nach router update kein vpn mehr
ottosykora
17. Apr 2013
Der Provider hat ein Update auf den Modems durchgeführt. Was neu ist weiss niemand.
Nachdem nun sonst alles zu funktionieren scheint, versuche ich VPN. Geht nicht. Auch PPTP geht nicht.
Der OVPN macht im Log:
Enter Management Password:
Thu Nov 14 08:59:42 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Thu Nov 14 08:59:42 2013 Need hold release from management interface, waiting...
Thu Nov 14 08:59:43 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Thu Nov 14 08:59:43 2013 MANAGEMENT: CMD 'state on'
Thu Nov 14 08:59:43 2013 MANAGEMENT: CMD 'log all on'
Thu Nov 14 08:59:43 2013 MANAGEMENT: CMD 'hold off'
Thu Nov 14 08:59:43 2013 MANAGEMENT: CMD 'hold release'
Thu Nov 14 08:59:52 2013 MANAGEMENT: CMD 'username "Auth" "admin"'
Thu Nov 14 08:59:52 2013 MANAGEMENT: CMD 'password [...]'
Thu Nov 14 08:59:53 2013 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Nov 14 08:59:53 2013 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Nov 14 08:59:54 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Nov 14 08:59:54 2013 MANAGEMENT: >STATE:1384415994,RESOLVE,,,
Thu Nov 14 08:59:55 2013 UDPv4 link local (bound): [undef]
Thu Nov 14 08:59:55 2013 UDPv4 link remote: [AF_INET]92.107.115.169:1194
Thu Nov 14 08:59:55 2013 MANAGEMENT: >STATE:1384415995,WAIT,,,
Thu Nov 14 08:59:55 2013 MANAGEMENT: >STATE:1384415995,AUTH,,,
Thu Nov 14 08:59:55 2013 TLS: Initial packet from [AF_INET]92.107.115.169:1194, sid=056c675e 34033622
Thu Nov 14 08:59:55 2013 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Thu Nov 14 08:59:55 2013 VERIFY OK: depth=1, C=CH, ST=BS, L=Basel, O=ORG, OU=NET, CN=OttoSykora, emailAddress=ottosykora@xxx.xx
Thu Nov 14 08:59:55 2013 VERIFY OK: depth=0, C=XY, ST=Snake Desert, L=Snake Town, O=Snake Oil, Ltd, OU=Certificate Authority, CN=Snake Oil CA, emailAddress=ca@snakeoil.dom
Thu Nov 14 08:59:56 2013 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Thu Nov 14 08:59:56 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Nov 14 08:59:56 2013 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Thu Nov 14 08:59:56 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Nov 14 08:59:56 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Thu Nov 14 08:59:56 2013 [Snake Oil CA] Peer Connection Initiated with [AF_INET]92.107.115.169:1194
Thu Nov 14 08:59:57 2013 MANAGEMENT: >STATE:1384415997,GET_CONFIG,,,
Thu Nov 14 08:59:59 2013 SENT CONTROL [Snake Oil CA]: 'PUSH_REQUEST' (status=1)
Thu Nov 14 08:59:59 2013 PUSH: Received control message: 'PUSH_REPLY,route 192.168.110.0 255.255.255.0,route 10.8.0.0 255.255.255.0,dhcp-option DNS 192.168.110.1,route 10.8.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.8.0.6 10.8.0.5'
Thu Nov 14 08:59:59 2013 OPTIONS IMPORT: timers and/or timeouts modified
Thu Nov 14 08:59:59 2013 OPTIONS IMPORT: --ifconfig/up options modified
Thu Nov 14 08:59:59 2013 OPTIONS IMPORT: route options modified
Thu Nov 14 08:59:59 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Nov 14 08:59:59 2013 MANAGEMENT: Client disconnected
Thu Nov 14 08:59:59 2013 There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> OpenVPN -> Add a new TAP-Windows virtual ethernet adapter.
Thu Nov 14 08:59:59 2013 Exiting due to fatal error
fpo4711
26. Mai 2010
deine Fehlermeldung hat normalerweise überhaupt nichts mit Router oder VPN-Server zu tun. Hast Du vieleicht zusammen mit dem neuen Router noch irgendwelche Sicherheitssoftware installiert o.ä.
Jedenfalls besagt deine Fehlermeldung das dein Client kein tap-device erstellen kann. Meistens ist das auf irgendwelche Sicherheitssoftware zurückzuführen. Google mal nach dieser Fehlermeldung und Du wirst einiges an Checkpunkten finden. Den Clienten auch "als Administrator" ausgeführt?
Gruß Frank
ottosykora
17. Apr 2013
also es geht wieder.
Nein keine Sicherheitssoftware habe ich installiert, was der Provider in den Router installiert hat weiss ich nicht.
Administrator , ja , das habe ich mittlerweile im Griff
Aber dann habe ich die Zeile im Log bis Ende gelesen und genau das gemacht was die dort schreiben, in der Tat, im Startmenu von w7 ist der Punkt mit den TAP drin, dort sind zwei Scripte verlinkt, eines ist offenbar dafür da um einen neuen TAP zu erstellen. Das ausgeführt, ging etwas hin und her, hat im CMD dies und jenes geschrieben, am Schluss dann noch geschrieben ein TAP wurde erfolgreich erstellt.
Danach ging alles wieder wie vorher.
Warum es früher ging und jetzt plötzlich nicht mehr weiss ich nicht, hat aber offenbar nichts mit dem Update des Routers zu tun, nur mit dem PC von dem aus ich die Verbindung gemacht habe.
Magic: danach nochmal PPTP versucht, selbst das ging auch weider.
