Ipkg ds109
fenris79
05. Mai 2008
Servus
Hab eine DS109 und versuche über PuTTY und SSH verbindung IPKG zu installieren, leider kommt eine Fehlermeldung bei der installation.
Info:
bin als Admin angemeldet
Hab blöderweise am Anfang das falsche IPKG verwendet syno-x07-bootstrap_1.2-7_arm.xsh jetzt hab ich das richtige syno-mvkw-bootstrap_1.2-7_arm.xsh
DiskStation> sh syno-mvkw-bootstrap_1.2-7_arm.xsh
Optware Bootstrap for syno-mvkw.
Extracting archive... please wait
bootstrap/
bootstrap/bootstrap.sh
bootstrap/ipkg-opt.ipk
bootstrap/ipkg.sh
bootstrap/optware-bootstrap.ipk
bootstrap/wget.ipk
1232+1 records in
1232+1 records out
Creating temporary ipkg repository...
Installing optware-bootstrap package...
Unpacking optware-bootstrap.ipk...Done.
Configuring optware-bootstrap.ipk...mkdir: Cannot create directory `/opt': Permission denied
chmod: /opt: No such file or directory
mount: Mounting /volume1/@optware on /opt failed: No such file or directory
mkdir: Cannot create directory `/opt/': Permission denied
chmod: /opt/etc: No such file or directory
chmod: /opt/var: No such file or directory
chmod: /opt/tmp: No such file or directory
chmod: /opt/lib: No such file or directory
//tmp/ipkg/info/optware-bootstrap.ipk.preinst failed. Aborting installation of optware-bootstrap.ipk
Installing ipkg...
Unpacking ipkg-opt.ipk...Done.
Configuring ipkg-opt.ipk...tar: Cannot create directory `./opt': Permission denied
tar: Cannot create directory `./opt/': Permission denied
tar: ./opt/bin/ipkg: No such file or directory
Done.
Removing temporary ipkg repository...
Installing wget...
bootstrap.sh: bootstrap.sh: 55: /opt/bin/ipkg: not found
BusyBox v1.1.0 (2009.11.12-17:45+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
DiskStation> ipkg update
/bin/sh: ipkg: not found
bootstrap/
bootstrap/ipkg.sh
bootstrap/wget.ipk
1232+1 records in
1232+1 records out
Backup your configuration settings, then type:
  rm -rf /volume1/@optware hilft leider auch nicht
  rm -rf /usr/lib/ipkg hilft leider auch nicht
This will remove all existing optware packages.
You must *reboot* and then restart the bootstrap script.
*reboot* was ist damit gemeint?
Matthieu
03. Nov 2008
Du musst dich als root anmelden. Steht aber glaube ich auch so in der Anleitung ...
MfG Matthieu
thedude
30. Nov 2009
Yap tut es. Gleich unter Punkt 1:
1. Mit Telnet als root (identisches Passwort wie admin) auf der Synology Station einloggen
Also einfach rebooten (= per DSM die DS neu starten), als root einloggen und dann nochmal der Anleitung folgen.
gruss
dude
Newman
12. Sep 2008
hi ich mach wohl auch was falsch
ich kriege die meldung
Diskstation> sh syno-mvkw-bootstrap_1.2-7_arm.xsh
bootstrap/
bootstrap/ipkg.sh
bootstrap/wget.ipk
1232+1 records in
1232+1 records out
BusyBox v1.1.0 (2010.01.25-15:59+0000) Built-in shell (ash)
Diskstation> ipkp update
/bin/sh: ipkp: not found
Diskstation>
Matthieu
03. Nov 2008
Was für eine DS hast du denn (Tip: Schreibs entweder in dein Profil, oder noch besser in deine Signatur)?
Bist du als root angemeldet?
MfG Matthieu
Newman
12. Sep 2008
ich hab die ds110j und hab die befehler schon probiert und ein reboot gemacht
aber es kommt immer noch
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
das Vorhandensein von /volume1/@optware ist das Merkmal ob das Script abbricht oder wenn es nicht vorhanden ist weiter macht
REAL_OPT_DIR=/volume1/@optware
if [ -e "$REAL_OPT_DIR" ] ; then
    echo "Backup your configuration settings, then type:"
    echo "  rm -rf $REAL_OPT_DIR"
    echo "  rm -rf /usr/lib/ipkg"
    echo "This will remove all existing optware packages."
    echo
    echo "You must *reboot* and then restart the bootstrap script."
    exit 1
also stelle sicher, daß /volume1/@optware wirklich gelöscht ist.
umount /opt
rm /etc/rc.optware
neu starten und nochmal probieren.
Newman
12. Sep 2008
ok ich hab es hin bekommen. vielen dank. es klappt nur nicht aber das wird wohl am pc liegen...
Blueyed1
11. Feb 2011
    echo
    exit 1
umount /opt
rm /etc/rc.optware
Hallo Götz
Vielleicht bist du derjenige, der mir weiter helfen kann?
Ich glaube, ich habe alles versucht, so ipkg arbeiten, aber kein Glück
In /root/.profile
DiskStation> vi /root/.profile
umask 022
#PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin
#export PATH
#This fixes the backspace when telnetting in.
#if [ "$TERM" != "linux" ]; then
#        stty erase
#fi
HOME=/root
export HOME
TERM=${TERM:-cons25}
export TERM
PAGER=more
export PAGER
PS1="`hostname`> "
alias dir="ls -al"
- /root/.profile 1/24 4%
umask 022
#PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin
#export PATH
#        stty erase
#fi
HOME=/root
export HOME
export TERM
PAGER=more
export PAGER
PS1="`hostname`> "
alias dir="ls -al"
alias ll="ls -la"
In /etc/profile
DiskStation> vi /etc/profile
#/etc/profile: system-wide .profile file for ash.
umask 022
export PATH
PATH=/opt/bin:/opt/sbin:$PATH
export PATH
#        stty erase
#fi
PGDATA=/var/services/pgsql
export PGDATA
TERMINFO=/usr/share/terminfo
export TERMINFO
export TERM
PAGER=more
export PAGER
export LC_ALL=en_US.utf8
export LANG=en_US.utf8
PS1="`hostname`> "
alias dir="ls -al"
alias ll="ls -la"
ulimit -c unlimited
Und nochmal probier
umount /opt
rm /etc/rc.optware
Und dann
cd /volume1/@tmp
--2014-05-11 20:23:51-- http://ipkg.nslu2-linux.org/feeds/optware/syno-x07/cross/unstable/syno-x07-bootstrap_1.2-7_arm.xsh
Resolving ipkg.nslu2-linux.org... 140.211.169.161
Connecting to ipkg.nslu2-linux.org|140.211.169.161|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 250349 (244K) [text/plain]
Saving to: 'syno-x07-bootstrap_1.2-7_arm.xsh'
100%[======================================================================================================>] 250,349 220KB/s in 1.1s
2014-05-11 20:23:53 (220 KB/s) - 'syno-x07-bootstrap_1.2-7_arm.xsh' saved [250349/250349]
sh syno-x07-bootstrap_1.2-7_arm.xsh
Optware Bootstrap for syno-x07.
bootstrap/
bootstrap/ipkg.sh
bootstrap/wget.ipk
1226+1 records in
1226+1 records out
Configuring optware-bootstrap.ipk...Done.
Installing ipkg...
Configuring ipkg-opt.ipk...WARNING: can't open config file: /usr/syno/ssl/openssl.cnf
Done.
Installing wget...
bootstrap.sh: line 45: /opt/bin/ipkg: not found
ln -s /volume1/@optware /opt
ipkg update
Ich weiß nicht, wo der Fehler ist, kann aber nicht zu bekommen ipkg zu laufen.
Kannst du mir helfen, danke im Voraus
/Blueyed1
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
Blueyed1
11. Feb 2011
aus Deinen anderen Beiträgen erfährt man, daß Du eine DS211+ hast. Du hast versucht ipkg für eine DS107+ zu installieren, das ist nicht kompatibel.
http://ipkg.nslu2-linux.org/feeds/o...ss/unstable/syno-mvkw-bootstrap_1.2-7_arm.xsh
ist das richtige Paket.
Also noch einmal wie oben ipkg löschen und neu installieren.
Vielen Dank für die Hilfe Götz
Du hattest Recht, es ist eine DS211 +.
Ich konnte nicht http://ipkg.nslu2-linux.org/feeds/op..._1.2-7_arm.xsh verwenden, da kam ein CPU-Fehler.
Aber du hast mich in die richtige richtung gerichtet, und ich habe diese Bootstrap statt die ander verwenden
http://forum.synology.com/wiki/index.php/Overview_on_modifying_the_Synology_Server,_bootstrap,_ipkg_etc
For Marvel Kirkwood mv6282 ARM models (which are compatible with the mv6281 for as far as we can tell) a modified syno-mvkw-bootstrap_1.2-7_arm.xsh with a bit more relaxed CPU checking: http://web.archive.org/web/20121005...chief/syno-mvkw-bootstrap_1.2-7_arm-ds111.xsh which uses http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/unstable/ as its feed.
Jetzt funktioniert wieder ipkg
/Blueyed1
