ipkg auf ds212+ funktioniert nicht
noyse
09. Jan 2012
Hallo
kurz knapp das was ich gemacht habe:
bootstrap:
For Marvel Kirkwood mv6282 ARM models (which are compatible with the mv6281 for as far as we can tell) a modified syno-mvkw-bootstrap_1.2-7_arm.xsh with a bit more relaxed CPU checking: http://wizjos.endofinternet.net/synology/archief/syno-mvkw-bootstrap_1.2-7_arm-ds111.xsh which uses http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/unstable/ as its feed. quelle: http://forum.synology.com/wiki/inde...rver,_bootstrap,_ipkg_etc#How_to_install_ipkg
installation läuft so weit ohne weitere probleme durch.
Solange ich nicht neustarte hab ich auch ipkg. nach dem obligatorischen reboot nicht mehr
BusyBox v1.16.1 (2012-01-13 21:18:15 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
DiskStation> ipkg
-ash: ipkg: not found
DiskStation>
ein ll zeigt folgendes:
DiskStation> cd /
DiskStation> ll
drwxr-xr-x   22 root     root          4096 Feb 10 07:00 .
drwxr-xr-x   22 root     root          4096 Feb 10 07:00 ..
drwxr-xr-x    3 root     root          4096 Feb  7 21:23 .old_patch_info
-rw-------    1 root     root          1024 Feb 25  2011 .rnd
drwxr-xr-x    3 root     root          4096 Feb  7 21:21 .syno
drwxr-xr-x    2 root     root          4096 Feb 25  2011 .system_info
-rw-rw-rw-    1 root     root        129078 Jan 29 22:18 Packages.gz
drwxr-xr-x    2 root     root          4096 Feb  7 21:23 bin
drwxr-xr-x    9 root     root         36864 Feb 10 07:00 dev
drwxr-xr-x   16 root     root          4096 Feb 10 07:01 etc
drwxr-xr-x   14 root     root          4096 Feb 10 07:01 etc.defaults
drwxr-xr-x    2 root     root          4096 Jan 14 04:48 initrd
drwxr-xr-x   16 root     root         20480 Feb  7 21:47 lib
lrwxrwxrwx    1 root     root            11 Feb  7 21:23 linuxrc -> bin/busybox
drwx------    2 root     root          4096 Jan 14 04:40 lost+found
drwxr-xr-x    2 root     root          4096 Jan 14 04:38 mnt
lrwxrwxrwx    1 root     root            17 Feb  9 22:05 opt -> /volume1/@optware
-rw-rw-rw-    1 root     root             0 Feb  7 21:40 postinst.txt
dr-xr-xr-x  120 root     root             0 Jan  1  1970 proc
drwxr-xr-x    3 root     root          4096 Feb  9 22:17 root
drwxr-xr-x    2 root     root          4096 Feb  7 21:23 sbin
drwxr-xr-x   11 root     root             0 Jan  1  1970 sys
drwxrwxrwt   10 root     root          1140 Feb 10 10:22 tmp
drwxr-xr-x    8 root     root          4096 Feb  7 21:23 usr
drwxr-xr-x   13 root     root          4096 Feb 10 07:01 var
drwxr-xr-x   11 root     root          4096 Feb  7 21:23 var.defaults
drwxr-xr-x   19 root     root          4096 Feb 10 07:00 volume1
DiskStation>
/opt/bin/ipkg zeigt mir folgendes:
ipkg: ipkg must have one sub-command argument
ipkg version 0.99.163
usage: ipkg [options...] sub-command [arguments...]
where sub-command is one of:
scheint also grundsätzlich installiert.
problem ist aber auch wenn ich folgendes aufrufe:
Downloading http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/unstable/Packages.gz
ipkg: /opt/ipkg-vYduna/Packages.gz: No such file or directory
file_copy: ERROR: failed to copy /opt/ipkg-vYduna/Packages.gz to /tmp/ipkg.UWH9Na/cross.gz
An error ocurred, return value: 1.
Hat jemand vielleicht eine tolle Idee wie ich nun das ipkg zum arbeiten bewegen kann?
Trolli
12. Jul 2007
Welche Firmware benutzt Du auf Deiner DS?
noyse
09. Jan 2012
mist doch infos vergessen ;)
dsm 4.0 Beta
Das komische bis vor kurzem lief ipkg bestens...hatte nur Probleme mit dem Zeitplan runterfahren (wohl wegen dem mount) also hatte ich das mount auskommentiert und dem symLink gesetzt. danach ging nix mehr udn seit zwei tagen versuche ich (leider bisher ohne erfolg) IPKG wieder zum laufen zu bewegen (inkl unzählige Neuinstallationen vom ipkg)
noyse
09. Jan 2012
ah super danke das werde ich mir zu gemüte is ja bisserl zu lesen ;)
Trolli
12. Jul 2007
Die Lösung steht in Beitrag #7 ;)
noyse
09. Jan 2012
stimmt ;) hat super funktioniert...was fürn elend zwei tage hab ich mir damit um die ohren geschlagen :(
