habe bisher 3 Synos völlig problemlos aktualisieren können (inkl. komplettem Neuaufbau der Raids wg. Ext4), allerdings alle von der DSM 3.0 Beta aus. Scheinbar treten aber hin und wieder Probleme beim Upgrade auf.
Zitat von der Synology Download-Seite:
Due to users' feedback on possible malfunction during DSM 3.0 upgrades, the DSM download link is temporarily closed. We had identified the root cause and will reopen the download link shortly as soon as the fix is ready.
If you already upgraded your DiskStation and having the same issue, please contact our support service at http://www.synology.com/support/support_form.php. We apologize for the inconvenience. Thank you very much for your patience and constant support for Synology products.
Da lohnt es sich bestimmt noch etwas zu warten vor dem Upgrade ;-)
Cheers
/J.
Cheers
/J.
