ich habe das aktuelle Node.js package (node v0.10.33, npm v1.4.28) welches von Synology herausgegeben wurde installiert. Wenn ich jetzt allerdings versuche irgendein Paket zu installieren dann bekomme ich immer den selben Fehler.
Beispiel: "npm install express"
0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', 'express' ]
2 info using npm@1.4.28
3 info using node@v0.10.33
4 verbose node symlink /usr/bin/node
5 verbose cache add [ 'express', null ]
6 verbose cache add name=undefined spec="express" args=["express",null]
7 verbose parsed url { protocol: null,
7 verbose parsed url slashes: null,
7 verbose parsed url auth: null,
7 verbose parsed url host: null,
7 verbose parsed url port: null,
7 verbose parsed url hostname: null,
7 verbose parsed url hash: null,
7 verbose parsed url search: null,
7 verbose parsed url query: null,
7 verbose parsed url pathname: 'express',
7 verbose parsed url path: 'express',
7 verbose parsed url href: 'express' }
8 silly lockFile f3c62de4-express express
9 error Error: Attempt to unlock express, which hasn't been locked
9 error at unlock (/volume1/@appstore/Node.js/usr/lib/node_modules/npm/lib/utils/locker.js:44:11)
9 error at cb (/volume1/@appstore/Node.js/usr/lib/node_modules/npm/lib/cache/add-local.js:30:5)
9 error at /volume1/@appstore/Node.js/usr/lib/node_modules/npm/lib/cache/add-local.js:47:20
9 error at /volume1/@appstore/Node.js/usr/lib/node_modules/npm/lib/utils/locker.js:22:20
9 error at /volume1/@appstore/Node.js/usr/lib/node_modules/npm/node_modules/inflight/inflight.js:22:7
9 error at Array.forEach (native)
9 error at res (/volume1/@appstore/Node.js/usr/lib/node_modules/npm/node_modules/inflight/inflight.js:21:9)
9 error at f (/volume1/@appstore/Node.js/usr/lib/node_modules/npm/node_modules/once/once.js:16:25)
9 error at afterMkdir (/volume1/@appstore/Node.js/usr/lib/node_modules/npm/lib/cache/get-stat.js:53:14)
9 error at /volume1/@appstore/Node.js/usr/lib/node_modules/npm/node_modules/mkdirp/index.js:34:29
10 error If you need help, you may report this *entire* log,
10 error including the npm and node versions, at:
10 error <http://github.com/npm/npm/issues>
11 error System Linux 2.6.32.12
12 error command "/usr/bin/node" "/usr/bin/npm" "install" "express"
13 error cwd /volume1/web/test
14 error node -v v0.10.33
15 error npm -v 1.4.28
16 verbose exit [ 1, true ]
Nun weiß ich nicht weiter. Ich hoffe Ihr könnt mir weiterhelfen.
Hier noch die Daten meiner DiskStation.
Modellname: DS212+
Prozessor: MARVELL Kirkwood 88F6282
Prozessor-Taktrate: 2 GHz
Prozessorkerne: 1
Arbeitsspeicher insgesamt: 512 MB
DSM-Version: DSM 5.1-5004
Modellname: DS212+
Prozessorkerne: 1
