Probleme mit session_start() und file_exist()
hackerzzzz
09. Dez 2007
Ich möchte auf meiner CubeStation CS407 eine Jinzora-WebApplikation laufen lassen.
Bei der Installation erscheinen folgende Fehler:
PHP:
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/volume1/web/../lib-common.php) is not within the allowed path(s): (/volume1/web:/volume2/web:/volume3/web:/volume4/web:/volume5/web:/volume1/photo:/volume2/photo:/volume3/photo:/volume4/photo:/volume5/photo:/usr/syno/synoman:/etc:/var/run:/tmp:/var/spool/php:/volume1/@tmp/php:/var/services/web:/var/services/photo:/var/services/blog) in /volume1/web/index.php on line 64
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/volume1/web/../../mainfile.php) is not within the allowed path(s): (/volume1/web:/volume2/web:/volume3/web:/volume4/web:/volume5/web:/volume1/photo:/volume2/photo:/volume3/photo:/volume4/photo:/volume5/photo:/usr/syno/synoman:/etc:/var/run:/tmp:/var/spool/php:/volume1/@tmp/php:/var/services/web:/var/services/photo:/var/services/blog) in /volume1/web/index.php on line 70
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/volume1/web/../../class2.php) is not within the allowed path(s): (/volume1/web:/volume2/web:/volume3/web:/volume4/web:/volume5/web:/volume1/photo:/volume2/photo:/volume3/photo:/volume4/photo:/volume5/photo:/usr/syno/synoman:/etc:/var/run:/tmp:/var/spool/php:/volume1/@tmp/php:/var/services/web:/var/services/photo:/var/services/blog) in /volume1/web/index.php on line 76
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /volume1/web/index.php:64) in /volume1/web/index.php on line 86
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /volume1/web/index.php:64) in /volume1/web/index.php on line 86
Kann mir jemand sagen, wie ich dies beheben / umgehen kann?
Besten dank schon mal für die Hilfe
freundliche Grüsse
Azibi
20. Apr 2008
bist du mit deinem Problem weitergekommen? Würde mich auch für so eine Lösung interessieren....
Gruß Azibi
Trolli
12. Jul 2007
Den open_basdir Fehler kannst Du umgehen, indem Du in der /usr/syno/etc/php.ini den Pfad aus der Variable open_basedir entfernst. Da sollte dann (Zeile 205?) nur noch stehen:
open_basedir =
Der user Apache bzw. die Station muss danach neu gestartet werden.
Trolli
Pax90
14. Aug 2008
Ich würde aus sicherheitstechnischen Gründen empfehlen, dass Du in deiner .php nachguckst, auf welchen Pfad er zugreifen will und diesen in "open_basedir =" ergänzen =)
