FTP zu FTP Server mit FXP
ktm300
30. Dez 2009
ich versuche gerade eine FTP-Verbindung mit Flashfxp von meiner Dreambox zur DS 110j herzustellen.
Die Anmeldung an beide Rechner funktioniert. Beim Datentransfer wird aber immer nur der Dateinamen geschrieben und dann bricht die Verbindung ab. D.h. die Daten kommen nicht an.
Auszug aus dem log:
[R] Verbinde zu dreambox -> IP=192.168.2.32 PORT=21
[R] Verbunden mit dreambox
[R] 220 Welcome to the OpenDreambox FTP service.
[R] USER root
[R] 331 Please specify the password.
[R] PASS (hidden)
[R] 230 Login successful.
[R] SYST
[R] 215 UNIX Type: L8
[R] FEAT
[R] 211-Features:
[R] EPRT
[R] EPSV
[R] MDTM
[R] PASV
[R] REST STREAM
[R] SIZE
[R] TVFS
[R] 211 End
[R] CWD /media/hda1
[R] 250 Directory successfully changed.
[R] PWD
[R] 257 "/media/hda1"
[L] CWD /video
[L] 250 CWD command successful.
[L] PWD
[L] 257 "/video" is current directory.
[R] TYPE I
[R] 200 Switching to Binary mode.
[L] TYPE I
[L] 200 Type set to I.
[R] PASV
[R] 227 Entering Passive Mode (192,168,2,32,98,104)
[L] PORT 192,168,2,32,98,104
[L] 200 PORT command successful.
[L] STOR gemini.epg.dat.autosave
[L] 150 Opening BINARY mode data connection for 'gemini.epg.dat.autosave'.
[R] RETR gemini.epg.dat.autosave
[R] 425 Security: Bad IP connecting.
[L] 226 Transfer complete.
[R] ABOR
[R] 500 Unknown command.
[L] ABOR
[L] 500 ÿôÿòÿòABOR: command not understood.
[L] Übertragung fehlgeschlagen!
[L] TYPE A
[L] 200 Type set to A.
[L] PASV
[L] 227 Entering Passive Mode (192,168,2,2,217,11)
[L] Öffne Datenkanal-IP: 192.168.2.2 PORT: 55563
[L] LIST -al
[L] 150 Opening BINARY mode data connection for 'file list'.
[L] Verzeichnis geladen: 642 Bytes in 0,06 Sekunde(n) (10,0 KB/s)
[R] TYPE A
[R] 200 Switching to ASCII mode.
[R] PASV
[R] 227 Entering Passive Mode (192,168,2,32,117,169)
[R] Öffne Datenkanal-IP: 192.168.2.32 PORT: 30121
[R] LIST -al
[R] 150 Here comes the directory listing.
[R] 226 Directory send OK.
[R] Verzeichnis geladen: 754 Bytes in 0,13 Sekunde(n) (5,9 KB/s)
Übertragung von Warteschlange komplett
1 Datei(en) nicht übertragen
Vielleicht kann jemand helfen ?
Danke
KTM300
karl2014
19. Apr 2009
FlashFXP is a FTP (File Transfer Protocol) client for Windows.
Ich glaube nicht dass du damit zwei Linux-Rechner verbinden kannst.
stevechief
26. Jul 2008
Server -> Server geht mit FlashFXP leider nicht.
Kleinen Trick gibt es allerdings: Zielordner ner DS im Arbeitsplatz als virtuelles Laufwerk anlegen.
Dann kannst du Quasi von Dreambox auf das Lokale Laufwerk bzw andersherum kopieren.
MFG Stefan
Matthieu
03. Nov 2008
Kann eine Dreambox nicht NFS? Ich glaube einige hier haben es mit "mount" schon geschafft.
MfG Matthieu
ktm300
30. Dez 2009
Danke für die Hilfe.
1. Dreambox kann kein fxp bzw. der FTP-Server :-(
Meine Lösung:
per ftp auf die Dreambox dann per Midnight Commander eine FTP Verbindung zur DS.
Wichtig war das der ganze Transfer nicht noch über einen PC gezogen werden muß !
Grüsse von Niederrhein
KTM300
PS: Viele Wege führen nach Rom !
jahlives
19. Aug 2008
Meine Lösung:
KTM300
Nur damit ich es verstehe: Der MC läuft auf dem PC oder der Dreambox oder der DS? Denn wenn das Teil auf dem PC läuft wird wohl der Transfer Dreambox-PC-DS laufen
ktm300
30. Dez 2009
Also:
per ftp auf die Dreambox, dann auf der Dreambox MC gestartet und mit MC dann per ftp auf die DS !
Lauft perfekt !
Gruss
ktm300
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
ich denke Du meinst
per ssh auf die Dreambox, dann auf der Dreambox MC gestartet und mit MC dann per ftp auf die DS !
ktm300
30. Dez 2009
ich denke Du meinst
Ups ! Da hat wohl der Fehlerteufel zugeschlagen.:confused:
Per Telnet auf die Dream !
Gruss
KTM300
Bloedi
08. Jul 2009
Natürlich geht FXP-Transfer zwischen der Synology und anderen Servern.
Füge einfach in der Konfiguration des vftp auf der Dreambox "/etc/vsftpd.conf" folgende Zeile ein: pasv_promiscuous=YES
Starte dann die Box neu und Du kannst Deine Daten zwischen Synology und Dreambox mittels FXP transferieren.
Trolli
12. Jul 2007
Klasse Hinweis! Kannte ich auch noch nicht...
itari
15. Mai 2008
Kann jemand diese ganze Geschichte mal in einem Wiki-Beitrag zusammenfassen? Oder haben wir das Thema noch nicht ganz durchgekaut?
Itari
Trolli
12. Jul 2007
Dass FXP grundsätzlich mit den Synology Stations funktioniert, war ja durchaus bekannt. Neu ist lediglich die Konfiguration der Deambox für die Übertragung mit FXP. Das Problem ist aber möglicherweise doch zu speziell für einen eigenen Wiki-Eintrag...
ktm300
30. Dez 2009
Moin,
da sag ich doch vielen Dank für den Tipp. Funktioniert 1 a ! Problem gelösst :)
KTM300
