Pyload Startskript will nicht.
blinddark
03. Jan 2013
ich habe pyload erfolgreich installiert. Wenn ich jetzt das Startskriptmit /opt/etc/init.d/S99pyload –start aufrufe erscheint folgende Meldung
/opt/etc/init.d/S99pyload: line 3: syntax error: unexpected end of file (expecti ng "then"). Wo liegt hier der Hund begraben? Pyload ist in /opt/ installiert.
Mein Skript sieht folgendermaßen aus:
#!/bin/sh
# pyLoad STARTUP and UPDATE SCRIPT for Synology NAS
# AUTOSTART pyLoad as DAEMON - UPDATE PROGRAM FILES
# <./S99pyload info> for more details and help
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin
SYNO=/usr/syno/bin
DAEMON="python /opt/pyload/pyLoadCore.py --daemon"
DAEMON_OPTS="--debug"
QUIT="python /opt/pyload/pyLoadCore.py --quit"
STATUS="python /opt/pyload/pyLoadCore.py --status"
VERSION="python /opt/pyload/pyLoadCore.py --version"
RELEASE_SRC="https://bitbucket.org/spoob/pyload/get/v0.4.9.zip" #edit v0.4.9.zip if a new release is out there!
UPDATE_SRC="https://bitbucket.org/spoob/pyload/get/tip.zip"
LOG="/volume1/pyload/Logs/log.txt" #your path to the Logfile here!
SCRN=/opt/etc/init.d/S99pyload
# COMMANDS START
start()
echo "`$VERSION`: try to start"
echo "`$VERSION`:" `$DAEMON`
sleep 2
if [ `$STATUS` -gt 3 ]; then
echo "`$VERSION`: successfully started"
else
`$DAEMON`
fi
stop()
echo "`$VERSION`: try to kill myself"
echo "`$QUIT`"
setup()
echo "pyLoad: installing latest stable release - only run once!"
cd /opt/; $SYNO/wget --no-check-certificate -q $RELEASE_SRC
if [ $? -eq 0 ] ; then
echo "pyLoad: successfully loaded latest stable release"
else
setup
fi
unzip -q spoob-pyload*.zip; rm spoob-pyload*.zip
echo "pyLoad: archive unzipped and removed"; sleep 2
else
setup
fi
mv spoob-pyload* pyload
cd /opt/pyload/
python pyLoadCore.py -s
else
setup
fi
update()
# if [ `$STATUS` -gt 3 ]; then
stop; sleep 5;
# fi
echo "UPDATE: updating `$VERSION`"
echo "`date '+%d.%m.%Y %T'` INFO Updating `$VERSION`" >>$LOG
cd /opt/
$SYNO/wget --no-check-certificate -q $UPDATE_SRC
echo "UPDATE: successfully loaded dev version"
else
update
fi
echo "UPDATE: archive unzipped and removed"; sleep 2
else
update
fi
$SYNO/rsync -qr /opt/spoob-pyload-*/ /opt/pyload/
echo "UPDATE: `$VERSION` successfully updated"
else
update
fi
rm -rf /opt/spoob-pyload-*/
echo "`date '+%d.%m.%Y %T'` INFO Update complete" >>$LOG
start
stable()
stop; sleep 5;
fi
echo "`$VERSION`: installing latest stable release"
mkdir pyload_tip; cd /opt/pyload/; cp -r * /opt/pyload_tip/
cd /opt/
echo "`$VERSION`: successfully loaded latest stable release"
else
stable
fi
echo "`$VERSION`: archive unzipped and removed"; sleep 2
else
stable
fi
echo "`$VERSION`: successfully installed"
else
stable
fi
start
debug()
echo "`$VERSION`: already performing ... restart"
stop
sleep 5
debug
else
echo "`$VERSION`: try to start in debug mode + show output"
echo "`$VERSION`:" `$DAEMON $DAEMON_OPTS`
sleep 2
echo "`$VERSION`: successfully startet in debug mode"
echo ""
echo "***** ctrl + c to STOP OUTPUT and return *****"
echo ""
tail -f $LOG
else
fi
fi
info()
then
echo "`$VERSION`: Process ID is `$STATUS`"
echo ""
echo -e '\e[33m####################################################################\e[0m'
echo -e '\e[33m# OPERATIONS\e[0m'
echo -e '\e[33m# start = start pyLoad (default)\e[0m'
echo -e '\e[33m# stop = stop pyLoad\e[0m'
echo -e '\e[33m# restart = stop and start pyLoad\e[0m'
echo -e '\e[33m# setup = install pyLoad **only run at the first time**\e[0m'
echo -e '\e[33m# stable = run the latest stable version\e[0m'
echo -e '\e[33m# update = update program files\e[0m'
echo -e '\e[33m# debug = enable debug mode + output\e[0m'
echo -e '\e[33m# info = print out PID and status of pyLoad\e[0m'
echo -e '\e[33m# show = print out Logfile while executing\e[0m'
else
echo "`$VERSION`: process is NOT active"
fi
show()
start
while [ `$STATUS` -gt 3 ]; do
echo ""
echo ""
tail -f $LOG
done
case "$1" in
start)
start
stop)
stop
restart)
stop
sleep 5
start
setup)
setup
stable)
stable
update)
update
debug)
debug
info)
info
show)
show
echo "Usage: $SCRN (start|stop|restart|setup|stable|update|debug|info|show)" >&2
exit 1
esac
exit 0
# End of script
Grüße Blinddark
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
nur start angeben nicht -start.
blinddark
03. Jan 2013
Da kommt der gleiche fehler
jahlives
19. Aug 2008
klein aber fies :)
da fehlt ein Leerzeichen zwischen ] und ;
blinddark
03. Jan 2013
Hab es jetzt an allen Stellen ersetzt.. Der gleiche Fehler..
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
verwunderlich ist die Meldung line 3.
Starte mal das Script per
sh -x /opt/etc/init.d/S99pyload start
oder auch mal ohne Parameter.
Womit hast Du das Script erstellt?
blinddark
03. Jan 2013
hatte es erst mit notepad++ erstellt und gespeichert. Ich habe es nun noch einmal neu an meine Bedürfnisse angepasst und nicht gespeichert. Nach dem neu Erstellen des Skriptes läuft es nun.. Ich danke euch.
