Business Neue ABfB-Version
Adama
05. Mrz 2013
Grad die Meldung für Version 2.4.1-12321 bekommen:
What's new
    Added support for Windows Server 2022.
    Added support for Linux kernel 5.10 and the following distributions:
        RHEL: 8.4、8.5
        Debian: 11
    Added support for Microsoft Hyper-V failover clusters.
    Added support for Microsoft System Center Virtual Machine Manager (SCVMM).
    Added support for user delegation to grant non DSM admin users package operation permissions.
    Added support for advance search on Task List pages.
    Added support for bandwidth throttling on personal computers and physical servers within a specific IP range.
    Supports notifying users 24 hours after a scheduled backup for computers or physical servers is missed.
    Supports selecting and deselecting all virtual machines under a directory at once when creating backup tasks.
    Supports restoring files and folders to personal computers or physical servers other than the backup source.
    Modified how users exclude files from backup for file filters.
    Increased the retry duration for personal computer and physical server backup tasks. The system will retry backup until 72 hours after a device is disconnected.
    Supports restoring encrypted shared folders from Synology NAS backup tasks via Active Backup for Business Portal.
Fixed Issues (General Issues)
    Fixed an issue where the task result was successful even when only partial data was backed up due to file system support problems.
    Fixed an issue where users couldn't restore files to a device previously disconnected from Active Backup for Business via the Recovery Portal.
    Fixed an issue where file restoration might fail if multiple restoration tasks are processing concurrently.
    Fixed an issue where exporting activity logs and task history might fail.
    Adjusted the retention policy to ensure that at least one successful backup version is kept.
    Fixed an issue where backup templates might not be applied if users changed the capitalization of the destination shared folder name.
    Fixed an issue where storage relink might fail.
    Fixed an issue where users couldn't browse devices' version lists if the backup destination was encrypted.
    Fixed an issue where the package couldn't function properly when it was installed on a Peta Volume.
    Fixed an issue where DSM memory usage would surge when the agent retried uploading logs after the timeout.
    Fixed an issue where backup tasks might fail if the system couldn't perform the backup file mounting test.
    Fixed an issue where backup versions of Windows devices might become corrupted.
    Fixed an issue where file accessibility might be restricted to admin after users restored the backed-up DSM files via Active Backup for Business Portal.
    This update includes fixes to the below issues mentioned in 2.4.0-12234.
        Fixed an issue where users couldn't open files or folders whose names contained letters with diacritical marks from Recovery Portal.
Fixed Issues (Virtual Machines)
    Fixed an issue where Hyper-V backup tasks might fail to apply the application-aware settings.
    Fixed an issue where adding a Hyper-V server might fail when the hypervisor's storage was an external drive.
        Modified the backup mechanism for virtual machines to prevent backup failure when application-aware processing isn't available on the guest operating system.
        Fixed an issue where users couldn't add a Hyper-V failover cluster when it had multiple IP addresses.
Fixed Issues (Servers and Workstations)
    Fixed an issue where Linux devices couldn't connect to Synology NAS when users launched the agent with command lines.
    Fixed an issue where the first backup version might be corrupted after users rebooted their CentOS devices.
Fixed Issues (File Servers)
    Fixed a performance issue of Snapshot Replication caused by file server backup tasks.
    Fixed an Overview information display issue when there were ongoing file server backup tasks.
    Fixed an issue where folders whose names start with "proc" cannot be selected as file server backup destinations.
Ist ja mal eine sehr umfangreiche Liste...
RichardB
11. Jun 2019
Danke, wird mir auch schon angeboten.
Was ich mich frage: ist das (ev. erforderliche) Update der Agents diesmal dabei, oder muss man (wie beim letzten Update) das Agent Paket wieder manuell runterladen und installieren.
Die Umlautproblematik wurde scheinst gefixt (da hätt ich mir mein Ticket sparen können) ;)
Adama
05. Mrz 2013
Also ich konnte einen meiner PCs über die ABfB-Oberfläche aktualisieren...
Und ja, die Umlaut-Problematik ist damit gefixt. Hab's grad noch mal getestet...
RichardB
11. Jun 2019
Danke, das ist beruhigend.
Gerade gesehen: Der Agent für die Server-Sicherung (Beta) wird mir auf meiner 1019+ auch bereits angeboten.
DirkKn
11. Apr 2016
Scheinbar wird jetzt auch wieder eine Sicherung nachgeholt, wenn der Client zum Backupzeitpunkt ausgeschaltet/im Sleep war.
Es war ja sowieso schwachsinnig das abzuschalten.
Leider gibt's immer noch keinen Agenten für macOS.
VG Dirk
