Homebridge Plugin Fehler
HaraldFuxi
17. Feb 2022
Hallo, benötige eure Hilfe und zwar habe ich lt.Anleitung Homebridge installiertauf meiner DS218.
https://github.com/oznu/homebridge-syno-spk
Soweit funktioniert die Homebridge, jedoch kann ich das Loxone-Connect Plugin nicht installieren:
Vielleicht hat jemand Rat.
USER: homebridge
DIR: /volume1/@appdata/homebridge
CMD: npm install -g homebridge-loxone-connect@latest
npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated axios@0.18.1: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
npm ERR! code 1
npm ERR! path /volume1/@appdata/homebridge/lib/node_modules/homebridge-loxone-connect/node_modules/utf-8-validate
npm ERR! command failed
npm ERR! command sh -c node-gyp-build
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@8.3.0
npm ERR! gyp info using node@16.13.2 | linux | arm64
npm ERR! gyp info find Python using Python version 3.8.8 found at "/usr/bin/python3.8"
npm ERR! gyp info spawn /usr/bin/python3.8
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/volume1/@appdata/homebridge/lib/node_modules/homebridge-loxone-connect/node_modules/utf-8-validate/build/config.gypi',
npm ERR! gyp info spawn args '/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/var/packages/homebridge/home/.cache/node-gyp/16.13.2/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/var/packages/homebridge/home/.cache/node-gyp/16.13.2',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/var/packages/homebridge/home/.cache/node-gyp/16.13.2/<(target_arch)/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/volume1/@appdata/homebridge/lib/node_modules/homebridge-loxone-connect/node_modules/utf-8-validate',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: not found: make
npm ERR! gyp ERR! stack at getNotFoundError (/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/which/which.js:10:17)
npm ERR! gyp ERR! stack at /volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/which/which.js:57:18
npm ERR! gyp ERR! stack at new Promise (<anonymous>)
npm ERR! gyp ERR! stack at step (/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/which/which.js:54:21)
npm ERR! gyp ERR! stack at /volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/which/which.js:71:22
npm ERR! gyp ERR! stack at subStep (/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/which/which.js:69:33)
npm ERR! gyp ERR! stack at /volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/which/which.js:80:22
npm ERR! gyp ERR! stack at /volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/isexe/index.js:42:5
npm ERR! gyp ERR! stack at /volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
npm ERR! gyp ERR! System Linux 4.4.180+
npm ERR! gyp ERR! command "/volume1/@appstore/homebridge/app/bin/node" "/volume1/@appstore/homebridge/app/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd /volume1/@appdata/homebridge/lib/node_modules/homebridge-loxone-connect/node_modules/utf-8-validate
npm ERR! gyp ERR! node -v v16.13.2
npm ERR! gyp ERR! node-gyp -v v8.3.0
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in:
npm ERR! /var/packages/homebridge/home/.npm/_logs/2022-02-17T07_45_16_197Z-debug.log
Command failed. Please review log for details.
HaraldFuxi
17. Feb 2022
EDIT:
Hat sich erledigt. Musste noch den Punkt erledigen:
Enable Compiling Of Native Modules​
