OpenVPN nach Update nicht von allen Clients erreichbar
funzel1607
16. Jan 2013
ich habe gestern das Update auf Version 1.2-2456 gemacht. Ein Tunnel via iOS funktioniert nach wie vor problemlos. Jedoch habe ich seitdem keinen Zugriff mehr via Viscosity.
Es kommt nur noch folgende Meldung:
Nov 04 08:50:59: Viscosity Mac 1.5.11 (1314)
Nov 04 08:50:59: Viscosity OpenVPN Engine Started
Nov 04 08:50:59: Running on Mac OS X 10.11.1
Nov 04 08:50:59: ---------
Nov 04 08:50:59: Checking reachability status of connection...
Nov 04 08:50:59: Connection is reachable. Starting connection attempt.
Nov 04 08:50:59: OpenVPN 2.3.8 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on Sep 23 2015
Nov 04 08:50:59: library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.09
Nov 04 08:51:02: Attempting to establish TCP connection with [AF_INET]xxx.xxx.xxx.xxx:1194 [nonblock]
Nov 04 08:51:03: TCP connection established with [AF_INET]xxx.xxx.xxx.xxx:1194
Nov 04 08:51:03: TCPv4_CLIENT link local: [undef]
Nov 04 08:51:03: TCPv4_CLIENT link remote: [AF_INET]xxx.xxx.xxx.xxx:1194
Nov 04 08:51:03: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Nov 04 08:51:04: VERIFY ERROR: depth=0, error=certificate signature failure: C=TW, ST=Taiwan, L=Taipei, O=Synology Inc., OU=FTP Team, CN=synology.com, emailAddress=product@synology.com
Nov 04 08:51:04: TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Nov 04 08:51:04: TLS Error: TLS object -> incoming plaintext read error
Nov 04 08:51:04: TLS Error: TLS handshake failed
Nov 04 08:51:04: Fatal TLS error (check_tls_errors_co), restarting
Nov 04 08:51:04: SIGUSR1[soft,tls-error] received, process restarting
Nov 04 08:51:07: SIGTERM[hard,init_instance] received, process exiting
Hat Jemand eine Idee?
Danke!
funzel1607
16. Jan 2013
Habe es gelöst bekommen. Nach dem Update war es nötig die OpenVPN Konfiguration erneut zu exportieren und im Client das alte durch das "neue" Zertifikat zu ersetzen.
