smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: MG07ACA
Device Model: TOSHIBA MG07ACA14TE
Serial Number: 14B0B0BFUBWG
LU WWN Device Id: 5 000039 d09400ff8
Firmware Version: 4305
User Capacity: 14,000,519,643,136 bytes [14.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA >3.2 (0x1ff), 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Jan 10 18:00:54 2025 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Read_error_rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_up_time 0x0027 100 100 001 Pre-fail Always - 7981
4 Start/Stop_count 0x0032 100 100 000 Old_age Always - 5
5 Reallocated_sector_count 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_error_rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_time_performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power-on_hours_count 0x0032 100 100 000 Old_age Always - 34
10 Spin_retry_count 0x0033 100 100 030 Pre-fail Always - 0
12 Drive_power_cycle_count 0x0032 100 100 000 Old_age Always - 5
23 He_condition-1_(the_fall_direction) 0x0023 100 100 075 Pre-fail Always - 0
24 He_condition-2_(the_rise_direction) 0x0023 100 100 075 Pre-fail Always - 0
191 Shock_sense_count 0x0032 100 100 000 Old_age Always - 2
192 Power-off_retract_count 0x0032 100 100 000 Old_age Always - 1
193 Load/Unload_cycle_count 0x0032 100 100 000 Old_age Always - 5
194 Temperature 0x0022 100 100 000 Old_age Always - 26 (Min/Max 15/31)
196 Reallocated_sector_event_count 0x0032 100 100 000 Old_age Always - 0
197 Current_pending_sector_count 0x0032 100 100 000 Old_age Always - 0
198 Offline_scan_uncorrectable_sector_count 0x0030 100 100 000 Old_age Offline - 0
199 CRC_error_count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 1310722
222 Loaded_hours 0x0032 100 100 000 Old_age Always - 34
223 Load_retry_count 0x0032 100 100 000 Old_age Always - 0
224 Load_friction 0x0022 100 100 000 Old_age Always - 0
226 Load_in_time 0x0026 100 100 000 Old_age Always - 597
240 DST_write_head_test_failure 0x0001 100 100 001 Pre-fail Offline - 0
Serial Number: 14B0B0BKUBWG
LU WWN Device Id: 5 000039 d09400ffc
3 Spin_up_time 0x0027 100 100 001 Pre-fail Always - 8062
194 Temperature 0x0022 100 100 000 Old_age Always - 28 (Min/Max 12/34)
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 1179648
226 Load_in_time 0x0026 100 100 000 Old_age Always - 592
Serial Number: 14B0B0C7UBWG
LU WWN Device Id: 5 000039 d09401012
3 Spin_up_time 0x0027 100 100 001 Pre-fail Always - 7957
194 Temperature 0x0022 100 100 000 Old_age Always - 27 (Min/Max 13/33)
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 1048577
226 Load_in_time 0x0026 100 100 000 Old_age Always - 591
Smart Log for NVME device:nvme0n1 namespace-id:ffffffff
critical_warning : 0
temperature : 35 C
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 0%
data_units_read : 3194
data_units_written : 20598
host_read_commands : 34448
host_write_commands : 596487
controller_busy_time : 0
power_cycles : 4
power_on_hours : 35
unsafe_shutdowns : 2
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 35 C
Temperature Sensor 2 : 19 C
Temperature Sensor 3 : 0 C
Temperature Sensor 4 : 0 C
Temperature Sensor 5 : 0 C
Temperature Sensor 6 : 0 C
Temperature Sensor 7 : 0 C
Temperature Sensor 8 : 0 C
Smart Log for NVME device:nvme1n1 namespace-id:ffffffff
temperature : 38 C
data_units_read : 895
data_units_written : 20601
host_read_commands : 10672
host_write_commands : 596941
power_cycles : 4
power_on_hours : 34
media_errors : 0
Temperature Sensor 1 : 38 C
Temperature Sensor 2 : 21 C
