- Mitglied seit
- 13. Nov 2008
- Punkte für Reaktionen
- 0
Hallo
Es geht um eine DS508. Ein Neustart von dem Teil dauert knapp 20 Minuten.
Es spielt keine Rolle ob der Neustart per SSH oder per Webinterface ausgelöst wird. Die Station ist dann nach kurzer Zeit wieder pingbar, sonst nicht erreichbar.
Das Protokoll im Webinterface
Information 2008/12/09 12:49:54 admin Windows file service was started.
Information 2008/12/09 12:49:40 admin System started to boot up.
Information 2008/12/09 12:32:16 admin Windows file service was stopped.
Information 2008/12/09 12:32:16 admin Apple file service was stopped.
Information 2008/12/09 12:32:13 admin System started counting down to reboot.
Information 2008/12/09 12:32:05 admin User [admin] logged in [Management] from [X].
Hier ein paar Zeilen aus /var/log/messages:
Dec 9 12:32:13 findhostd: si_pid=[28297], process=[/bin/sh]
Dec 9 12:32:13 findhostd: si_ppid=[28296], process=[sh]
Dec 9 12:32:13 findhostd: findhostd.c:51(FHOSTDExit) exit on signal[10]
Dec 9 12:32:13 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Dec 9 12:32:14 scemd: ErrScemChangeMTUEvent(328) SLIBFileGetKeyValue(MTUValue) failed(2000).
Dec 9 12:32:16 scemd: ErrScemChangeMTUEvent(328) SLIBFileGetKeyValue(MTUValue) failed(2000).
Dec 9 12:32:16 rsyncd[2814]: rsync error: received SIGUSR1 or SIGINT (code 20) at rsync.c(163)
Dec 9 12:32:16 scheduler: scheduler.c (1297) Got signal. Die gracefully.
Dec 9 12:32:17 scheduler: scheduler.c (1315) rTorrent is killed.
Dec 9 12:32:18 scemd: ErrScemChangeMTUEvent(328) SLIBFileGetKeyValue(MTUValue) failed(2000).
Dec 9 12:32:20 scemd: ErrScemChangeMTUEvent(328) SLIBFileGetKeyValue(MTUValue) failed(2000).
Dec 9 12:32:22 scemd: ErrScemChangeMTUEvent(328) SLIBFileGetKeyValue(MTUValue) failed(2000).
Dec 9 12:34:42 s00_synocheckfstab: s00_synocheckfstab_main(240): /etc/fstab format error. szBuf=/dev/md2 /volume1 ext3 defaults 0 0
Dec 9 12:34:42 s00_synocheckfstab: s00_synocheckfstab_main(240): /etc/fstab format error. szBuf=/dev/md3 /volume2 ext3 defaults 0 0
Dec 9 12:34:42 s00_synocheckfstab: s00_synocheckfstab_main(188): /etc/fstab format error. redundant 'proc' line.
Dec 9 12:34:43 kernel: EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
Dec 9 12:49:39 kernel: EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
Dec 9 12:49:46 scemd: modules/disk_hibernation.c:79 Force hibernation enable, idle minutes 0
Dec 9 12:49:46 scemd: modules/raid_sys_volume_check.c:382 MD0 active disks 5, designed disks 5
Dec 9 12:49:46 scemd: modules/raid_sys_volume_check.c:382 MD1 active disks 5, designed disks 5
Dec 9 12:49:47 synousbdisk: RCClean succeeded
Auszug aus dmesg:
EXT3 FS on md2, internal journal
EXT3-fs: mounted filesystem with writeback data mode.
kjournald starting. Commit interval 5 seconds
EXT3 FS on md3, internal journal
ata5.00: configured for UDMA/100
ata5: EH complete
sd 4:0:0:0: [sde] 1953525168 512-byte hardware sectors (1000205 MB)
sd 4:0:0:0: [sde] Write Protect is off
sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Anscheinend prüft der das FS beim booten. Wieso jedoch jedesmal?
Wo liegt das Problem?
Auszug aus dmesg:
ata5: EH complete
