ja, lässt sich aufrufen. hier die Fehlermeldung nach ausführen der Aufgabe:
Aufgabe: Task 9
Startzeit: Tue, 13 Jun 2017 15:47:29 GMT
Stoppzeit: Tue, 13 Jun 2017 15:47:30 GMT
Aktueller Status: 0
Standardausgabe/Fehler:
DEBUG: Issuer name of certificate. [Let's Encrypt]->[/usr/syno/etc/certificate/_archive/eQmDlw/cert.pem]
DEBUG: start to renew [/usr/syno/etc/certificate/_archive/eQmDlw].
DEBUG: setup acme url
https://acme-v01.api.letsencrypt.org/directory
DEBUG: szUserAgent: [synology_armada370_114 DSM6.1-15101 Update 4 (DDNS)]
DEBUG: GET Request:
DEBUG: Curl Reply: [200] Header: [HTTP/1.1 200 OK
Server: nginx
Content-Type: application/json
Content-Length: 352
Boulder-Request-Id: 1i229oHQ5DT7BIoh9nFFPnN8hlyDh8WjLPAyhDSfK0g
Replay-Nonce: asjaQGfBGLkzHZD7BDjiNUeGg77fTRYI4TI9MHKNRy8
X-Frame-Options: DENY
Strict-Transport-Security: max-age=604800
Expires: Tue, 13 Jun 2017 13:47:30 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Tue, 13 Jun 2017 13:47:30 GMT
Connection: keep-alive
] Body: [{
"key-change": "https://acme-v01.api.letsencrypt.org/acme/key-change",
"new-authz": "https://acme-v01.api.letsencrypt.org/acme/new-authz",
"new-cert": "https://acme-v01.api.letsencrypt.org/acme/new-cert",
"new-reg": "https://acme-v01.api.letsencrypt.org/acme/new-reg",
"revoke-cert": "https://acme-v01.api.letsencrypt.org/acme/revoke-cert"
DEBUG: strat to do new-authz for blabla.myfritz.net
DEBUG: ==> start new authz.
DEBUG: new authz: do new-authz.
DEBUG: Post JWS Request:
DEBUG: Post JWS value: {
"identifier" : {
"type" : "dns",
"value" : "blabla.myfritz.net"
"resource" : "new-authz"
DEBUG: Post Request:
DEBUG: Post value: {
"header" : {
"alg" : "RS256",
"jwk" : {
"e" : "AQAB",
"kty" : "RSA",
"n" : "yE_EXElfkyPe8QV5ewRlHyEgR-nqQwqt7WR12SHPgO-wTO0lKZ3RsSAQ_hUSWmfHCX9vUkjwGVNqsx1cXbNDtOL4QFm4NjCPs8Y59XzvhmYe3kG6Eo_ZHsUZEbBtkiVSe7KfCCFoxCKM-dcqGufXErk6hnrcocWyv44mQfVaGpwU52wIrFkkyi1ceK-6fiU0qmb-Xyn67DQRNOKwVEg9zvpAHRg4LjhF6x-HcJTV1YPqsB0W0xRVQ2LoT9Kg8QqknICAGVaz2Q7lDDVZaHrB3Th8wx7MBCJestDFVCbyMzUImqZ8uWXWqJLrsyo7AfJnSleZ4-O_QdafOOqxF22Rzw"
"payload" : "eyJpZGVudGlmaWVyIjp7InR5cGUiOiJkbnMiLCJ2YWx1ZSI6Ink4ZTkxa3l0eTNybHVuZmEubXlmcml0ei5uZXQifSwicmVzb3VyY2UiOiJuZXctYXV0aHoifQo",
"protected" : "eyJub25jZSI6ImFzamFRR2ZCR0xrekhaRDdCRGppTlVlR2c3N2ZUUllJNFRJOU1IS05SeTgifQo",
"signature" : "UIpBYRxSKZirSD0J4qVjXpGbCS4B96-oDiFS_WSRHZ7t-T5UF9N7BS5S3Y4Jen_AqXyweeKMjFVn7eWnFa9u0yUythSHz92QdY1YawcM1AffekXKoAxQYxRa7ADPbijWZCzOUwdEGn2TUq1TUc3jc-76pQ1_-kcM_ywre6K8rDMYWt7fAp5N4mgVbvI-Drz5xNfVKwdCMxCDmuZRPMYP_4f8v6RuCMotSv03ILyw9h4AXk4dY9p3han7YuQQOgRR_nXE2szEwbo96Lpicd1NgWjP5U-WgfbXoIwG9Uhd5HlHytYNj7fCvNp_Vj8fUqwRyz0A7EMe12GSxsDQUJw6SQ"
DEBUG: Curl Reply: [429] Header: [HTTP/1.1 429 Unknown
Server: nginx
Content-Type: application/problem+json
Content-Length: 144
Boulder-Request-Id: m3WN-7eweqOnaw5wKz8j7qXWH4roAajZ_bT9ysoxI7o
Boulder-Requester: 2772864
Replay-Nonce: bvdRCq94ZEmOBBMKIx29Sk5p_AQ_pnAJMfEU_i6LgK0
Pragma: no-cache
Connection: close
] Body: [{
"type": "urn:acme:error:rateLimited",
"detail": "Error creating new authz :: Too many invalid authorizations recently.",
"status": 429
DEBUG: Not synology DDNS.
DEBUG: DNS challenge failed, reason: {"error":108,"file":"challenge.cpp","msg":"Not synology DDNS."}
DEBUG: Normal challenge failed, reason: {"error":200,"file":"client.cpp","msg":"new_authz: unexpect httpcode."}
