Hello, I made an account here because english Synology forums doesn't have a data recovery section. So I'm hoping someone here understands english and can point me in the right direction.
To make long story short, I was adding a new disk to a 3 disk SHR array, and at the start of adding disk it gave me error. I figured I'd reboot and try again, but it got stuck shutting down. So after waiting for a while I hard powered off. Powered back on and data volume was gone. I just made some great progress today with help of someone experienced in data recovery (Remy), but could use some help from people familiar with synology systems.
DiskStation> fdisk -l
I'm not sure where that fat partition (sda3) came from or what it is.
Using testdisk, partition table none, no alignment, I was able to find my data partition (Diskstation:2):
I then calculated offset for Diskstation:2 partition, and used losetup:
Examine new loop devices.
Assembled new array:
I don't know what I need to do next. Does this all look okay? Can anyone tell me what to do next?
Danke
Disk /dev/sda: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 311 2490240 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary
/dev/sda2 311 572 2097152 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary
/dev/sda3 588 243201 1948788912 f Win95 Ext'd (LBA)
Disk /dev/sdc: 2000.3 GB, 2000398934016 bytes
/dev/sdc1 1 311 2490240 fd Linux raid autodetect
/dev/sdc2 311 572 2097152 fd Linux raid autodetect
Disk /dev/sdb: 2000.3 GB, 2000398934016 bytes
/dev/sdb1 1 311 2490240 fd Linux raid autodetect
/dev/sdb2 311 572 2097152 fd Linux raid autodetect
Results
P ext4 0 4 5 310 7 17 4980352 [1.42.6-3202]
ext4 blocksize=4096 Large file Sparse superblock, 2549 MB / 2431 MiB
P Linux md 0.9 RAID 0 4 5 310 9 19 4980480 [md0]
md 0.90.0 B.Endian Raid 1: devices 0(8,1)* 1(8,17) 2(8,33), 2550 MB / 2431 MiB
P Linux SWAP 2 310 9 20 571 28 17 4194160
SWAP2 version 1, pagesize=4096, 2147 MB / 2047 MiB
P Linux md 0.9 RAID 310 9 20 571 30 35 4194304 [md1]
md 0.90.0 B.Endian Raid 1: devices 0(8,2)* 1(8,18) 2(8,34), 2147 MB / 2048 MiB
P Linux md 1.x RAID 588 112 5 243200 72 48 3897559304 [DiskStation:2]
md 1.x L.Endian Raid 5 - Array Slot : 0 (0, 1, 2, failed, failed, failed), 1995 GB / 1858 GiB
interface_write()
CHS to LBA = (588*255*63)+(112*63)+(5-1) = 9453280
Offset in bytes = 9453280*512 = 4840079360
DiskStation> losetup -o 4840079360 /dev/loop1 /dev/sda
DiskStation> losetup -o 4840079360 /dev/loop2 /dev/sdb
DiskStation> losetup -o 4840079360 /dev/loop3 /dev/sdc
/dev/loop1: 545112064 /dev/sda
/dev/loop2: 545112064 /dev/sdb
/dev/loop3: 545112064 /dev/sdc
DiskStation> mdadm --examine /dev/loop[1-3]
/dev/loop1:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : c7ac0e55:5cb2e968:b09f83b2:85b6356e
Name : DiskStation:2 (local to host DiskStation)
Creation Time : Sun May 19 18:10:54 2013
Raid Level : raid5
Raid Devices : 3
Avail Dev Size : 3897559680 (1858.50 GiB 1995.55 GB)
Array Size : 7795118592 (3717.00 GiB 3991.10 GB)
Used Dev Size : 3897559296 (1858.50 GiB 1995.55 GB)
Data Offset : 2048 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 26c354ea:9679fee7:b4337841:8d291201
Update Time : Tue Jun 11 12:00:06 2013
Checksum : 2a2f9fe9 - correct
Events : 18
Layout : left-symmetric
Chunk Size : 64K
Device Role : Active device 0
Array State : AAA ('A' == active, '.' == missing)
/dev/loop2:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 3
State : clean
Device UUID : e48bfdb6:7f6d61e8:3ba638d8:2f633966
Checksum : f32308ba - correct
Events : 18
Chunk Size : 64K
Device Role : Active device 1
/dev/loop3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 3
State : clean
Device UUID : dd8e1640:c64f0593:bbf07fd2:e4bca4ff
Checksum : ba929230 - correct
Events : 18
Chunk Size : 64K
Device Role : Active device 2
DiskStation> mdadm -A /dev/md2 /dev/loop1 /dev/loop2 /dev/loop3
mdadm: /dev/md2 has been started with 3 drives.
DiskStation> cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 loop1[0] loop3[2] loop2[1]
3897559296 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
md1 : active raid1 sda2[0] sdb2[1] sdc2[2]
2097088 blocks [12/3] [UUU_________]
md0 : active raid1 sda1[0] sdb1[1] sdc1[2]
2490176 blocks [12/3] [UUU_________]
unused devices: <none>
DiskStation>
DiskStation> vgdisplay
--- Volume group ---
VG Name vg1000
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 2
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 0
Max PV 0
Cur PV 1
Act PV 1
VG Size 3.63 TB
PE Size 4.00 MB
Total PE 951552
Alloc PE / Size 951552 / 3.63 TB
Free PE / Size 0 / 0
VG UUID 6Lf9E0-Uruw-vS94-vaQn-TyxN-35a4-awlTUI
DiskStation> pvdisplay
--- Physical volume ---
PV Name /dev/md2
VG Name vg1000
PV Size 3.63 TB / not usable 2.25 MB
Allocatable yes (but full)
PE Size (KByte) 4096
Total PE 951552
Free PE 0
Allocated PE 951552
PV UUID n5I8mM-3o67-f411-xnzi-lmr5-uh09-bnhpVr
DiskStation> lvdisplay
--- Logical volume ---
LV Name /dev/vg1000/lv
VG Name vg1000
LV UUID YGWx0P-vbWP-wHmD-4Cqs-h8R5-sKQy-Ol2GBp
LV Write Access read/write
LV Status NOT available
LV Size 3.63 TB
Current LE 951552
Segments 1
Allocation inherit
Read ahead sectors auto
Danke
