Moin,
ich hatte ein Ticket bei Synology aufgegeben, weil ich reproduzierbar einen Einbruch in der Datenübertragung (egal ob AFP oder SMB) habe, sobald ich MySQL starte. MySQL wieder aus, Datenübertagung wieder schnell.
Nach Zusendung des Kernel Logs und einiger Screenshots an Synology kam folgende Antwort:
Hi ,
Thank you for your inquiry.
According to our developers, they've noticed that you have installed some optware and/or 3rd party software.
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 2451064 454996 1893668 19% /
/tmp 124628 776 123852 1% /tmp
/dev/md2 956786420 693280600 263403420 72% /volume1
/dev/md3 956786420 381902704 574781316 40% /volume2
/VOLUME1/@OPTWARE 956786420 693280600 263403420 72% /OPT
/dev/sdq1 1922858256 1154193728 768562128 60% /volumeUSB1/usbshare
As these haven't been tested and supported by DSM, we couldn't guarantee compatibility and proper functioning of DSM. 3rd party software / optware has been known to cause strange behavior on DSM.
If you install 3rd-party software like ipkg, we will suggest that you make a reset by the below method to get a fresh system (follow the firmware reinstall method) and please carefully read the disclaimer:
http://forum.synology.com/wiki/index.php/How_to_Reset_the_Synology_System [7]
If problem still persist after installing the clean DSM system, please feel free to contact Synology support again.
also werde ich die Kiste mal zurücksetzen und hoffen, dass dann der Fehler weg ist.
hope..
Hi ,
hope..
