Ich habe OpenVPN und das VPN Center nach Anleitung eingerichtet.
Jetzt bekomme ich folgende Fehlermeldung von OpenVPN:
Wo liegt mein Fehler?
In der Config-Datei von OpenVPN habe ich mein dynds.org Adresse eingegeben..
Im Vorus vielen Dank für eure Bemühungen!
Tue Sep 20 18:02:41 2011 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Sep 20 18:02:41 2011 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Tue Sep 20 18:02:41 2011 LZO compression initialized
Tue Sep 20 18:02:41 2011 UDPv4 link local (bound): [undef]:1194
Tue Sep 20 18:02:41 2011 UDPv4 link remote: ######
Tue Sep 20 18:03:41 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Tue Sep 20 18:03:41 2011 TLS Error: TLS handshake failed
Tue Sep 20 18:03:41 2011 SIGUSR1[soft,tls-error] received, process restarting
Tue Sep 20 18:03:43 2011 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA. OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
