pcregrep installieren / Alternative
etofi
10. Jul 2021
ich möchte regelmäßig folgende Script laufen lassen in dem pcregrep verwendet wird.
Leider ist pcregrep nicht verfügbar.
Gibt es einen Weg das nachzuinstallieren? Oder eine Alternative für pcregrep.
Ich bin leider nicht so der Profi was Regular Expressions angeht.
Wäre super wenn jemand eine Idee für mich hätte.
#!/bin/bash
SOURCE_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" >/dev/null 2>&1 && pwd)"
EXPORT_DIR="$SOURCE_DIR/export"
WORK_DIR="$SOURCE_DIR/working"
STATS_DIR="$SOURCE_DIR/stats"
LISTS="$SOURCE_DIR/lists.txt"
REGEX="$SOURCE_DIR/regex.txt"
CUSTOM_BLACKLIST="$SOURCE_DIR/custom_blacklist.txt"
CUSTOM_WHITELIST="$SOURCE_DIR/custom_whitelist.txt"
TMP_LIST="$WORK_DIR/blocklist.tmp"
TMP_LIST2="$WORK_DIR/blocklist.tmp2"
FNL_LIST="$EXPORT_DIR/blocklist.txt"
FNL_LIST_ZERO="$EXPORT_DIR/blocklist_all_zero.txt"
# STATS
CHANGELOG="$STATS_DIR/changelog.txt"
ADDED_DOMAINS="$STATS_DIR/added.txt"
REMOVED_DOMAINS="$STATS_DIR/removed.txt"
GROUPED_BY_DOMAIN="$STATS_DIR/top_50_blocked_tld.txt"
# Create Dirs
mkdir -p "$STATS_DIR" "$EXPORT_DIR" "$WORK_DIR"
# Download all block lists into one single file
echo -e "All block lists are currently being downloaded ..."
while read -r url; do curl -s "$url" >>"$TMP_LIST"; done <"$LISTS"
cat "$CUSTOM_BLACKLIST" >> "$TMP_LIST"
echo -e "Removing everything starting with punctation ..."
sed -i '/^[[:punct:]]/ d' "$TMP_LIST"
echo -e "Removing IP adresses ..."
sed -i -e 's/[0-9]\{1,3\}\.[0-9]\{1,3\}\.[0-9]\{1,3\}\.[0-9]\{1,3\}//g' "$TMP_LIST"
echo -e "Removing spaces and setting everything lower case ..."
cat "$TMP_LIST" | tr -d ' ' | tr -d '\t' | sed '/^[[:space:]]*$/d' | tr '[:upper:]' '[:lower:]' >"$TMP_LIST2" && mv -f "$TMP_LIST2" "$TMP_LIST"
echo -e "Sorting and removing duplicates ..."
grep -oe '^.*\S' "$TMP_LIST" | sort | uniq >"$TMP_LIST2" && mv -f "$TMP_LIST2" "$TMP_LIST"
echo -e "Validating domains and subdomains ..."
pcregrep -o '^([a-z0-9][a-z0-9-_]*\.)*[a-z0-9]*[a-z0-9-_]*[[a-z0-9]+$' "$TMP_LIST" >"$TMP_LIST2" && mv -f "$TMP_LIST2" "$TMP_LIST"
echo -e "Regex filters are applied ..."
while read -r r; do sed -i -E "${r}d" "$TMP_LIST"; done <"$REGEX"
echo -e "Entries of the whitelist are kept ..."
comm -23 <(sort "$TMP_LIST") <(sort "$CUSTOM_WHITELIST")  >"$TMP_LIST2" && mv -f "$TMP_LIST2" "$TMP_LIST"
echo -e "Stats: Top 50 blocked domains ..."
cat "$TMP_LIST" | sed 's/.*\.//' | sort | uniq -c | sort -nr | head -50 >"$GROUPED_BY_DOMAIN"
echo -e "Stats: Changelog ..."
echo "$(date +"%Y-%m-%d %H:%M:%S")    $(wc -l <"$TMP_LIST") Domains" >>"$CHANGELOG"
echo "$(tail -10 "$CHANGELOG")" >"$CHANGELOG"
comm -13 <(sort "$TMP_LIST") <(sort "$FNL_LIST") >"$REMOVED_DOMAINS"
comm -23 <(sort "$TMP_LIST") <(sort "$FNL_LIST") >"$ADDED_DOMAINS"
echo -e "Stats: \e[32m$(wc -l <"$ADDED_DOMAINS") \e[39madded domains ..."
echo -e "Stats: \e[31m$(wc -l <"$REMOVED_DOMAINS") \e[39mremoved domains ..."
echo -e "The generation is complete: \e[95m$(wc -l <"$TMP_LIST") domains are in the blocklist!"
sed -e 's/^/0.0.0.0\ /' "$TMP_LIST" >"$FNL_LIST_ZERO"
mv -f "$TMP_LIST" "$FNL_LIST"
