- 04. Apr. 2013
Hallo
beim Erstellen des Zertifikats erhalte ich eine Fehlermeldung die mir leider keinen Aufschluss darueber gibt wo das Problem ist. Hat von euch einer einen Tipp wo ich suchen soll>
Vielen Dank
Dreamoffice
DS413j> openssl req -new -x509 -extensions v3_ca -keyout private/cakey.pem
Generating a 1024 bit RSA private key
writing new private key to 'private/cakey.pem'
Enter PEM pass phrase:
Verifying - Enter PEM pass phrase:
You are about to be asked to enter information that will be incorporated
into your certificate request.
What you are about to enter is what is called a Distinguished Name or a DN.
There are quite a few fields but you can leave some blank
For some fields there will be a default value,
If you enter '.', the field will be left blank.
Country Name (2 letter code) [AU]roblems making Certificate Request
Vielen Dank
Dreamoffice
