Mon Nov 04 17:05:07 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [IPv6] built on Aug 22 2013
Mon Nov 04 17:05:12 2013 WARNING: No server certificate verification method has been enabled. See
http://openvpn.net/howto.html#mitm for more info.
Mon Nov 04 17:05:13 2013 UDPv4 link local (bound): [undef]
Mon Nov 04 17:05:13 2013 UDPv4 link remote: [AF_INET]178.7.141.27:1194
Mon Nov 04 17:05:13 2013 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Mon Nov 04 17:05:14 2013 [synology.com] Peer Connection Initiated with [AF_INET]178.7.141.27:1194
Mon Nov 04 17:05:16 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Nov 04 17:05:16 2013 open_tun, tt->ipv6=0
Mon Nov 04 17:05:16 2013 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{6F153CC2-900D-4633-AAB0-71F6DDC7496A}.tap
Mon Nov 04 17:05:16 2013 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.0.4.6/255.255.255.252 on interface {6F153CC2-900D-4633-AAB0-71F6DDC7496A} [DHCP-serv: 10.0.4.5, lease-time: 31536000]
Mon Nov 04 17:05:16 2013 Successful ARP Flush on interface [12] {6F153CC2-900D-4633-AAB0-71F6DDC7496A}
Mon Nov 04 17:05:21 2013 Initialization Sequence Completed
Mon Nov 04 19:31:36 2013 [synology.com] Inactivity timeout (--ping-restart), restarting
Mon Nov 04 19:31:36 2013 SIGUSR1[soft,ping-restart] received, process restarting
Mon Nov 04 19:31:38 2013 WARNING: No server certificate verification method has been enabled. See
Mon Nov 04 19:31:38 2013 UDPv4 link local (bound): [undef]
Mon Nov 04 19:31:38 2013 UDPv4 link remote: [AF_INET]178.7.141.27:1194
Mon Nov 04 19:31:56 2013 [synology.com] Peer Connection Initiated with [AF_INET]178.7.141.27:1194
Mon Nov 04 19:31:58 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Nov 04 19:31:58 2013 open_tun, tt->ipv6=0
Mon Nov 04 19:31:58 2013 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{6F153CC2-900D-4633-AAB0-71F6DDC7496A}.tap
Mon Nov 04 19:31:58 2013 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.0.4.10/255.255.255.252 on interface {6F153CC2-900D-4633-AAB0-71F6DDC7496A} [DHCP-serv: 10.0.4.9, lease-time: 31536000]
Mon Nov 04 19:31:58 2013 Successful ARP Flush on interface [12] {6F153CC2-900D-4633-AAB0-71F6DDC7496A}
Mon Nov 04 19:32:33 2013 Warning: route gateway is not reachable on any active network adapters: 10.0.4.9
Mon Nov 04 19:32:33 2013 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Mon Nov 04 19:32:33 2013 SYSTEM ROUTING TABLE
Mon Nov 04 19:32:33 2013 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=10 t=4 pr=3 a=9050 h=0 m=200/0/0/0/0
Mon Nov 04 19:32:33 2013 10.0.4.0 255.255.255.0 10.0.4.9 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
Mon Nov 04 19:32:33 2013 10.0.4.1 255.255.255.255 10.0.4.9 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
Mon Nov 04 19:32:33 2013 10.0.4.4 255.255.255.252 10.0.4.6 p=0 i=12 t=3 pr=3 a=8836 h=0 m=286/0/0/0/0
Mon Nov 04 19:32:33 2013 10.0.4.6 255.255.255.255 10.0.4.6 p=0 i=12 t=3 pr=3 a=8836 h=0 m=286/0/0/0/0
Mon Nov 04 19:32:33 2013 10.0.4.7 255.255.255.255 10.0.4.6 p=0 i=12 t=3 pr=3 a=8836 h=0 m=286/0/0/0/0
Mon Nov 04 19:32:33 2013 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=9070 h=0 m=306/0/0/0/0
Mon Nov 04 19:32:33 2013 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=9070 h=0 m=306/0/0/0/0
Mon Nov 04 19:32:33 2013 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=9070 h=0 m=306/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.1.0 255.255.255.0 192.168.1.2 p=0 i=10 t=3 pr=3 a=9050 h=0 m=356/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.1.2 255.255.255.255 192.168.1.2 p=0 i=10 t=3 pr=3 a=9050 h=0 m=356/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.1.255 255.255.255.255 192.168.1.2 p=0 i=10 t=3 pr=3 a=9050 h=0 m=356/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.2.0 255.255.255.0 10.0.4.9 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.56.0 255.255.255.0 192.168.56.1 p=0 i=40 t=3 pr=3 a=9051 h=0 m=276/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.56.1 255.255.255.255 192.168.56.1 p=0 i=40 t=3 pr=3 a=9051 h=0 m=276/0/0/0/0
Mon Nov 04 19:32:33 2013 192.168.56.255 255.255.255.255 192.168.56.1 p=0 i=40 t=3 pr=3 a=9051 h=0 m=276/0/0/0/0
Mon Nov 04 19:32:33 2013 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=9070 h=0 m=306/0/0/0/0
Mon Nov 04 19:32:33 2013 224.0.0.0 240.0.0.0 192.168.1.2 p=0 i=10 t=3 pr=3 a=9054 h=0 m=356/0/0/0/0
Mon Nov 04 19:32:33 2013 224.0.0.0 240.0.0.0 10.0.4.6 p=0 i=12 t=3 pr=3 a=9054 h=0 m=286/0/0/0/0
Mon Nov 04 19:32:33 2013 224.0.0.0 240.0.0.0 192.168.56.1 p=0 i=40 t=3 pr=3 a=9054 h=0 m=276/0/0/0/0
Mon Nov 04 19:32:33 2013 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=9070 h=0 m=306/0/0/0/0
Mon Nov 04 19:32:33 2013 255.255.255.255 255.255.255.255 192.168.1.2 p=0 i=10 t=3 pr=3 a=9054 h=0 m=356/0/0/0/0
Mon Nov 04 19:32:33 2013 255.255.255.255 255.255.255.255 10.0.4.6 p=0 i=12 t=3 pr=3 a=9054 h=0 m=286/0/0/0/0
Mon Nov 04 19:32:33 2013 255.255.255.255 255.255.255.255 192.168.56.1 p=0 i=40 t=3 pr=3 a=9054 h=0 m=276/0/0/0/0
Mon Nov 04 19:32:33 2013 SYSTEM ADAPTER LIST
Mon Nov 04 19:32:33 2013 TAP-Windows Adapter V9
Mon Nov 04 19:32:33 2013 Index = 12
Mon Nov 04 19:32:33 2013 GUID = {6F153CC2-900D-4633-AAB0-71F6DDC7496A}
Mon Nov 04 19:32:33 2013 IP = 10.0.4.6/255.255.255.252
Mon Nov 04 19:32:33 2013 MAC = 00:ff:6f:15:3c:c2
Mon Nov 04 19:32:33 2013 GATEWAY = 0.0.0.0/255.255.255.255
Mon Nov 04 19:32:33 2013 DHCP SERV = 10.0.4.5/255.255.255.255
Mon Nov 04 19:32:33 2013 DHCP LEASE OBTAINED = Mon Nov 04 17:05:16 2013
Mon Nov 04 19:32:33 2013 DHCP LEASE EXPIRES = Tue Nov 04 17:05:16 2014
Mon Nov 04 19:32:33 2013 DNS SERV =
Mon Nov 04 19:32:33 2013 Realtek PCIe GBE Family Controller
Mon Nov 04 19:32:33 2013 Index = 10
Mon Nov 04 19:32:33 2013 GUID = {63C80402-988E-4A68-BC23-C1292FDAAE1C}
Mon Nov 04 19:32:33 2013 IP = 192.168.1.2/255.255.255.0
Mon Nov 04 19:32:33 2013 MAC = d0:27:88:63:fd:78
Mon Nov 04 19:32:33 2013 GATEWAY = 192.168.1.1/255.255.255.255
Mon Nov 04 19:32:33 2013 DHCP SERV = 192.168.1.1/255.255.255.255
Mon Nov 04 19:32:33 2013 DHCP LEASE OBTAINED = Mon Nov 04 17:01:42 2013
Mon Nov 04 19:32:33 2013 DHCP LEASE EXPIRES = Mon Nov 11 17:01:42 2013
Mon Nov 04 19:32:33 2013 DNS SERV = 192.168.1.1/255.255.255.255
Mon Nov 04 19:32:33 2013 VirtualBox Host-Only Ethernet Adapter #2
Mon Nov 04 19:32:33 2013 Index = 40
Mon Nov 04 19:32:33 2013 GUID = {2EF98499-BA41-4E0B-9C1F-71D131C96266}
Mon Nov 04 19:32:33 2013 IP = 192.168.56.1/255.255.255.0
Mon Nov 04 19:32:33 2013 MAC = 08:00:27:00:00:8c
Mon Nov 04 19:32:33 2013 Initialization Sequence Completed With Errors ( see
http://openvpn.net/faq.html#dhcpclientserv )
