Fetchmail Deamon - Meldungen
wolfda
14. Feb 2012
habe zwei nette Mails vom Fetchmail Deamon bekommen:
"Fetchmail could not get mail from ***.de.
The attempt to get authorization failed.
Since we have already succeeded in getting authorization for this
connection, this is probably another failure mode (such as busy server)
that fetchmail cannot distinguish because the server didn't send a useful
error message.
However, if you HAVE changed your account details since starting the
fetchmail daemon, you need to stop the daemon, change your configuration
of fetchmail, and then restart the daemon.
The fetchmail daemon will continue running and attempt to connect
at each cycle. No future notifications will be sent until service
is restored.
The Fetchmail Daemon"
Weiß jemand wo da das Problem liegt - bisher funktionierte alles wunderbar.
jahlives
19. Aug 2008
hast du allenfalls zu häufig die Mails abgefragt und der Provider hat den Account gesperrt? Oder stimmen deine Zugangsdaten nicht mehr?
wolfda
14. Feb 2012
Die Zugangsdaten sind korrekt. Die Mails werden alle 5 Minuten abgefragt.
jahlives
19. Aug 2008
alle 5min kann je nach Provider auch zu oft sein
Basalt
06. Mai 2012
Maybe kicking in an open door:
First try fetching e-mail with your PC, without using Syno at all.
If this works properly, use same settings on your Syno.
/Erik.
