HDD SATA Nach Fetsplattenwechsel auf WD 3 TB Red™ BULK kein Tiefschlaf mehr
SATA HDD
klausm
23. Dez 2013
Hallo Gemeinde
Die Fest - Platten ALT gegen NEU Ausgetauscht + danach gibt es kein Tiefschlaf mehr ???
Absolut nichts geändert .
Wo ist mein Ansatzpunkt ??
Definition der neuen Platten
153.434993] ata1.00: configured for UDMA/133
[ 153.454867] scsi 0:0:0:0: Direct-Access WDC WD30EFRX-68EUZN0 82.0 PQ: 0 ANSI: 5
[ 153.464342] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[ 153.472125] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 153.477551] sd 0:0:0:0: [sda] Write Protect is off
[ 153.482362] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 153.482445] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 156.461679] Delay 5 seconds to wait for disk 2 ready.
[ 157.451849] sda: sda1 sda2 sda5
[ 157.456417] sd 0:0:0:0: [sda] Attached SCSI disk
[ 163.944766] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl F300)
[ 164.144800] ata2.00: ATA-9: WDC WD30EFRX-68EUZN0, 82.00A82, max UDMA/133
[ 164.151527] ata2.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 164.174988] ata2.00: configured for UDMA/133
[ 164.194856] scsi 1:0:0:0: Direct-Access WDC WD30EFRX-68EUZN0 82.0 PQ: 0 ANSI: 5
[ 164.204318] sd 1:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[ 164.205764] physmap platform flash device: 00800000 at f0000000
[ 164.206645] physmap-flash physmap-flash.0: map_probe failed
[ 164.209342] SPI Serial flash detected @ 0xf0000000, 8192KB (128sec x 64KB)
[ 164.209369] Searching for RedBoot partition table in SYNOMTD-0 at offset 0x7f0000
[ 164.238006] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 164.243447] sd 1:0:0:0: [sdb] Write Protect is off
[ 164.248064] 6 RedBoot partitions found on MTD device SYNOMTD-0
[ 164.248073] SYNOMTD flash bank 0: Using RedBoot partition definition
[ 164.248082] Creating 6 MTD partitions on "SYNOMTD-0":
[ 164.248093] 0x000000000000-0x0000000d0000 : "RedBoot"
[ 164.270609] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 164.270729] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
kein Plan ??????????? für die Ursache bzw. Behebung !!
Wo ist die Ursache
Danke fuer Tips !
