Nach update von 4.0 auf 4.3 startet zarafa Server nicht mehr
Topfgucker
23. Jan 2013
nach dem update der DSM auf 4.3 bekommt der zarafa-Server einfach keinen Zugriff auf die Datenbank mehr. Im Log findet sich:
Sat Aug 23 17:26:56 2014: SQL [00000001] Failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'END' at line 20, Query Size: 1713, Query: "CREATE PROCEDURE GetProps(IN hid integer, IN mode integer)
BEGIN
  DECLARE bestbody INT;
  IF mode = 1 THEN
         call GetBestBody(hid, bestbody);
  END IF;
  SELECT 0, tag, properties.type, val_ulong, val_string, val_binary, val_double, val_longint, val_hi, val_lo, 0, names.nameid, names.namestring, names.guid
    FROM properties LEFT JOIN names ON (properties.tag-0x8501)=names.id WHERE hierarchyid=hid AND (tag <= 0x8500 OR names.id IS NOT NULL) AND (tag NOT IN (0x1009, 0x1013) OR mode = 0 OR (mode = 1 AND tag = bestbody) )
  UNION
  SELECT count(*), tag, mvproperties.type,
          group_concat(length(mvproperties.val_ulong),':', mvproperties.val_ulong ORDER BY mvproperties.orderid SEPARATOR ''),
          group_concat(length(mvproperties.val_string),':', mvproperties.val_string ORDER BY mvproperties.orderid SEPARATOR ''),
          group_concat(length(mvproperties.val_binary),':', mvproperties.val_binary ORDER BY mvproperties.orderid SEPARATOR ''),
          group_concat(length(mvproperties.val_double),':', mvproperties.val_double ORDER BY mvproperties.orderid SEPARATOR ''),
          group_concat(length(mvproperties.val_longint),':', mvproperties.val_longint ORDER BY mvproperties.orderid SEPARATOR ''),
          group_concat(length(mvproperties.val_hi),':', mvproperties.val_hi ORDER BY mvproperties.orderid SEPARATOR ''),
          group_concat(length(mvproperties.val_lo),':', mvproperties.val_lo ORDER BY mvproperties.orderid SEPARATOR ''),
    FROM mvproperties LEFT JOIN names ON (mvproperties.tag-0x8501)=names.id WHERE hierarchyid=hid AND (tag <= 0x8500 OR names.id IS NOT NULL) GROUP BY tag, mvproperties.type;
END;
Sat Aug 23 17:26:56 2014: zarafa-server is unable to create stored procedures, error 1064
Damit startet zarafa natürlich nicht und ich bin ziemlich aufgeschmissen. Bitte, helft mir und rettet mir das Wochenende...
Topfgucker
23. Jan 2013
Hat sich erledigt. Ich habe dann doch auf DSM 5.0-4493-3 upgedatet und da läuft mein Zarafa wieder.
