Jun 13 21:41:16 kernel: CPU: ARM926EJ-S [56251311] revision 1 (ARMv5TE), cr=00053977
Jun 13 21:41:16 kernel: Machine: Feroceon-KW
Jun 13 21:41:16 kernel: Using UBoot passing parameters structure
Jun 13 21:41:16 kernel: Sys Clk = 200000000, Tclk = 166666667
Jun 13 21:41:16 kernel: Synology Board ID: 21
Jun 13 21:41:16 kernel: Synology Hareware Version: DS209v10-j
Jun 13 21:41:16 kernel: Internal HD num: 2
Jun 13 21:41:16 kernel: Internal netif num: 1
Jun 13 21:41:16 kernel: Memory policy: ECC disabled, Data cache writeback
Jun 13 21:41:16 kernel: CPU0: D VIVT write-back cache
Jun 13 21:41:16 kernel: CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Jun 13 21:41:16 kernel: CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Jun 13 21:41:16 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Jun 13 21:41:16 kernel: PID hash table entries: 1024 (order: 10, 4096 bytes)
Jun 13 21:41:16 kernel: Console: colour dummy device 80x30
Jun 13 21:41:16 kernel: Mount-cache hash table entries: 512
Jun 13 21:41:16 kernel: CPU Interface
Jun 13 21:41:16 kernel: -------------
Jun 13 21:41:16 kernel: SDRAM_CS0 ....base 00000000, size 128MB
Jun 13 21:41:16 kernel: SDRAM_CS1 ....base 08000000, size 128MB
Jun 13 21:41:16 kernel: SDRAM_CS2 ....disable
Jun 13 21:41:16 kernel: SDRAM_CS3 ....disable
Jun 13 21:41:16 kernel: PEX0_MEM ....base e8000000, size 128MB
Jun 13 21:41:16 kernel: PEX0_IO ....base f2000000, size 1MB
Jun 13 21:41:16 kernel: INTER_REGS ....base f1000000, size 1MB
Jun 13 21:41:16 kernel: NFLASH_CS ....base fa000000, size 2MB
Jun 13 21:41:16 kernel: SPI_CS ....base f8000000, size 4MB
Jun 13 21:41:16 kernel: BOOT_ROM_CS ....no such
Jun 13 21:41:16 kernel: DEV_BOOTCS ....no such
Jun 13 21:41:16 kernel: CRYPT_ENG ....base f0000000, size 2MB
Jun 13 21:41:16 kernel: Detected Tclk 200000000 and SysClk 400000000
Jun 13 21:41:16 kernel: Marvell USB EHCI Host controller #0: cfc37200
Jun 13 21:41:16 kernel: cesadev_init(c001185c)
Jun 13 21:41:16 kernel: mvCesaInit: sessions=10240, queue=64, pSram=f0000000
Jun 13 21:41:16 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jun 13 21:41:16 kernel: RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Jun 13 21:41:16 kernel: Load Marvell Ethernet Driver
Jun 13 21:41:16 kernel: o Cached descriptors in DRAM
Jun 13 21:41:16 kernel: o DRAM SW cache-coherency
Jun 13 21:41:16 kernel: RX Queue support - ETH_DEF_RXQ=0
Jun 13 21:41:16 kernel: o Single TX Queue support - ETH_DEF_TXQ=0
Jun 13 21:41:16 kernel: o TCP segmentation offload enabled
Jun 13 21:41:16 kernel: o Receive checksum offload enabled
Jun 13 21:41:16 kernel: o Transmit checksum offload enabled
Jun 13 21:41:16 kernel: o Rx descripors: q0=128
Jun 13 21:41:16 kernel: o Tx descripors: q0=532
Jun 13 21:41:16 kernel: o Loading network interface:
Jun 13 21:41:16 kernel: eth0
Jun 13 21:41:16 kernel: Driver 'sd' needs updating - please use bus_type methods
Jun 13 21:41:16 kernel: Integrated Sata device found
Jun 13 21:41:16 kernel: Delay 10 seconds to wait for disk 1 ready.
Jun 13 21:41:16 kernel: Delay 10 seconds to wait for disk 2 ready.
Jun 13 21:41:16 kernel: SPI Serial flash detected @ 0xf8000000, 4096KB (64sec x 64KB)
Jun 13 21:41:16 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
J
