Neue Docker-Version: 24.0.2-1535
Adama
05. Mrz 2013
Ui, es ist passiert: Der Container Manager ist offiziell upgedatet! Habemus Docker!
Die Release Notes:
(2025-02-11)
Important Notes
    Starting from this version, if you perform a clean install of the package, the "docker" shared folder will not have the "Hide this shared folder in My Network Places" setting selected by default.
    As of this version, settings for containers—including ports, volumes, environments, and links—cannot be modified post-creation. To modify the settings, duplicate a desired container and make the change to the newly created one.
Compatibility & Installation
    Starting from this version, Aliyun Hub will no longer be a default registry in the package.
What's New
    Updated Docker Daemon to version 24.0.2.
    Supports duplicating container configurations to easily create new containers.
    Supports displaying the container's status and error details upon hovering over an unhealthy container.
    Supports resizing the terminal interface window for containers.
Fixed Issues
    Fixed an issue where container ports connections might fail when multiple gateways were enabled on DSM.
    Fixed an issue where IPv6 configurations might not be correctly applied.
    Fixed an issue where the image status might not display correctly after downloading the image again from the registry.
    Fixed an issue where certain container log text might be garbled.
    Fixed an issue where the status of containerized web service might not be properly updated in Web Station.
    Fixed an issue where the system might not show a reminder message when the URL for registry mirror was incorrect.
    Fixed an issue where the container settings tab might not correctly display volumes specified with long syntax in a docker-compose file.
Limitation
    Restricted the "Enable resource limitation" option to be unmodifiable once it was enabled for the container.
Anmerkungen:
    This version is released in a staged rollout.
https://www.synology.com/de-de/releaseNote/ContainerManager?model=DS918+&os=DSM&version=7_x_series
Ich bin so aufgeregt... :ROFLMAO:
Adama
05. Mrz 2013
Und das Update hat ohne Probleme geklappt (von der Beta aus).
metalworker
25. Apr 2023
Aktuell ist docker wohl bei der 27.xx wenn ich das richtig sehe .
Aber immerhin sind wir mal wieder etwas näher dran
Adama
05. Mrz 2013
Wir sind hier bei Synology. Du erwartest nicht ernsthaft, dass wir da was aktuelles bekommen, oder? ;)
metalworker
25. Apr 2023
NA das stimmt .
Wie oft Haut Docker denn ne neue Version eigentlich raus?
Kachelkaiser
22. Feb 2018
