.92.212]:25, delay=0.74, delays=0.18/0.16/0.2/0.2, dsn=5.0.0, status=bounced (host mx.freenet.de[195.4.92.212] said: 550 Submission from d
625D0: removed
tics: max connection rate 1/60s for (smtp:65.55.116.38) at Mar 16 19:00:37
tics: max connection count 1 for (smtp:65.55.116.38) at Mar 16 19:00:37
tics: max cache size 1 at Mar 16 19:00:37
jahlives
19. Aug 2008
der Fehler liegt hier
[COLOR=#333333]625CE: to=<meinename@meinebox.dsmynas.com>, relay=zarafa, delay=3.1, delays=0.56/0.1/0/2.5, dsn=5.3.0, status=bounced (internal software error. Command output: [ 8063] Access denied or Connection failed,
rein von der Meldung her würde ich vermuten, dass das Problem wohl im Transport von zarafa liegen muss. Der Transport zarafa wird wohl ein externes File auf deiner DS sein. Von daher würde ich meinen Postfix darf dieses File nicht aufrufen. Such mal im File /usr/syno/mailstation/etc/tansport nach zarafa und prüfe ob der User postfix das dort angegebene File lesen darf
[/COLOR]
Jdo2002
24. Dez 2011
Okay, du hast eine eigene Domain oder hast du einen POP3 Emailaccount?
Also ich möchte gerade erstmal verstehen was dein Ziel ist :)
EDIT: Wer lesen kann ist klar im Vorteil - du hast ne eigene Domain :)
Jdo2002
24. Dez 2011
Wie hast du denn dein postfix konfiguriert? Nach der Anleitung im Wiki?
Kannst du mal deine master.cf / main.cf posten?
placebofan86
15. Feb 2011
habe beide datein als ziparchive angehängt ... bitte txt in zip umändern ich konnte es sonst nicht hochladen sorry
  • mail.txt
Jdo2002
24. Dez 2011
Also in der master.cf hast du zweimal diesen Eintrag stehen
zarafa unix - n n - 10 pipe
flags= user=vmail argv=/usr/local/zarafa/bin/zarafa-dagent $(user)
flags= user=christopher argv=/usr/local/zarafa/bin/zarafa-dagent $(user)
Dieser Eintrag definiert wie Postfix Mails an Zarafa übergeben soll. Der User vmail ist seitens Zarafa als admin definiert (siehe Eintrag in der Datei /etc/zarafa/server.cfg: local_admin_users = root vmail)
Daher ist nur ein Eintrag für alle User erforderlich und korrekt:
In der main.cf solltest du folgenden Eintrag auskommentieren:
mailbox_command = /usr/bin/zarafa-dagent ${user}
Dann mit "/usr/syno/mailstation/sbin/postfix reload" die Konfig nochmal neu reinladen. Ich würd die empfehlen dann mal per telnet eine Mail an das Zarafa Postfach zuzustellen (guck dazu mal hier)
placebofan86
15. Feb 2011
oooh, danke! ich bekomme schon mal eine email in das webaccess center von zarafa freu!
nun versuche ich von dort mail an extern zu senden.
Mar 16 21:05:25 postfix/smtpd[28458]: connect from localhost[127.0.0.1]
Mar 16 21:05:25 postfix/smtpd[28458]: 457E212625D2: client=localhost[127.0.0.1]
Mar 16 21:05:25 postfix/cleanup[28464]: 457E212625D2: message-id=<zarafa.4f639d05.6f90.712d091b7829c905@meinebox>
Mar 16 21:05:25 postfix/smtpd[28458]: disconnect from localhost[127.0.0.1]
Mar 16 21:05:25 postfix/qmgr[27433]: 457E212625D2: from=<name.nachname@hotmail.de>, size=1890, nrcpt=1 (queue active)
Mar 16 21:05:27 postfix/smtp[28471]: 457E212625D2: to=<name.nachname@hotmail.de>, relay=mx1.hotmail.com[65.55.92.152]:25, delay=1.4, delays=0.58/0.02/0.62/0.15, dsn=5.0.0, status=bounced (host mx1.hotmail.com[65.55.92.152] said: 550 DY-001 (SNT
Mar 16 21:05:27 postfix/smtp[28471]: 457E212625D2: lost connection with mx1.hotmail.com[65.55.92.152] while sending RCPT TO
Mar 16 21:05:27 postfix/cleanup[28464]: 2475712625D4: message-id=<20120316200527.2475712625D4@meinebox>
Mar 16 21:05:27 postfix/bounce[28573]: 457E212625D2: sender non-delivery notification: 2475712625D4
Mar 16 21:05:27 postfix/qmgr[27433]: 2475712625D4: from=<>, size=4336, nrcpt=1 (queue active)
Mar 16 21:05:27 postfix/qmgr[27433]: 457E212625D2: removed
Mar 16 21:05:28 postfix/smtp[28471]: 2475712625D4: to=<name.nachname@hotmail.de>, relay=mx2.hotmail.com[65.55.37.120]:25, delay=0.96, delays=0.07/0.01/0.69/0.19, dsn=5.0.0, status=bounced (host mx2.hotmail.com[65.55.37.120] said: 550 DY-001 (CO
L
Mar 16 21:05:28 postfix/smtp[28471]: 2475712625D4: lost connection with mx2.hotmail.com[65.55.37.120] while sending RCPT TO
Mar 16 21:05:28 postfix/qmgr[27433]: 2475712625D4: removed
Mar 16 21:06:07 postfix/anvil[27472]: statistics: max connection rate 1/60s for (smtp:65.55.116.36) at Mar 16 20:59:13
Mar 16 21:06:07 postfix/anvil[27472]: statistics: max connection count 1 for (smtp:65.55.116.36) at Mar 16 20:59:13
Mar 16 21:06:07 postfix/anvil[27472]: statistics: max cache size 2 at Mar 16 21:02:45
placebofan86
15. Feb 2011
warum klappt es über meinebox.dsmynas.com aber nicht über die weiterleitung auf meinebox.de ?
jahlives
19. Aug 2008
hast du eine dynamische externe IP? Falls ja dann hat wohl die Gegenseite die Mail desswegen verweigert. In dem Fall bräuchtest du einen externen Relay Server mit fixer IP
Jdo2002
24. Dez 2011
Das senden schlägt fehlt da hotmail nicht einfach mails ohne Anmeldung annimmt -generell wirst du das Problem haben das die Mailserver von deiner dynamischen IP die Mails nicht unbedingt annehmen. Deshalb kann man einen smarthost verwenden. D.h. zum senden meldet sich postfix bei diesem Server an und der leitet die Mail dann weiter.
Folgende Punkte:
- Du hast ne eigene domain - dann solltest du auch mit deinbenutzername@deinedomain.de mails verschicken. So wie es laut logs aussiehst verwendest du aber deinbenutzername@hotmail.de als Absender.
- Du kannst natürlich auch über deinbenutzername@deinedomain.de emails empfangen und über die hotmail Adresse versenden. Das macht aber wenig sinn wenn dir dann jemand antwortet.
Die frage ist nun was du möchtest:
- Emails per fetchmail von deinem Hotmail Konto abholen und per postfix über hotmail auch Mails verschicken
- Emails über deine Domain empfangen und darüber auch versenden.
placebofan86
15. Feb 2011
okay, ich möchte das machen :
das im fetchmail scheint dann wohl noch ein Überbleibsel von der config davor zu sein, muss ich wohl bereinigen.
vorher hatte ich alles über hotmail laufen, nun würde ich gerne meine eigene domain verwenden wollen.
placebofan86
15. Feb 2011
hast du eine dynamische externe IP? Falls ja dann hat wohl die Gegenseite die Mail desswegen verweigert. In dem Fall bräuchtest du einen externen Relay Server mit fixer IP[/COLOR]
momentan benutze ich den dyndns dienst von synology, d.h. wohl ich habe eine dynamische ip ?!
und was muss ich nun tun?
übrigens vielen dank euch! finde die hilfe gerade echt strak! macht mir spaß so vorwärts zu kommen, auch wenn es nur kleine schritte sind!
Jdo2002
24. Dez 2011
Die meisten privaten Internetnutzer haben eine Dynamische IP => heißt mit jedem einwählen / nach einer bestimmten Zeitspanne bekommt man in der Regel eine neue IP Adresse. Viele Mailserver verweigern die Annahme von E-Mails. Du müsstest dich mal schlaumachen wo die Domain gehostet wird. Meistens hat der anbieter auch einen Mailserver den man nutzen kann. Dazu gibts dann auch Zugangsdaten damit du den Nutzen kannst.
Deine Main.cf solltest du dann um diese Einträge ergänzen, wobei SMARTHOST für den mailserver dem Anbieter der Domain steht
relayhost = [SMARTHOST]
smtp_sasl_auth_enable = yes
smtp_sasl_security_options = noanonymous
#This file contains the username and password of your provider
smtp_sasl_password_maps = hash:/usr/syno/mailstation/etc/saslpasswd
#Uncomment the following line to get debug output in case of problems with the smarthost
#debug_peer_list = SMARTHOST
Und so legst hinterlegst du dann noch die Zugangsdaten für den mailserver von dem mailserver (aus dem wiki):
Next edit the password file which contains the username and password of the smtp server of your provider
vi /usr/syno/mailstation/etc/saslpasswd
Create one line with the smarthost that you selected in the main.cf and then add the username and password of your provider.
SMARTHOST USERNAME:pASSWORD
You have to create .db files of the saslpasswd file and the aliases files, so that postfix can read it (you have to repeat this everytime you change the saslpasswd file).
/usr/syno/mailstation/sbin/postmap /usr/syno/mailstation/etc/saslpasswd
Achja und damit du Zarafaseitig "sauber" bist, solltest du nen neuen User anlegen der die Emailadresse hat die du später auch nutzen möchtest (das ist dann die Standardabsenderadresse). Man kann diese bestimmt auch ändern, das kommando dazu ist mir aber gerade nicht geläufig.
placebofan86
15. Feb 2011
echt: das password muss im klartext auf der box sein? gibt es da keine andere möglichkeit? ist das nicht gefährlich.
Jdo2002
24. Dez 2011
Du hast auch deine ganzen Mails auf der Box.Postfix muss sich ja irgendwie an dem Mailserver anmelden. Du kannst die saslpasswd ja wieder löschen - für postfix ist meine ich nur die .db Datei wichtig. Ich glaube aber nicht das die unbedingt verschlüsselt ist.
placebofan86
15. Feb 2011
ach postfix erstellt dann aus der datei eine .db datei für sich? habe ich das so richtig verstanden?
Jdo2002
24. Dez 2011
Jo das macht der Befehl postmap:
DESCRIPTION
The postmap(1) command creates or queries one or more
Postfix lookup tables, or updates an existing one.
Aber wie gesagt auch die Datei ist nicht verschlüsselt nur in einem für postfix lesbaren Format.
placebofan86
15. Feb 2011
ich habe versucht das zu machen was du mir geschrieben ahst mit dem smtp.live.com als smarthost
kommen aber noch immer keine mails aus zarafa an eine andere adresse log:
Mar 16 21:54:46 postfix/smtpd[4132]: connect from localhost[127.0.0.1]
Mar 16 21:54:46 postfix/smtpd[4132]: C495012625D2: client=localhost[127.0.0.1]
Mar 16 21:54:46 postfix/cleanup[4135]: C495012625D2: message-id=<zarafa.4f63a895.1018.3f084f122bfaaebc@meineBox>
Mar 16 21:54:46 postfix/smtpd[4132]: disconnect from localhost[127.0.0.1]
Mar 16 21:54:46 postfix/qmgr[4037]: C495012625D2: from=<name.nach@hotmail.de>, size=1930, nrcpt=1 (queue active)
Mar 16 21:54:48 postfix/smtp[4136]: C495012625D2: to=<name.nach@hotmail.de>, relay=smtp.live.com[65.55.162.200]:25, delay=1.7, delays=0.35/0.63/0.56/0.12, dsn=5.7.0, status=bounced (host smtp.live.com[65.55.162.200] said: 530 5.7.0 Must iss
u
Mar 16 21:54:49 postfix/cleanup[4135]: EB03212625D4: message-id=<20120316205448.EB03212625D4@meineBox>
Mar 16 21:54:49 postfix/bounce[4141]: C495012625D2: sender non-delivery notification: EB03212625D4
Mar 16 21:54:49 postfix/qmgr[4037]: EB03212625D4: from=<>, size=3829, nrcpt=1 (queue active)
Mar 16 21:54:49 postfix/qmgr[4037]: C495012625D2: removed
Mar 16 21:54:49 postfix/smtp[4136]: EB03212625D4: to=<name.nach@hotmail.de>, relay=smtp.live.com[65.55.162.200]:25, delay=0.67, delays=0.13/0/0.42/0.12, dsn=5.7.0, status=bounced (host smtp.live.com[65.55.162.200] said: 530 5.7.0 Must issue
Mar 16 21:54:49 postfix/qmgr[4037]: EB03212625D4: removed
main:
#home_mailbox = Mailbox
#home_mailbox = Maildir/
#home_mailbox = .Maildir/
mailbox_transport = zarafa:
local_recipient_maps =
zarafa_destination_recipient_limit = 1
#information which domains are served by this postfix installation
myhostname = meinebox.dsmynas.com
mydomain = meinebox.dsmynas.com
myorigin = $mydomain
mydestination = meinebox.dsmynas.com, $myhostname.local, localhost, $mydomain
smtpd_recipient_restrictions = permit_mynetworks, reject_unknown_recipient_domain, permit_sasl_authenticated, reject_unauth_destination
default_privs = guest
#Change SMARTHOST to the mailserver of your provider (the [] are important, do not remove them!)
#Example: smtp.mail.yahoo.de
relayhost = smtp.live.com
smtpd_sasl_type=cyrus
smtpd_sender_restrictions = reject_unknown_address
# The mail_spool_directory parameter specifies the directory where
# UNIX-style mailboxes are kept. The default setting depends on the
# system type.
#mail_spool_directory = /var/mail
#mail_spool_directory = /var/spool/mail
